Gästbok
2 svar · 432 visningar · startad av Kent
KentMedlem sedan juli 2000355 inlägg
Detta är koden till min gästbok,
vil nu ha så att var det max får vara 25 inlägg per sida, sedan ska sidorna delas upp,
Sida 1 2 3 4
typ som dom har på alxook.com.
Hur ser koden ut för detta.
#!/usr/bin/perl
$lock="2";
$unlock="8";
$forminfo=$ENV{'QUERY_STRING'};
$forminfo=~tr/+/ /;
$forminfo=~s/%(..)/pack("c",hex($1))/ge;
@par=split(/&/,$forminfo);
foreach $a (@par){
($ruta, $text)=split(/=/,$a);
$INFO{$ruta}=$text;
$INFO{'namn'}=~/[;<>\*\|´&\$!#\(\)\[\]\{\}:'"]/;
$INFO{'kommentar'}=~/[;<>\*\|´&\$!#\(\)\[\]\{\}:'"]/;
$INFO{'stad'}=~/[;<>\*\|´&\$!#\(\)\[\]\{\}:'"]/;
$INFO{'epost'}=~/^[\w-.]+\@[\w.]+$/;
if($INFO{'namn'} ne "" &#0124; &#0124; $INFO{'epost'} ne "" &#0124; &#0124; $INFO{'hemstad'} ne "" &#0124; &#0124; $INFO{'kommentar'} ne ""){
&registrera_kommentar;
&skriva_gastlista;
print "Content-type: text/html\n\n";
print "<html><head><title>Gästbok</title></head>";
print "<body bgcolor=\"#FFFFFF\" text=\"#000000\" link=\"#0000FF\" vlink=\"#0000FF\">";
print "<center><img src=$loggan></center><center><small><br>";
print "<b><br></center></small>";
print "<STYLE>A {text-decoration:none} A:hover{text-decoration:underline} </STYLE></p>";
print "<div align=\"center\"><center><table border=\"0\" width=\"400\">    <tr>";
print "<td width=\"100%\"><p align=\"center\"></p>        </td>    </tr></table></center></div>";
print "<form action=\"gastbok.pl\" method=\"get\">";
print "<div align=\"center\"><center><table border=\"0\" cellpadding=\"4\"    cellspacing=\"4\">";
print "<tr><td align=\"right\"><font color=\"#000000\">";
print "<strong>Namn:</strong></font></td>";
print "<td><input type=\"text\" size=\"30\" maxlength=\"40\" name=\"namn\"></td>";
print "</tr><tr><td align=\"right\"><p align=\"right\"><font color=\"#000000\"><strong>E-post: </strong></font></p>";
print "</td><td><input type=\"text\" size=\"30\" maxlength=\"40\" name=\"epost\"></td>";
print "</tr><tr><td align=\"right\"><p align=\"right\"><font color=\"#000000\"><strong>Hemstad: </strong></font></p>";
print "</td><td><input type=\"text\" size=\"30\" maxlength=\"40\"  name=\"hemstad\"></td></tr><tr><td align=\"right\" valign=\"top\">";
print "<p align=\"center\"><font color=\"#000000\"><strong>Kommentar:</strong></font></p></td><td valign=\"top\"><p align=\"right\">";
print "<textarea name=\"kommentar\" rows=\"4\" cols=\"30\" maxlength=\"100\"></textarea><br>";
print "<input type=\"submit\" value=\"Sänd\"> <input type=\"reset\" value=\"Rensa\"></p></td></tr><tr><td>";
print "</td></tr></table></center></div></form>";
print "</body></html>";
sub skriva_gastlista{
$k=0;
flock(TEXT,$lock);
open (TEXT,"$boktext");
while ($rad=<TEXT> ){
$k++;
$rad=~/(.*)::(.*)::(.*)::(.*)::(.*)::(.*)::(.*)::(.*)/;
$INFO1[$k]=$1;
$INFO2[$k]=$2;
$INFO3[$k]=$3;
$INFO4[$k]=$4;
$INFO5[$k]=$5;
$INFO6[$k]=$6;
$INFO7[$k]=$7;
$INFO8[$k]=$8;
close (TEXT);
flock(TEXT,$unlock);
flock(TEXT,$lock);
$kommentarer=0;
@filen=<TEXT>;
foreach $rad (@filen){
$kommentarer++;
close (TEXT);
$nr=0;
while ($k ne 0){
$SORT1[$nr]=$INFO1[$k];
$SORT2[$nr]=$INFO2[$k];
$SORT3[$nr]=$INFO3[$k];
$SORT4[$nr]=$INFO4[$k];
$SORT5[$nr]=$INFO5[$k];
$SORT6[$nr]=$INFO6[$k];
$SORT7[$nr]=$INFO7[$k];
$SORT8[$nr]=$INFO8[$k];
$nr++;
$k--;
print "<center><table border=\"0\" width=\"400\"><TR><TD>";
$nr=0;
while ($nr ne 25){
if($nr eq $kommentarer){
&raknare;
exit;
print "<hr>";
		if($SORT3[$nr] ne "tomt")
                print  "<b><a href=\"mailto:$SORT3[$nr]\">$SORT2[$nr]</A></b> <small><i>  ($SORT7[$nr])</i> <br>\n";
               print  "<b>$SORT2[$nr]</b> <small><i>($SORT7[$nr])</i><br>\n";
		print  "$SORT5[$nr]</b><p>\n";
		if($SORT4[$nr] ne "")
		print  "$SORT4[$nr], $SORT8[$nr] - $SORT1[$nr]</small><br>";
                print  "$SORT8[$nr] - $SORT1[$nr]</small><br>";
$nr++;
if($nr eq 10){
&raknare;
print "</TD></TR></TABLE>";
exit;
sub raknare{
flock(RAKNARE,$lock);
open (RAKNARE,"$boknr");
while ($rad=<RAKNARE> ){
$rad=~/(.*)::(.*)/;
$besokare[1]=$1;
$kommentar[1]=$2;
close (RAKNARE);
flock(RAKNARE,$unlock);
$besokare[1]++;
open (RAKNARE,">$boknr");
print RAKNARE "$besokare[1]::$kommentar[1]";
close (RAKNARE);
print "<hr><p><small><center>Du är besökare nr: <b>$besokare[1]</b> på denna sida!";
print "<STYLE>A {text-decoration:none} A:hover{text-decoration:underline} </STYLE>";
exit;
sub registrera_kommentar{
if($INFO{'namn'} eq "" &#0124; &#0124;$INFO{'kommentar'} eq "")
print "<body bgcolor=\"white\" text=\"black\">";
print "<p><left><b><h3>";
print "Namn och kommentar är obligatoriska uppgifter!<br>";
print "Backa med din browser och fyll i glömd uppgift!";
print "</left></h3></b>";
exit;
if($INFO{'epost'}=~/[;<>\*\`&\$!#\(\)\[\]\{\}:'"]/)
print "Din epost innehåller ett felaktigt tecken!<br>";
print "Backa med din browser och korrigera uppgiften!";
exit;
if($INFO{'epost'} eq "")
$INFO{'epost'}="tomt";
print "<meta http-equiv=\"Refresh\" content=\"2; URL=$gastbok\">";
print "Tack för din kommentar, $INFO{'namn'}!<br>";
print "Du kommer inom kort att förflyttas till gästboken.<br>Om ditt inlägg inte syns, så uppdatera sidan.";
$INFO{'namn'} =~ s/</\&lt\;/g;
$INFO{'namn'} =~ s/</\&gt\;/g;
$INFO{'hemstad'} =~ s/</\&lt\;/g;
$INFO{'hemstad'} =~ s/</\&gt\;/g;
$INFO{'kommentar'} =~ s/</\&lt\;/g;
$INFO{'kommentar'} =~ s/</\&gt\;/g;
$INFO{'kommentar'}=~s/\n/<br>/g;
@dagar = ("Söndag","Måndag","Tisdag","Onsdag","Torsdag","Fredag","Lördag");
@manader = ("Januari","Februari","Mars","April","Maj","Juni","Juli","Augusti","September","Oktober","November","December");
@tid = localtime(time);
if ($tid[3] > 2){
$tid[3] = $tid[3].":e";
}else{
$tid[3] = $tid[3].":a";
if ($tid[0] < 10){
$tid[0] = "0".$tid[0];
if ($tid[1] < 10){
$tid[1] = "0".$tid[1];
if ($tid[2] < 10){
$tid[5]=$tid[5]+1900;
$datum=  "$dagar[$tid[6]]en den $tid[3] $manader[$tid[4]] $tid[5]";
flock(FILE,$lock);
open(FILE,"$ord");
@censur=<FILE>;
close FILE;
flock(FILE,$unlock);
map {
chomp;
$replace = '*' x length($_);
$INFO{'namn'} =~ s/$_/$replace/gi;
$INFO{'epost'} =~ s/$_/$replace/gi;
$INFO{'hemstad'} =~ s/$_/$replace/gi;
$INFO{'kommentar'} =~ s/$_/$replace/gi;
@censur;
@kontroll = ('::');
map {
$replace = '*' x length($_); # Här är det du söker.
@kontroll;
$rad=~/(.*)::(.*)/;
$besokare[1]=$1;
$kommentar[1]=$2;
close (RAKNARE);
$kommentar[1]++;
close (RAKNARE);
flock(LOGG,$lock);
open (LOGG,">>$boktext");
print LOGG "$kommentar[1]::$INFO{'namn'}::$INFO{'epost'}::$INFO{'hemstad'}::$INFO{'kommentar'}::$INFO{'R1'}::$ENV{'REMOTE_ADDR'}::$datum\n";
close (LOGG);
flock(LOGG,$unlock);
exit;
Mycket tacksam för svar.
demo
Hej Kent!
Det där scriptet har du väl laddat ned från wF-script :)
Kul att scriptet kom till användning. :)
Vad gäller din fråga, så ställdes en liknande fråga tidigare och jag länkar till den och hoppas att den är dig till hjälp.
Länk till tidigare inlägg: http://cgi.webforum.nu/wf/Forum14/HTML/000156.html
Nu är jag en nybörjare/amatör vad gäller Perl, så det skulle vara intressant och höra vad de mer erfarna perl-programmerarna tycker om koden?
För att få ihop gästboken så ställde jag en del frågor på wf.
Så delar av scriptet bla. censurhanteringen kommer från svarsinlägg i wF.
Men för en perl-amatör vore det kul med lite synpunkter på koden. Vad kan man göra bättre och effektivare m.m.
//Demo
[Redigerat av demo den 19 aug 2000]
Fattar inte riktigt, går det att göra med följande kod:
use POSIX qw(ceil);
$antalsidor=ceil($antalinlagg/$antalpersida);
127 ms totalt · 3 externa anrop · v20260731065814-full.b943c234
