CodeSmith kodgenerator..
7 svar · 216 visningar · startad av Walker
Fick detta felmeddelandet P
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: File or assembly name Microsoft.Data.Odbc, or one of its dependencies, was not found.
File name: "Microsoft.Data.Odbc"
at CodeGenP.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Fusion log follows:
=== Pre-bind state information ===
LOG: DisplayName = Microsoft.Data.Odbc, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
(Fully-specified)
LOG: Appbase = C:\Documents and Settings\Nicke\Desktop\
LOG: Initial PrivatePath = NULL
Calling assembly : CodeGenP, Version=1.0.1200.36070, Culture=neutral, PublicKeyToken=null.
LOG: Publisher policy file is not found.
LOG: Host configuration file not found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\config\machine.config.
LOG: Post-policy reference: Microsoft.Data.Odbc, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
LOG: Attempting download of new URL file:///C:/Documents and Settings/Nicke/Desktop/Microsoft.Data.Odbc.DLL.
LOG: Attempting download of new URL file:///C:/Documents and Settings/Nicke/Desktop/Microsoft.Data.Odbc/Microsoft.Data.Odbc.DLL.
LOG: Attempting download of new URL file:///C:/Documents and Settings/Nicke/Desktop/Microsoft.Data.Odbc.EXE.
LOG: Attempting download of new URL file:///C:/Documents and Settings/Nicke/Desktop/Microsoft.Data.Odbc/Microsoft.Data.Odbc.EXE.
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.3300.0
Win32 Version: 1.0.3705.0
CodeBase: file:///c:/windows/microsoft.net/framework/v1.0.3705/mscorlib.dll
CodeGenP
Assembly Version: 1.0.1200.36070
Win32 Version: 1.0.1200.36070
CodeBase: file:///C:/Documents%20and%20Settings/Nicke/Desktop/CodeGenP.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.3300.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.3300.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.3300.0__b03f5f7f11d50a3a/system.drawing.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
// Redigerat
Upptäckte att man var tvungen att ha MySql
P skrev:
Nepp!
Jag använder CodeGenP
url: p.latmask.com/CodeGenP
Är codegen ditt eget alster eller finns det någon hemsida med mer info?
Gjort själv.. finns i senare versioner om någon skulle vara intresserad ( mitt första winform program! ) :)
Nice..
Hur fungerar det om man har foreign keys i tabellerna, laddar den rätt värde då också, eller laddar den bara nycklen till det den posten i databasen?
foreign keys.. aldrig hört talas om ;) fungerar på strängar/datum/int och lite annat
Har du testat programet? Senste versionen finns på p.latmask.com/CodeGenP/CodeGenP.zip
Foreign keys får du om du har normaliserat databasen.
Sen beror det på om man vill göra ha det så eller inte.
Nope har inte testat det än, använder Codesmith ju :p
Men skall kika på det senare..
