Problem med bool
3 svar · 252 visningar · startad av aleborg
aleborgMedlem sedan jan. 20013 341 inlägg
Jag har följande kod:
		private void Edit_Click(object sender, System.EventArgs e)
			string target;
			bool validpath=false;
			GetUserInfo user = new GetUserInfo();
			user.SelectUserServices(Session["services"].ToString());
			//the full path
			if(txtTarget.Text.Replace("'","").Trim()=="/")
				target = user.Path+@"html";
				target = user.Path+@"html"+txtTarget.Text.Replace("/","\\").Trim();
			//is the path only /
			if(txtTarget.Text=="/")
				validpath = true;
				validpath=false;
				//does the path start with / but don't end with /
				if(txtTarget.Text.StartsWith("/") && !txtTarget.Text.EndsWith("/"))
					//check if the path exists
					DirectoryInfo di = new DirectoryInfo(target);
					if (di.Exists == true)
						validpath = true;
						validpath=false;
						errTBL.Visible = true;
						errDom.Visible = true;
						errDom.Text = "The folder don't exists!";
					validpath=false;
					errDom.Text = "The path cant end with \"/\" but must start with it...";
			if(validpath)
				ServerInfo server = new ServerInfo();
				server.GetServerInfo(user.Server);
				string servername = server.Server_Name;
				IISWebsite site = new IISWebsite();
				site.HomePath = target;
				site.Server = servername;
				site.WebsiteNumber = Request.QueryString["id"].Trim();
				if(site.EditTarget())
					Domains sqlDomain = new Domains();
					sqlDomain.Target = txtTarget.Text.Replace("'","").Trim();
					sqlDomain.UpdateDomain(Request.QueryString["id"]);
					Response.Redirect("tools_domains.aspx?action=edited");
					errDom.Text = "Subdomain couldn't be edited!";
Problemet är att vad jag än anger i txtTarget.Text så anger den validpath=true, även om jag skickar in "/weee/" eller om sökvägen inte finns!
LOL
if(!Page.IsPostBack) är rätt bra att använda i Page_OnLoad :r
Hehe, den har vi nog alla ramlat dit på en eller flera gånger. ;)
japp, jag 2 ggr hittils :e
