array!!?
2 svar · 260 visningar · startad av Guldstrand
GuldstrandMedlem sedan juli 20041 271 inlägg
Håller på att fixa till ett redan färdigt portal-script, men jag vet inte riktigt hur jag ska lösa följande. :r
Warning: extract(): First argument should be an array in /home/PROTECTED/public_html/PROTECTED/mods/stats.php on line 42
Det finns totalt 1 medlemmar i portalen.
Det finns totalt 10 kategorier från 1 olika länder.
Det finns totalt Totalt bilder cam images in the member archives.
Warning: extract(): First argument should be an array in /home/PROTECTED/public_html/PROTECTED/mods/stats.php on line 85
Det finns totalt Totalt bilder nya bilder idag.
Warning: extract(): First argument should be an array in /home/PROTECTED/public_html/PROTECTED/mods/stats.php on line 99
Det finns totalt Totalt bilder B image transfer in .
stats.php
$update1 = "update db_cam_total set total_images = '0' where id = 'total'";
@mysql_query($update1);
$query = @mysql_query("SELECT id FROM db_cam WHERE active = '1' GROUP BY id");
while ($rows = mysql_fetch_array($query)){
$user_id = $rows[id];
$nums = @mysql_query("SELECT id from db_cam_image_$user_id");
$num_rows = @mysql_num_rows($nums);
$res1 = @mysql_query("select total_images from db_cam_total WHERE id = 'total'");
@extract(mysql_fetch_array($res1));
$new_total = $num_rows + $total_images;
$update2 = "update db_cam_total set total_images = '$new_total' where id = 'total'";
@mysql_query($update2);
<CENTER>
<TABLE WIDTH="400" BORDER="0" CELLSPACING="0" CELLPADDING="2">
<TR>
<TD WIDTH="100%" BGCOLOR="<? echo "$TD_color2"; ?>">
<B><FONT COLOR="<? echo "$text_color1"; ?>" SIZE="-1" FACE="<? echo "$font_type"; ?>"><? echo "$stats_header"; ?></FONT></B></TD>
</TR>
<TR>
<TD WIDTH="100%" BGCOLOR="<? echo "$TD_color1"; ?>">
<FONT COLOR="<? echo "$text_color2"; ?>" SIZE="-1" FACE="<? echo "$font_type"; ?>">
$num1 = "SELECT id from db_cam_cat";
$nums1 = mysql_query($num1);
$num_rows1 = mysql_num_rows($nums1);
$num2 = "SELECT id from db_cam GROUP BY country";
$nums2 = mysql_query($num2);
$num_rows2 = mysql_num_rows($nums2);
$num3 = "SELECT id from db_cam";
$nums3 = mysql_query($num3);
$num_rows3 = mysql_num_rows($nums3);
$q2 = "select total_images from db_cam_total WHERE id = 'total'";
$res2 = mysql_query($q2) or die(mysql_error());
extract(mysql_fetch_array($res2));
echo "$there_are_total $num_rows3 $cam_m_in_portal<BR>";
echo "$there_are_total $num_rows1 $categorys_from $num_rows2 $different_countrys<BR>";
echo "$there_are_total $total_images $cam_i_in_m_archives<BR>";
// Images today start
// GMT time start
$gmt_user = $HTTP_COOKIE_VARS["gmt_client"];
if ($gmt_user == ""){
$gmt_client = date("d-m-Y");
} else {
$arrgmt = array("-12"=>"-12","-11"=>"-11","-10"=>"-10","-9"=>"-9","-8"=>"-8","-7"=>"-7","-6"=>"-6","-5"=>"-5","-4"=>"-4","-3"=>"-3","-2"=>"-2","-1=">"-1","+0"=>"0","+1"=>"1","+2"=>"2","+3"=>"3","+4"=>"4","+5"=>"5","+6"=>"6","+7"=>"7","+8"=>"8","+9"=>"9","+10"=>"10","+11"=>"11","+12"=>"12");
$gmt = $arrgmt[$gmt_user];
$gmt_a = $gmt-$server_GMT;
$gmt_b = $gmt-$server_GMT;
$user_hdiff = $gmt_a-$gmt_b;
$gmt_client = date("d-m-Y", time()+$user_hdiff*3600);
// GMT time end
$month_reset_time = time();
$resh = @mysql_query("select month_reset from db_cam_total WHERE id = 'total_today'");
@extract(mysql_fetch_array($resh));
if($month_reset_time - $month_reset > 10800){
$update3 = "update db_cam_total set total_images = '0' where id = 'total_today'";
@mysql_query($update3);
$queryz = @mysql_query("SELECT id FROM db_cam WHERE active = '1' GROUP BY id");
while ($rowz = @mysql_fetch_array($queryz)){
$useridz = $rowz[id];
$numsz = @mysql_query("SELECT id FROM db_cam_image_$useridz WHERE date = '$gmt_client'");
$num_rows_today = @mysql_num_rows($numsz);
$resg = @mysql_query("select total_images from db_cam_total WHERE id = 'total_today'");
@extract(mysql_fetch_array($resg));
$new_total_today = $num_rows_today + $total_images;
$update4 = "update db_cam_total set total_images = '$new_total_today',month_reset = '$month_reset_time' where id = 'total_today'";
@mysql_query($update4);
$qu = "select total_images from db_cam_total WHERE id = 'total_today'";
$resu = mysql_query($qu) or die(mysql_error());
extract(mysql_fetch_array($resu));
echo "$there_are_total $total_images $new_cams_today<BR>";
// Images today end
// Setup some common file size measurements.
$kb = 1024;         // Kilobyte
$mb = 1024 * $kb;   // Megabyte
$gb = 1024 * $mb;   // Gigabyte
$tb = 1024 * $gb;   // Terabyte
// Get the file size in bytes.
$q1 = "select total_images,month_reset from db_cam_total WHERE id = 'total_kb'";
$res1 = mysql_query($q1) or die(mysql_error());
$size = "$total_images";
if($size < $kb) {
$size = $size." B";
} else if($size < $mb) {
$size = round($size/$kb,2)." KB";
} else if($size < $gb) {
$size = round($size/$mb,2)." MB";
} else if($size < $tb) {
$size = round($size/$gb,2)." GB";
} else {
$size = round($size/$tb,2)." TB";
$monthName = array(01=> "January","February","March","April","May","June","July","August","September","October","November","December");
$monthname=("$monthName[$month_reset]");
echo "$there_are_total $size image transfer in $monthname.";
</FONT></TD>
</TR>
</TABLE>
</CENTER>
Försök att förklara felet så bra som möjligt, (är lite trög när det gäller php). 8-O
Patrik81Medlem sedan okt. 2001538 inlägg
Som jag ser det så tycker jag att det kan vara ett av två fel:
Antingen så genererar dina mysql frågor inga träffar, och då returneras ingen array. Medan du håller på att peta i koden för att få den att funka tycker jag du borde slänga bort alla @ framför mysql_query() och lägga till or die(mysql_error()) bakom denne.
Istället för:
$result = @mysql_query("select foo from bar");
så kör såhär:
$result = mysql_query("select foo from bar") or die(mysql_error());
så att du får lite bättre felmeddelanden.
Det enda andra som jag kan tänka mig strular till det är att mysql_fetch_array returnerar en numeriskt indexerad array om man inte säger till den något annat. Och efter att ha studerat hur extract funkar så antar jag att den antingen vill ha en associativ array, eller ha rätt flagga och något prefix att hänga på variablerna.
( Enklast vore ju förstås att bara byta ut alla mysql_fetch_array() mot mysql_fetch_assoc() och som sagt lägga till die(mysql_error()) på alla mysql_query() så att du får reda på vad servern försöker säga dig ;) )
MVH Patrik
Tack för den detaljerade infon, ska genast kolla upp detta. ;)
138 ms totalt · 3 externa anrop · v20260731065814-full.3ab8d573
