Kod till en enkel RSS-läsare?
PHP
12 svar · 809 visningar · startad av Bire
Behöver en mycket enkel kodsnutt som läser RSS... En läsare alltså som jag kan klistra in på en websida.
Any tips?
Nu har jag hittat nått som funkar:
<?php
/*  PHP RSS Reader v1.1
    By Richard James Kendall
    Bugs to [email]richard@richardjameskendall.com[/email]
    Free to use, please acknowledge me
    Place the URL of an RSS feed in the $file variable.
       The $rss_channel array will be filled with data from the feed,
       every RSS feed is different by by and large it should contain:
       Array {
           [TITLE] = feed title
           [DESCRIPTION] = feed description
           [LINK] = link to their website
           [IMAGE] = Array {
                       [URL] = url of image
                       [DESCRIPTION] = alt text of image
           [ITEMS] = Array {
                       [0] = Array {
                               [TITLE] = item title
                               [DESCRIPTION] = item description
                               [LINK = a link to the story
       By default it retrives the Reuters Oddly Enough RSS feed. The data is put into the array
       structure so you can format the information as you see fit.
set_time_limit(0);
$file = "http://www.nyhetsportalen.se/static/export_1065.xml";
$rss_channel = array();
$currently_writing = "";
$main = "";
$item_counter = 0;
function startElement($parser, $name, $attrs) {
       global $rss_channel, $currently_writing, $main;
       switch($name) {
           case "RSS":
           case "RDF:RDF":
           case "ITEMS":
               break;
           case "CHANNEL":
               $main = "CHANNEL";
               break;
           case "IMAGE":
               $main = "IMAGE";
               $rss_channel["IMAGE"] = array();
               break;
           case "ITEM":
               $main = "ITEMS";
               break;
           default:
               $currently_writing = $name;
               break;
function endElement($parser, $name) {
       global $rss_channel, $currently_writing, $item_counter;
       if ($name == "ITEM") {
           $item_counter++;
function characterData($parser, $data) {
    global $rss_channel, $currently_writing, $main, $item_counter;
    if ($currently_writing != "") {
        switch($main) {
            case "CHANNEL":
                if (isset($rss_channel[$currently_writing])) {
                    $rss_channel[$currently_writing] .= $data;
                } else {
                    $rss_channel[$currently_writing] = $data;
                break;
            case "IMAGE":
                if (isset($rss_channel[$main][$currently_writing])) {
                    $rss_channel[$main][$currently_writing] .= $data;
                } else {
                    $rss_channel[$main][$currently_writing] = $data;
                break;
            case "ITEMS":
                if (isset($rss_channel[$main][$item_counter][$currently_writing])) {
                    $rss_channel[$main][$item_counter][$currently_writing] .= $data;
                } else {
                    //print ("rss_channel[$main][$item_counter][$currently_writing] = $data<br>");
                    $rss_channel[$main][$item_counter][$currently_writing] = $data;
                break;
$xml_parser = xml_parser_create();
xml_set_element_handler($xml_parser, "startElement", "endElement");
xml_set_character_data_handler($xml_parser, "characterData");
if (!($fp = fopen($file, "r"))) {
    die("could not open XML input");
while ($data = fread($fp, 4096)) {
    if (!xml_parse($xml_parser, $data, feof($fp))) {
        die(sprintf("XML error: %s at line %d",
                    xml_error_string(xml_get_error_code($xml_parser)),
                    xml_get_current_line_number($xml_parser)));
xml_parser_free($xml_parser);
// output as HTML
print ("<html><head><title>News</title></head><body>");
if (isset($rss_channel["ITEMS"])) {
    if (count($rss_channel["ITEMS"]) > 0) {
        for($i = 0;$i < count($rss_channel["ITEMS"]);$i++) {
            print ("<a href=\"" . $rss_channel["ITEMS"][$i]["LINK"] . "\" target=\"_blank\">" . $rss_channel["ITEMS"][$i]["TITLE"] . "</a>");
            print ("&nbsp;&nbsp;");
    } else {
        print ("<b>There are no articles in this feed.</b>");
print ("</body></html>");
Men hur includerar jag denna fil i en php-fil?
Skriv så här:
<?php
     require "filnamn.php";
Får inte till det.. :(
Kan du försöka förklara lite bättre så vi kan hjälpa dig? ;)
Här är en del av koden:
		<if condition="$bbuserinfo['userid']">
			<td class="vbmenu_control"><a href="login.php?$session[sessionurl]do=logout&amp;u=$bbuserinfo[userid]" onclick="return log_out()">$vbphrase[log_out]</a></td>
		</if>
	</tr>
	</table>
<!-- / nav buttons bar -->
<?php
     require "rss.php";
<br />
<br />
<if condition="$show['popups']">
<!-- NAVBAR POPUP MENUS -->
	<if condition="$show['searchbuttons']">
Hm. Det verkar som att koden du klistrade in är befintlig php-kod eller vad man ska säga. Då behöver du inte skriva <?php och ?> för att inkludera filen... Men gör så att du lägger inkluderingen överst på sidan.
Ser att det är en html-mall från vBulletin. ;)
Det går inte att klistra in php-kod i en mall, utan det måste antingen läggas i php-filen eller läggas in via så kallade hooks (som finns i version 3.5.0 och uppåt).
Utan <?php och ?> funkar det inte heller..
Aha!!
Medlem sedan maj 2003176 inlägg
Koden funkar alldeles utmärkt.
Jag undrar om det går att :
1. lägga in tid/datum när nyheten kommer
2. få nyheter från flera källor ?
3. få mellanrum eller helst ny rad mellan nyheter typ <br>
Hur gör man då ? Hur ser koden ut ?
Och ett problem till:
om man tex väljer http://www.redeyeresearch.com/rss/rss.php
då får man problem med svenska bokstäver .
Någon`??
Ingen
Som kan hjälpa mig ??
253 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
120 ms — deklarationer (db)
121 ms — ändringar (db)
