För i så fall gör så här.
Spara detta i en module.
Option Explicit
Public Declare Function getprivateprofilestring Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationname As String, ByVal lpKeyname As Any, ByVal lpdefault As String, ByVal lpreturnedstring As String, ByVal nSize As Long, ByVal lpFileName As String) As Long
Public Declare Function writeprivateprofilestring Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationname As String, ByVal lpKeyname As Any, ByVal lpString As Any, ByVal lpFileName As String) As Long
Global RealLen As Byte
Global AutoInput As Boolean
Function ReadINI(Section As String, KeyName As String, FileName As String) As String
Dim sRet As String
sRet = String(255, Chr(0))
ReadINI = Left(sRet, getprivateprofilestring(Section, ByVal KeyName$, "", sRet, Len(sRet), FileName))
End Function
Function WriteINI(sSection As String, sKeyName As String, sNewString As String, sFileName) As Integer
Dim r
r = writeprivateprofilestring(sSection, sKeyName, sNewString, sFileName)
End Function
Sen Använder du denna kod till att spara.
Dim Ret
Dim i
j = List1.ListIndex
For i = 0 To List1.ListCount - 1
List1.ListIndex = i
Ret = WriteINI("Tid", List1.ListIndex, List1, App.Path & "\Alarm.ini")
Ret = WriteINI("Medelande", List1.ListIndex, Text1.Text, App.Path & "\Alarm.ini")
Next i
List1.ListIndex = j
Sen Använder du denna kod till att Läsa in data.
Skulle sätta in en listbox där tiden står och sen en text ruta där medelandet är.
Private Sub Form_Load()
strFileName = App.Path & "\Alarm.ini"
intCounters = 0
List1.Clear
Do
strTider = ReadINI("Tid", Str(intCounters), App.Path & "\Alarm.ini")
If strTider = "" Then
Exit Do
Else
List1.AddItem strTider
intCounters = intCounters + 1
Loop
End Sub
Private Sub List1_Click()
On Error GoTo ErrorHand
Text1.Text = ReadINI("Medelande", List1.ListIndex, App.Path & "\Alarm.ini")
Exit Sub
ErrorHand:
MsgBox Error, vbCritical + vbOKOnly
End Sub
Snabb skrivit koden så du får kanske göra om lite men det borde funka att utgå från denna.
Sen i Alarm.ini lägg dit denna text och spara så kan du testa sen.
[Tid]
0=07:00
[Medelande]
0=Vakna
@nders Ska tänka på det Sorry.
