Deserializering av object varav en är en IDictionary
.NET
1 svar · 245 visningar · startad av renholm
Kan inte få min deserializering av följande object att fungera, får detta felmeddelande
For non-array types, you may use the following attributes: XmlAttribute, XmlText, XmlElement, or XmlAnyElement.
Stack Trace:
[InvalidOperationException: For non-array types, you may use the following attributes: XmlAttribute, XmlText, XmlElement, or XmlAnyElement.]
System.Xml.Serialization.XmlReflectionImporter.ImportAccessorMapping(MemberMapping accessor, FieldModel model, XmlAttributes a, String ns, Type choiceIdentifierType) +11541
System.Xml.Serialization.XmlReflectionImporter.ImportFieldMapping(StructModel parent, FieldModel model, XmlAttributes a, String ns) +176
System.Xml.Serialization.XmlReflectionImporter.ImportStructLikeMapping(StructModel model, String ns) +1584
[InvalidOperationException: There was an error reflecting property 'Nodes'.]
System.Xml.Serialization.XmlReflectionImporter.ImportStructLikeMapping(StructModel model, String ns) +2340
System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, Boolean repeats) +448
[InvalidOperationException: There was an error reflecting type 'Renholm.Lightweight.Business.Website'.]
System.Xml.Serialization.XmlReflectionImporter.ImportTypeMapping(TypeModel model, String ns, ImportContext context, String dataType, Boolean repeats) +1070
System.Xml.Serialization.XmlReflectionImporter.ImportElement(TypeModel model, XmlRootAttribute root, String defaultNamespace) +168
System.Xml.Serialization.XmlSerializer..ctor(Type type, String defaultNamespace) +227
System.Xml.Serialization.XmlSerializer..ctor(Type type) +27
Renholm.Lightweight.Business.Website.Create(CultureInfo culture) in i:\renholm\lite\business\website.cs:41
Renholm.Lightweight.Business.User.get_Website() in I:\Renholm\Lite\Business\User.cs:19
Renholm.Lightweight.UI.Page.Page_Load(Object sender, EventArgs e) in i:\renholm\lite\ui\page.cs:20
System.EventHandler.Invoke(Object sender, EventArgs e) +0
System.Web.UI.Control.OnLoad(EventArgs e) +67
System.Web.UI.Control.LoadRecursive() +35
System.Web.UI.Page.ProcessRequestMain() +731
Följande kod:
public class Website
		private string title;
		private NodeCollection nodes;
		[XmlAttribute]
		public string Title
			get { return title; }
			set { title = value; }
		[XmlArrayItemAttribute("Node")]
		public NodeCollection Nodes
			get { return nodes; }
			set { nodes = value; }
		public static Website Create(CultureInfo culture)
			string filepath	= ConfigurationSettings.AppSettings["Settings"] + "\\" + culture.Name + "\\Site.xml";
			Website result	= (Website)HttpContext.Current.Cache["Site_" + culture.Name];
			if (result == null)
				using(StreamReader stream = new StreamReader(filepath))
					XmlSerializer xml = new XmlSerializer(typeof(Website));
					result = (Website)xml.Deserialize(stream);
					HttpContext.Current.Cache.Insert("Site_" + culture.Name, result, new CacheDependency(filepath));
			return result;
		public Website()
	public class NodeCollection : DictionaryBase, IXmlSerializable
		public NodeCollection()
		public virtual Node this[string key]
			get { return (Node)Dictionary[key]; }
			set { Dictionary[key] = value; }
		public virtual void Add(string key, Node value)
			Dictionary.Add(key, value);
		public virtual bool Contains(string key)
			return this.Dictionary.Contains(key);
		public virtual bool ContainsKey(string key)
		public virtual bool ContainsValue(Node value)
			foreach (Node item in this.Dictionary.Values)
				if (item == value)
					return true;
			}        return false;
		public virtual void Remove(string key)
			this.Dictionary.Remove(key);
		[XmlIgnore]
		public virtual ICollection Keys
			get { return this.Dictionary.Keys; }
		[XmlIgnore]
		public virtual ICollection Values
			get	{ return this.Dictionary.Values; }
		void IXmlSerializable.WriteXml(System.Xml.XmlWriter w)
			XmlSerializer xml = new XmlSerializer(typeof(Node));
			foreach (string key in Dictionary.Keys)
				Node value = (Node)Dictionary[key];
				xml.Serialize(w, value);
		void IXmlSerializable.ReadXml(System.Xml.XmlReader r)
			r.Read();
			r.ReadStartElement("Nodes");
			while(r.NodeType != System.Xml.XmlNodeType.EndElement)
				Node value = (Node)xml.Deserialize(r);
				Dictionary.Add(value.Id, value);
				r.MoveToContent();
			r.ReadEndElement();
		System.Xml.Schema.XmlSchema IXmlSerializable.GetSchema()
			return null;
public class Node
		private string id;
		private string name;
		private ModuleCollection modules;
		[XmlAttribute]
		public string Id
			get { return id; }
			set { id = value; }
		[XmlElement]
		public string Name
			get { return name; }
			set { name = value; }
		public ModuleCollection Modules
			get { return modules; }
			set { modules = value; }
		public Node()
public class ModuleCollection : CollectionBase
		public void Add(Module item)
			List.Add(item);
		public void Remove(Module item)
			List.Remove(item);
		public Module this[int Index]
			get	{ return (Module)List[Index]; }
			set	{ List[Index] = value; }
		public ModuleCollection()
	public class Module
		private string panel;
		private string control;
		[XmlElement]
		public string Panel
			get { return panel; }
			set { panel = value; }
		[XmlElement]
		public string Control
			get { return control; }
			set { control = value; }
		public Module()
XML filen
<?xml version="1.0" encoding="iso-8859-1" ?>
<Website Title="Test">
	<Nodes>
		<Node Id="start">
			<Name>Startsidan</Name>
			<Nodes>
				<Node Id="undersida">
					<Name>Start Undersidan</Name>
				</Node>
			</Nodes>
		</Node>
	</Nodes>
</Website>
Är inte direkt säker på vad jag gjort i IXmlSerializable.ReadXml(System.Xml.XmlReader r).
red // skickade med xml-filen också
Tror jag löste de problemet genom att ändra [XmlArrayItemAttribute("Node")] på public NodeCollection Nodes till [XmlElement] eftersom jag kom på att NodeCollection inte riktigt räknas som en Array då jag fick ta till en speciall lösning i och med att jag behovde ha NodeCollection som ett Dictionary object.
272 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
128 ms — deklarationer (db)
126 ms — ändringar (db)
