Gästboksproblem
Webbutvecklingur Perl, Python, Ruby och övrig CGI
4 svar · 458 visningar · startad av GrAnD
GrAnDMedlem sedan juni 200119 inlägg
Jag har ett problem angående en gästbok.
Den vill inte skapa en "post" en websida som jag har skapat.
Method Not Allowed
The requested method POST is not allowed for the URL /hemsida/cgi-bin/guestbook.bat.
Apache/1.3.20 Server at www.****.com Port 80
Vidare info är källkoden.
_______________________________
#!/usr/bin/perl
# Set Variables #
$guestbookurl = "/localhost/guestbook/guestbook.html";
$guestbookreal = "/localhost/hemsida/guestbook/guestbook.html";
$guestlog = "/localhost/hemsida/guestbook/guestlog.html";
$cgiurl = "http://www.icst.com/cgi-bin/guestbook.pl";
$date_command = "/usr/bin/date";
# Set Your Options:
$mail = 0; # 1 = Yes; 0 = No
$uselog = 1; # 1 = Yes; 0 = No
$linkmail = 1; # 1 = Yes; 0 = No
$separator = 1; # 1 = <hr>; 0 = <p>
$redirection = 0; # 1 = Yes; 0 = No
$entry_order = 1; # 1 = Newest entries added first;
# 0 = Newest Entries added last.
$remote_mail = 0; # 1 = Yes; 0 = No
$allow_html = 1; # 1 = Yes; 0 = No
$line_breaks = 0; # 1 = Yes; 0 = No
# If you answered 1 to $mail or $remote_mail you will need to fill out
# these variables below:
$mailprog = '/usr/sbin/sendmail';
$recipient = 'you\@icst.com';
# Done
# Get the Date for Entry
$date = `$date_command +"%A, %B %d, %Y at %T (%Z)"`; chop($date);
$shortdate = `$date_command +"%D %T %Z"`; chop($shortdate);
# Get the input
read(STDIN, $buffer, $ENV{'CONTENT_LENGTH'});
# Split the name-value pairs
@pairs = split(/&/, $buffer);
foreach $pair (@pairs) {
($name, $value) = split(/=/, $pair);
# Un-Webify plus signs and %-encoding
$value =~ tr/+/ /;
$value =~ s/%([a-fA-F0-9][a-fA-F0-9])/pack("C", hex($1))/eg;
$value =~ s/<!--(.|\n)*-->//g;
if ($allow_html != 1) {
$value =~ s/<([^>]|\n)*>//g;
$FORM{$name} = $value;
# Print the Blank Response Subroutines
&no_comments unless $FORM{'comments'};
&no_name unless $FORM{'realname'};
# Begin the Editing of the Guestbook File
open (FILE,"$guestbookreal") || die "Can't Open $guestbookreal: $!\n";
@LINES=<FILE>;
close(FILE);
$SIZE=@LINES;
# Open Link File to Output
open (GUEST,">$guestbookreal") || die "Can't Open $guestbookreal: $!\n";
for ($i=0;$i<=$SIZE;$i++) {
$_=$LINES[$i];
if (/<!--begin-->/) {
  if ($entry_order eq '1') {
     print GUEST "\<!--begin--\>\\n";
  if ($line_breaks == 1) {
     $FORM{'comments'} =\~ s/\\cM\\n/\<br\>\\n/g;
  print GUEST "\<b\>$FORM{'comments'}\</b\>\<br\>\\n";
  if ($FORM{'url'}) {
     print GUEST "\<a href=\\"$FORM{'url'}\\"\>$FORM{'realname'}\</a\>";
  else {
     print GUEST "$FORM{'realname'}";
  if ( $FORM{'username'} ){
     if ($linkmail eq '1') {
        print GUEST " \<\<a href=\\"mailto:$FORM{'username'}\\"\>";
        print GUEST "$FORM{'username'}\</a\>\>";
     else {
        print GUEST " \<$FORM{'username'}\>";
  print GUEST "\<br\>\\n";
  if ( $FORM{'city'} ){
     print GUEST "$FORM{'city'},";
  if ( $FORM{'state'} ){
     print GUEST " $FORM{'state'}";
  if ( $FORM{'country'} ){
     print GUEST " $FORM{'country'}";
  if ($separator eq '1') {
     print GUEST " - $date\<hr\>\\n\\n";
  else {
     print GUEST " - $date\<p\>\\n\\n";
  if ($entry_order eq '0') {
else {
print GUEST $_;
close (GUEST);
# Log The Entry
if ($uselog eq '1') {
&log('entry');
# Options
# Mail Option
if ($mail eq '1') {
open (MAIL, "|$mailprog $recipient") || die "Can't open $mailprog!\n";
print MAIL "Reply-to: $FORM{'username'} ($FORM{'realname'})\n";
print MAIL "From: $FORM{'username'} ($FORM{'realname'})\n";
print MAIL "Subject: Entry to Guestbook\n\n";
print MAIL "You have a new entry in your guestbook:\n\n";
print MAIL "------------------------------------------------------\n";
print MAIL "$FORM{'comments'}\n";
print MAIL "$FORM{'realname'}";
print MAIL " <$FORM{'username'}>";
print MAIL "\n";
print MAIL "$FORM{'city'},";
print MAIL " $FORM{'state'}";
print MAIL " $FORM{'country'}";
print MAIL " - $date\n";
close (MAIL);
if ($remote_mail eq '1' && $FORM{'username'}) {
open (MAIL, "|$mailprog -t") || die "Can't open $mailprog!\n";
print MAIL "To: $FORM{'username'}\n";
print MAIL "From: $recipient\n";
print MAIL "Thank you for adding to my guestbook.\n\n";
print MAIL "\n";
close (MAIL);
# Print Out Initial Output Location Heading
if ($redirection eq '1') {
print "Location: $guestbookurl\n\n";
else {
&no_redirection;
# Subroutines
sub no_comments {
print "Content-type: text/html\n\n";
print "<html><head><title>No Comments</title></head>\n";
print "<body><h1>Your Comments appear to be blank</h1>\n";
print "The comment section in the guestbook fillout form appears\n";
print "to be blank and therefore the Guestbook Addition was not\n";
print "added. Please enter your comments below.<p>\n";
print "<form method=POST action=\"$cgiurl\">\n";
print "Your Name:<input type=text name=\"realname\" size=30 ";
print "value=\"$FORM{'realname'}\"><br>\n";
print "E-Mail: <input type=text name=\"username\"";
print "value=\"$FORM{'username'}\" size=40><br>\n";
print "City: <input type=text name=\"city\" value=\"$FORM{'city'}\" ";
print "size=15>, State: <input type=text name=\"state\" ";
print "value=\"$FORM{'state'}\" size=15> Country: <input type=text ";
print "name=\"country\" value=\"$FORM{'country'}\" size=15><p>\n";
print "Comments:<br>\n";
print "<textarea name=\"comments\" COLS=60 ROWS=4></textarea><p>\n";
print "<input type=submit> * <input type=reset></form><hr>\n";
print "Return to the <a href=\"$guestbookurl\">Guestbook</a>.";
print "\n</body></html>\n";
# Log The Error
&log('no_comments');
exit;
sub no_name {
print "<html><head><title>No Name</title></head>\n";
print "<body><h1>Your Name appears to be blank</h1>\n";
print "The Name Section in the guestbook fillout form appears to\n";
print "be blank and therefore your entry to the guestbook was not\n";
print "added. Please add your name in the blank below.<p>\n";
print "Your Name:<input type=text name=\"realname\" size=30><br>\n";
print " value=\"$FORM{'username'}\" size=40><br>\n";
print "value=\"$FORM{'state'}\" size=2> Country: <input type=text ";
print "value= name=\"country\" value=\"$FORM{'country'}\" ";
print "size=15><p>\n";
print "Comments have been retained.<p>\n";
print "<input type=hidden name=\"comments\" ";
print "value=\"$FORM{'comments'}\">\n";
print "<input type=submit> * <input type=reset><hr>\n";
# Log The Error
&log('no_name');
exit;
# Log the Entry or Error
sub log {
$log_type = $_[0];
open (LOG, ">>$guestlog");
if ($log_type eq 'entry') {
print LOG "$ENV{'REMOTE_HOST'} - [$shortdate]<br>\n";
elsif ($log_type eq 'no_name') {
print LOG "$ENV{'REMOTE_HOST'} - [$shortdate] - ERR: No Name<br>\n";
elsif ($log_type eq 'no_comments') {
print LOG "$ENV{'REMOTE_HOST'} - [$shortdate] - ERR: No ";
print LOG "Comments<br>\n";
# Redirection Option
sub no_redirection {
# Print Beginning of HTML
print "Content-Type: text/html\n\n";
print "<html><head><title>Thank You</title></head>\n";
print "<body><h1>Thank You For Signing The Guestbook</h1>\n";
# Print Response
print "Thank you for filling in the guestbook. Your entry has\n";
print "been added to the guestbook.<hr>\n";
print "Here is what you submitted:<p>\n";
print "<b>$FORM{'comments'}</b><br>\n";
if ($FORM{'url'}) {
print "<a href=\"$FORM{'url'}\">$FORM{'realname'}</a>";
else {
print "$FORM{'realname'}";
print " <<a href=\"mailto:$FORM{'username'}\">";
print "$FORM{'username'}</a>>";
else {
print " <$FORM{'username'}>";
print "<br>\n";
print "$FORM{'city'},";
print " $FORM{'state'}";
print " $FORM{'country'}";
print " - $date<p>\n";
# Print End of HTML
print "<hr>\n";
print "<a href=\"$guestbookurl\">Back to the Guestbook</a>\n"; print "- You may need to reload it when you get there to see your\n";
print "entry.\n";
print "</body></html>\n";
exit;
Frågan är om jag inte har configurerat Apache rätt så den änvänder sig av CGI??
HansenMedlem sedan aug. 2000374 inlägg
Har du satt exekverings rättigheter på guestbook.bat?
Om du försöker köra detta script på www.icst.com (Server: Microsoft-IIS/4.0) så måste du ha portade program för sendmail och date.
Hansen
c.h@ngmedia.com
Du menar chmodda den till 755?
Jag har försökt. Men eftersom jag inte är helt hundra på hur jag gör så har jag inte lyckats.
Adressen www.icst.com är inte det företag jag fixar hemsidan till. Det är en fiktiv adress bara för att få saker och funka =). Som det inte gör för tillfället.
Scriptet har jag fått av en kompis, så jag har inte så jäkla hundra på hur det funkar.
Portade? menar du ha länkat dem till program, lr att jag har program som fixar fram värdena?
Jag kör juh apache som localhost för att testa scriptet därigenom.
Kanske skall berätta oxå att jag kör Apache för windows. Windows Me.
138 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
129 ms — hämta forumlista (db)
