LAME (mp3-encoder) syntax
1 svar · 212 visningar · startad av Prime_66
Prime_66Medlem sedan aug. 2004290 inlägg
Does anyone know how to put a converted file into another folder than the default(same as the original song is in)? I think it should be possible to tell LAME where it should put the converted file.
HansenMedlem sedan aug. 2000374 inlägg
Har du läst hjälpen?
mundus:~ chansen$ lame --help
LAME version 3.95  ([url]http://www.mp3dev.org/[/url])
usage: lame [options] <infile> [outfile]
    <infile> and/or <outfile> can be "-", which means stdin/stdout.
RECOMMENDED:
    lame -h input.wav output.mp3
OPTIONS:
    -b bitrate      set the bitrate, default 128 kbps
    -f              fast mode (lower quality)
    -h              higher quality, but a little slower.  Recommended.
    -m mode         (s)tereo, (j)oint, (m)ono
                    default is (j) or (s) depending on bitrate
    -V n            quality setting for VBR.  default n=4
    --preset type   type must be "medium", "standard", "extreme", "insane",
                    or a value for an average desired bitrate and depending
                    on the value specified, appropriate quality settings will
                    be used.
                    "--preset help" gives more info on these
    --longhelp      full list of options
