Då måste jag alltså ändra i PHP-filen. Vet inte hur man gör, men kan det här nedan vara åtmindstone lite på rätt väg? Kollade även efter filnamnet i koden som visas i popupen men hittade inget...
$doc_title = "Lotta Wästerlid";
$columns=9;
$size = GetImageSize($currfile);
$width = 60;
$height = 60;
$quality=70;
$scriptname= "index.php";
$thumb_dir = "thumb";
$thumb_prefix = "thumb_";
[red]echo "<html>\n<head>\n<title>Lotta Wästerlid</title>\n";
echo "<body bgcolor=white>\n<style type="text/css">\n";
echo "<body {
scrollbar-face-color: #FFFFFF;
scrollbar-highlight-color: #FFFFFF;
scrollbar-3dlight-color: #FFFFFF;
scrollbar-darkshadow-color: #FFFFFF;
scrollbar-shadow-color: #FFFFFF;
scrollbar-arrow-color: #CC3333;
scrollbar-track-color: #FFFFFF;
} >\n
</style>\n"[/red]
</head>\n\n\n";
echo "<center>\n<P><BR><BR>\n\n";
$mydirectory= '.';
$counter=0;
$nbfiles = 0;
$currfile = "";
$filestab[0] = "";
$handle=opendir($mydirectory);
//create a directory for thumbnail images
if (! is_dir($thumb_dir))
mkdir($thumb_dir, 0777);
while ($currfile = readdir($handle))
// We get the extension of the current file and keep only image files
$extension= strtolower(substr( strrchr( $currfile, "." ), 1 ));
if ($extension== "gif" || $extension== "jpg" || $extension== "jpeg" ||
$extension== "png")
$nbfiles++;
$currfile = trim($currfile);
$filestab[$nbfiles] = $currfile;
if ($ishome == "")
$width = $size[0] / $ratio;
$height = $size[1] / $ratio;
$format = $size[2]; //1 = GIF, 2 = JPG, 3 = PNG, 5 = PSD, 6 = BMP
$currthumbfile = "./" . $thumb_dir . "/" . $thumb_prefix . $currfile;
if (! file_exists($currthumbfile))
switch ($format) {
case 1: $im_src = imagecreatefromgif($currfile);break;
case 2: $im_src = imagecreatefromjpeg($currfile);break;
case 3: $im_src = imagecreatefrompng($currfile);break;
if (!$im_src)
$currthumbfile = $currfile;
$img_dst = imagecreatetruecolor($width, $height);
imagecopyresampled ($img_dst, $im_src, 0, 0, 0, 0, $width, $height, imagesx($im_src), imagesy($im_src));
Imagejpeg($im_src, $currthumbfile, $quality);
ImageDestroy($im_src);
$currfile = str_replace(" ","%20",$currfile); // Allow filenames with space characters
$currthumbfile = str_replace(" ","%20",$currthumbfile); // Allow filenames with space characters
echo "<A HREF='#' onclick=\"window.open('$scriptname?ishome=1&filename=$currfile&filenumber=$nbfiles', '', 'width=400, height=500, scrollbars=yes, resizable=yes');return false;\">\n";
echo "<IMG SRC=$currthumbfile";
$currfile = str_replace("%20"," ",$currfile); // Clean display of filenames with space characters
echo " alt=\"Enlarge $currfile\">\n";
$currfile = str_replace(" ","%20",$currfile); //Clean display of filenames with space characters
echo "</A>\n";
$counter++;
if ($counter == $columns)
$counter = 0;
echo "<P><P><BR>";
closedir($handle);
if ($ishome == 1)
echo "<P>\n";
$filename = str_replace(" ","%20",$filename); // Allow filenames with space characters
$filename = stripslashes($filename); // Allow filenames with ' characters
echo "<IMG SRC=$filename>\n";
$display = str_replace("%20"," ",$filename); // Clean display of filenames with space characters
echo "<br><b> $display </b><br>";
echo "<P><BR>\n\n";
if ($filenumber != 1)
$prevnumber = $filenumber - 1;
$filestab[$prevnumber] = str_replace(" ","%20",$filestab[$prevnumber]); // Allow filenames with space characters
echo "[<A HREF=$scriptname?ishome=1&filename=$filestab[$prevnumber]&filenumber=$prevnumber>";
echo " << Tidigare</A>] \n";
echo " [<A HREF=$scriptname>Tillbaka</A>] \n";
echo " \n" ;
if ($filenumber != $nbfiles)
$nextnumber = $filenumber + 1;
$filestab[$nextnumber] = str_replace(" ","%20",$filestab[$nextnumber]); // Allow filenames with space characters
echo "[<A HREF=$scriptname?ishome=1&filename=$filestab[$nextnumber]&filenumber=$nextnumber>";
echo "Nästa >></A>]\n";
echo "\n\n";
<P><P><P><P>
</center>
</html>
