Klickräknare!
PHPur PHP
1 svar · 294 visningar · startad av cindra
Medlem sedan juli 200416 inlägg
Gokväll!
Jag har hämtat hem ett script som räknar antalet klick på mina länkar. Allting funkar perfekt men jag vill att man ska kunna se resultatet på min sida o inte bara i databasen.
Hur ska jag skriva för att antalet klick ska visas på sidan?
Skriptet ser ut såhär:
<?php
### --- ID: go.php :: 24/05/2002 --- ###
### --- Outgoing Links counter (uses PHP and MySQL) --- ###
### --- Made for Juicystudio Techmail --- ###
### Define variables
$yoursite = "http://www.yoursite.com/";
### Define database values
$dbhost = "";          // database host
$dbuser = "";          // database username
$dbpassword = "";      // database password
$db2use = "";          // name of database
<?php
### --- NO CHANGES BELOW THIS LINE --- ###
function dbconnect()
    global $dbhost, $dbuser, $dbpassword, $db2use;
    $link = @mysql_connect($dbhost,$dbuser,$dbpassword)
        or die("Connection failed: Please try later.");
    @mysql_select_db($db2use,$link)
        or die("Connection to database refused: Please try later.");
    return $link;
// Connect to database
dbconnect();
if (!empty($site))
    $qry = "SELECT hits FROM url_redirect WHERE site = '$site'"
    $hitcounter = mysql_query($qry);
    $hitcount = mysql_fetch_array($hitcounter);
    $hits = $hitcount[0];
    // next check if URL is in database
    if ($hits == 0)
        //  if not then add it!
        $newurl = "INSERT INTO url_redirect (site,hits) VALUES('$site',1)";
        // Site already exists so just update the hit count
        $newurl = "UPDATE url_redirect SET hits=$hits+1 WHERE site='$site'";
    mysql_query($newurl);
    mysql_close();
    // re-direct to the required site as defined
    // in the "go.php?site" link
    header ("Location: $site");
    exit;
    // site variable not entered, so redirect back to
    // "yoursite" as defined above
    header ("Location: $yoursite");
    exit;
$antal = "SELECT hits FROM url_redirect WHERE site = 'sidansnamn'"
136 ms totalt · 3 externa anrop · v20260731065814-full.4bcf49fe
