Amxbans prune_db
1 svar · 675 visningar · startad av McD
McDMedlem sedan mars 20002 520 inlägg
Hej vänner...
En kompis till mig håller på att installera amxbans ett SQL baserat banssystem för spelservers. Vi har allt uppe och rullar dock så får vi inte igången fil som ska pruna databasen dvs flytta över tempbans till ett annat ställe i databasen så att de inte längre är aktiva då tiden gått ut... dvs en mycket viktigt funktion i amxbans.
Vi får följande felmeddelande i perl.
DBI connect('dbname=amxbans;host=localhost','tender',...) failed: Client does not support authentication protocol requested by server; consider upgrading MySQL client at C:\move_bans.pl line 86
Can't call method "prepare" on an undefined value at C:\move_bans.pl line 43.
Hela scirptet.
#!/usr/bin/perl
#    AMXBans, managing bans for Half-Life modifications
#    Copyright (C) 2003, 2004  Ronald Renes / Niek Albers
#		web		: [url]http://www.xs4all.nl/~yomama/amxbans/[/url]
#		mail	: [email]yomama@xs4all.nl[/email]
#		ICQ		: 104115504
#		This file is part of AMXBans.
#    AMXBans is free software; you can redistribute it and/or modify
#    it under the terms of the GNU General Public License as published by
#    the Free Software Foundation; either version 2 of the License, or
#    (at your option) any later version.
#    AMXBans is distributed in the hope that it will be useful,
#    but WITHOUT ANY WARRANTY; without even the implied warranty of
#    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#    GNU General Public License for more details.
#    You should have received a copy of the GNU General Public License
#    along with AMXBans; if not, write to the Free Software
#    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
use strict;
use DBI;
my $dsn = {
    host     => 'localhost',
    username => 'tender',
    password => 'amxbanpass'
    database => 'amxbans',
main();
sub main {
    my $dbh = connect_db($dsn);
    my $sth = $dbh->prepare(
        q/ SELECT *
            FROM amx_bans
            WHERE ban_created + ban_length*60 < UNIX_TIMESTAMP()
            AND ban_length != 0 /
    my $rv = $sth->execute();
    while ( my $r = $sth->fetchrow_hashref ) {
        my $sql = q/INSERT INTO amx_banhistory
            (player_ip, player_id,   player_nick,
            admin_ip,  admin_id,    admin_nick,
            ban_type,  ban_reason,  ban_created,   ban_length,
            server_ip, server_name, unban_created, unban_reason,
            unban_admin_nick)
            VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,'Bantime expired','amxbans')/;
        my $sth = $dbh->prepare($sql);
            $r->{player_ip},  $r->{player_id},   $r->{player_nick},
            $r->{admin_ip},   $r->{admin_id},    $r->{admin_nick},
            $r->{ban_type},   $r->{ban_reason},  $r->{ban_created},
            $r->{ban_length}, $r->{server_ip},   $r->{server_name},
            time()
          or die $DBI::errstr;
        $sth = $dbh->prepare(q/DELETE FROM amx_bans WHERE bid = ?/);
        $sth->execute( $r->{bid} );
sub connect_db {
    my ($dsn) = @_;
    my @dsnlist = (
        'dbi:' . 'mysql' . ':dbname=' . $dsn->{database} . ';host=' .
          $dsn->{host},
        $dsn->{username}
    return DBI->connect( @dsnlist, $dsn->{password} ) or die $DBI::errstr;
The system:
Windows 2000
ActivePerl 5.6.1.631
MySQL 5.0.26 (even tried 5.0.21)
Någon som kan ha en aning om vad detta beror på?
Allt har löst sig.
