Är helt ny på php och har en liten fundering. Har hittat modifikation till phpbbforumet som gör att man kan visa inlägg från en viss kategori på vilken sida som helst i den övriga siten. När jag försöker testköra så står det "No Database Selected"
Vart i koden anger jag databasen?
Tack på förhand :)
// Date formatting
function format_date($input,$type)
// Change to your preferred dates
// [url]http://se2.php.net/manual/en/function.strftime.php[/url]
if($type == "long") {
$newsdate = strftime("%A %e %B %H:%M",$input);
if ($type == "short") {
$newsdate = strftime("%a %e %b %H:%M",$input);
echo $newsdate;
// echo ucwords($newsdate);
// Text formatting
// Not complete, someone else maybe can fill it in ?
function format_text($input)
$text_string = nl2br($input);
$text_string = eregi_replace("\\[b\\]([^\\[]*)\\[/b\\]","<b>\\1</b>",$text_string);
$text_string = eregi_replace("\\[i\\]([^\\[]*)\\[/i\\]","<i>\\1</i>",$text_string);
$text_string = eregi_replace("\\[url\\]([^\\[]*)\\[/url\\]","<a href=\"\\1\" target=\"_blank\">\\1</a>",$text_string);
$text_string = eregi_replace("\\[url=([^\\[]+)\\]([^\\[]*)\\[/url\\]","<a href=\"http://\\1\" target=\"_blank\">\\2</a>",$text_string);
// Main function
function mynews($prefix,$forum_id,$limit)
$get_threads = mysql_query("SELECT
ft.*, pt.*, us.username AS POSTER
FROM ".$prefix."_topics ft, ".$prefix."_posts_text pt, ".$prefix."_users us
WHERE ft.forum_id = '$forum_id' AND ft.topic_first_post_id = pt.post_id AND ft.topic_poster = us.user_id
ORDER BY ft.topic_time DESC LIMIT $limit") or die ("<h2>ERROR:</h2>" . mysql_error());
if (mysql_num_rows($get_threads) > 0) {
while ($th = mysql_fetch_array($get_threads)) {
echo "<h3>".$th['topic_title']."</h3>";
echo "<span class=\"date\">";
echo format_date($th['topic_time'],"short");
echo "</span> | <span class=\"poster\">".$th['POSTER']."</span><br /><br />";
echo "<div class=\"newstext\">";
echo format_text($th['post_text']);
echo "</div><br />";
// Maybe you will have to change the location of your forum files
echo "<p align=\"right\"><a class=\"subject\" href=\"/forum/viewtopic.php?t=".$th['topic_id']."\">View comments</a></p>";
echo "<hr /><br />";
// Call the function
// Example: default forum prefix "phpbb", forum id 8 and 15 news on the page
mynews("phpbb","14","15");
