startailMedlem sedan sep. 2000155 inlägg Hur får man fram ett negativt unixtime format innan 1970 ?
Tex:
$d = "1936-07-19";
print "strtotime: " . strtotime($d) ."<br />";
print "strtotime and date: " . date("Y-m-d", strtotime($d)) ."<br /><br />";
$d = "-1055714400";
print "strtotime: " . $d ."<br />";
print "strtotime and date: " . date("Y-m-d", $d) ."<br /><br />";
Det första ger -1 och det andra ger 1936-07-19.
Hur får man om 1936-07-19 till ett negativt unixtime format ?
Vore väldigt tacksam för ett svar.
startailMedlem sedan sep. 2000155 inlägg Lösning på problemet med negativa unixtider kan lösas med...
function maketime ($hour = false, $minute = false, $second = false, $month = false, $date = false, $year = false)
// For centuries, the Egyptians used a (12 * 30 + 5)-day calendar
// The Greek began using leap-years in around 400 BC
// Ceasar adjusted the Roman calendar to start with Januari rather than March
// All knowledge was passed on by the Arabians, who showed an error in leaping
// In 1232 Sacrobosco (Eng.) calculated the error at 1 day per 288 years
// In 1582, Pope Gregory XIII removed 10 days (Oct 15-24) to partially undo the
// error, and he instituted the 400-year-exception in the 100-year-exception,
// (notice 400 rather than 288 years) to undo the rest of the error
// From about 2044, spring will again coincide with the tropic of Cancer
// Around 4100, the calendar will need some adjusting again
if ($hour === false) $hour = Date ("G");
if ($minute === false) $minute = Date ("i");
if ($second === false) $second = Date ("s");
if ($month === false) $month = Date ("n");
if ($date === false) $date = Date ("j");
if ($year === false) $year = Date ("Y");
if ($year >= 1970) return mktime ($hour, $minute, $second, $month, $date, $year);
// date before 1-1-1970 (Win32 Fix)
$m_days = Array (31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31);
if ($year % 4 == 0 && ($year % 100 > 0 || $year % 400 == 0))
$m_days[1] = 29; // non leap-years can be: 1700, 1800, 1900, 2100, etc.
$d_year = 1970 - $year;
$days = 0 - $d_year * 365 - 1;
elseif ($year % 4 == 3 && ($year % 100 > 0 || $year % 400 == 0))
else {
// go backward (-), based on $year
$days = 0 - $d_year * 365;
$days -= floor ($d_year / 4); // compensate for leap-years
$days += floor (($d_year - 70) / 100); // compensate for non-leap-years
$days -= floor (($d_year - 370) / 400); // compensate again for giant leap-years
// go forward (+), based on $month and $date
for ($i = 1; $i < $month; $i++)
$days += $m_days [$i - 1];
$days += $date - 1;
// go forward (+) based on $hour, $minute and $second
$stamp = $days * 86400;
$stamp += $hour * 3600;
$stamp += $minute * 60;
$stamp += $second;
return $stamp;
