AutoRank
13 svar · 636 visningar · startad av costodia
costodiaMedlem sedan aug. 2000864 inlägg
jag håller på att installera programmet autorank på min server.
Dock får jag upp detta felmeddelande:
CGI Error
The specified CGI application misbehaved by not returning a complete set of HTTP headers. The headers it did return are:
Can't locate cgiworks.pm in @INC (@INC contains: d:/clients/costodia.com/scripts/autorank/data C:/Perl/lib C:/Perl/site/lib .) at d:\clients\costodia.com\scripts\autorank\setup.cgi line 13.
BEGIN failed--compilation aborted at d:\clients\costodia.com\scripts\autorank\setup.cgi line 13.
när jag ska kolla på
http://www.costodia.com/scripts/autorank/setup.cgi
Tack på förhand
Mvh Martin Persson
www.Costodia.com
sgtpepperMedlem sedan apr. 20007 588 inlägg
Scriptet hittar inte modulen cgiworks.pm, antingen så har du inte installerat denna, eller så har du inte lagt in den på rätt sökväg.
° 4711 - the number of the geek °
Tack för ditt snabba svar,
jag är helt ny på cgi-script (förskte hitta ett toppliste-script i asp men utan resultat)
Vet du om det finns någon bra svenska intruduktion till cgi?
Jag förstod det som att .pm filen skulel ligga i samma katalog som cgi-filerna, det står så här i faqen:
NOTICE: These instructions are for a NT installation. If you are installing the software on an Unix server, please see the install.html documentation file included with AutoRank.
At this point it is assumed you have extracted the archive containing AutoRank. If you have not yet done so you should do that now.
You will now need to login to your server and create some directories for AutoRank. First off, decide where you want the .cgi files installed. Generally it is a good idea to keep them in a cgi-bin (or equivalent) directory. Once you have decided where you want the .cgi files, change into that directory. Inside that directory you will need to create 2 subdirectories, one named templates and one named data.
Now, you need to decide where you want the HTML files written to. This will need to be outside of the cgi-bin directory. Once you have decided where you want them to go, record that information as you will need it later.
Example Directory Structure:
c:/home/username/cgi-bin/autorank location of .cgi and .pm files
c:/home/username/cgi-bin/autorank/data location of script data files
c:/home/username/cgi-bin/autorank/templates location of all template files
c:/home/username/public_html/autorank where the main HTML files will be generated
Next, you need to edit a few of the .cgi and .pm files to reflect your server configuration. In each of the files listed below, you will need to set the full path to certain directories. Each is explained.
cgiworks.pm
$DDIR = './data';
Change this to the full path to your data directory
$TDIR = './templates';
Change this to the full path to your templates directory
$OPSYS = 'UNIX';
Change this to NT
out.cgi
$DDIR = './data';
rankem.cgi
$DDIR = './data';
accounts.cgi, setup.cgi, ar.cgi
use lib '.';
Change this (the .) to the full path to where cgiworks.pm is located
In each of the above, you should only change the value inside the quotes. Also, you should ALWAYS use / in your directory paths, and not \ as Windows normally does. Using \ will NOT work. As an example, if your data directory is located at d:\web\yoursite\cgi-bin\data, then in cgiworks.pm you would have:
$DDIR = 'd:/web/yoursite/cgi-bin/data';
In most cases, these are all the changes you will need to make to the scripts. However, some server configurations will require one additional change to each script. If you cannot get the scripts to run, and they complain about not being able to find a file in @INC, then you will need to uncomment the following line in ALL of the .pm and .cgi files:
push(@INC, 'c:/full/path/to/cgi/scripts');
Just remove the # in front of that, then change the c:/full/path/to/cgi/scripts to the full path on your server to where you will be uploading the .cgi and .pm files.
Now you are ready to begin uploading the files to your server. VERY IMPORTANT: You must upload ALL of the AutoRank files in ASCII mode, or it will not function properly. If you are not sure how to do this, consult the documentation for your FTP client.
Place all of the .cgi and .pm files in the base directory you decided to install the script to. Next, place all of the .htmlt files in the templates directory you created. Finally, upload errors.dat, header.txt and footer.txt to the data directory you created.
You are now ready to begin the WWW based portion of the setup. In your browser, type in the full URL to the setup.cgi file on your server. This will bring up the portion of the script where you will set all of the variables. Details and examples for each variable are given, so follow along through that to get all of the variables set properly.
After you have set all of the variables, enter the default password admin and click the button. If everything went well, you will be presented with a page telling you that the variables have been recorded, and some self tests will be done by the script. If all the tests pass, you are ready to go on. If any of them fail, you will need to check file permissions and directory settings.
You should now be ready to begin using the scripts. The first thing you will want to do is create the ranking page on your server. This should be done by using the rerank.cgi script.
After Installation Is Complete
Once you have completed the installation you will want to get the list setup and ready to accept new members. Here we will outline the steps you will want to take immediately following the installation.
The first thing you will want to do is setup the HTML for your list page. This is done by editing the header and footer files in the data directory.
Editing the header/footer
Editing the header and footer for each of your list pages will setup the HTML that appears above and below the rankings. All HTML entered in header.txt will appear above the list; all HTML entered the footer.txt will appear below the list. Any HTML you want can be entered here. Typically your header will contain the opening html, title, and body tags, as well as links to accounts.cgi so that webmasters can add their sites to your list.
Make sure you look over the sample header.txt and footer.txt included with the software before you begin making changes. This will give you an idea of what you will need to have in the header and footer files for your list to function.
The next thing you will probably want to do is edit the templates for the accounts.cgi script. These are all located in the templates directory, and can be edited with any HTML editor. Each of the files contains normal HTML, and special items that the script recognizes. The special values that the script understands are surrounded by #%%#. You should never edit those values; you can move them around all you want, but don't change anything between the #%%#. Complete descriptions of each of the templates can be found on templates.html which is included with the software distribution.
Tack på förhand
Mvh Martin Persson
www.Costodia.com
Och jag kom fram till att alla cgifilerna skulle ligga i d:/clients/costodia.com/scripts/autorank/
Tack på förhand
Mvh Martin Persson
www.Costodia.com
Om du har satt alla sökvägar rätt enligt dokumentationen så kan du ju försöka dig på detta:
...If you cannot get the scripts to run, and they complain about not being able to find a file in @INC, then you will need to uncomment the following line in ALL of the .pm and .cgi files:
I ditt fall så skall det se ut så här:
push(@INC, 'd:/clients/costodia.com/scripts/autorank');
[Redigerat av sgtpepper den 05 sep 2000]
Tyvärr får jag inte det att funka,
jag har inte så mycket pengar, men om du vill så kan du få bli delägare i Costodia mot att du installerar scriptet.
Om du vill det är jag evigt tacksam,
Tack på förhand
Mvh Martin Persson
www.Costodia.com
Inte behöver du pröjsa för att få hjälp, det är det webForum är till för! (För hjälp vill säga, inte rent konsultarbete för då vill det till riktiga pengar :))
Vart hittar jag scriptet? Lägg in en länk här så att jag kan tanka ned det och kolla på det/installera det så återkommer jag med tips.
http://www.cgi-works.net/scripts/autorank/
är adressen,
Mvh Martin Persson
www.Costodia.com
[Redigerat av costodia den 06 sep 2000]
Har du följt instruktionerna till punkt och pricka? Alla sökvägar måste vara absoluta när du kör NT enligt dokumentationen.
cgiworks.pm
$DDIR = './data';
$OPSYS = 'UNIX';
Change this to NT
out.cgi
$DDIR = './data';
rankem.cgi
$DDIR = './data';
use lib '.';
Har du gjort dessa ändringar så att det ser ut så här:
cgiworks.pm
$DDIR = 'd:/clients/costodia.com/scripts/autorank/data';
$TDIR = 'd:/clients/costodia.com/scripts/autorank/templates';
$OPSYS = 'NT';
out.cgi
rankem.cgi
use lib 'd:/clients/costodia.com/scripts/autorank';
tack så hemskt mycket för hjälpen,
Men nu komemr det ett nytt felmeddelande på http://www.costodia.com/autorank/setup.cgi nämligen att:
CGI Error
Can't open perl script "d:\clients\costodia.com\wwwroot\autorank\setup.cgi": No such file or directory
Jag fattar liksom inte det setup.cgi ska ju inte ligga i wwwroot, eller?
Tack på förhand
Mvh Martin Persson
www.Costodia.com
Det där felet betyder helt enkelt att perl-motorn inte kan hitta filen setup.cgi.
Har du flyttat cgi-filerna till någon annan katalog eller?
Jo... Visst ska den det, om den ligger utanför wwwroot så är filen ju inte åtkomlig via webbservern.
tack så mycket nu fick jag det att funka så att de syns i webläsaren.
jag är evigt tacksam, vill du ha en länk från costodia så säg bara till.
Mvh Martin Persson
www.Costodia.com
[Redigerat av costodia den 07 sep 2000]
f
Tack på förhand
Mvh Martin Persson
www.Costodia.com
Bra! Ibland kan det vara knepigt att installera Perl-script, men oftast är det enkla fel.
137 ms totalt · 3 externa anrop · v20260731065814-full.0e50b1ef
