När jag matar in HTML-taggar i ett formulär så får jag följande felmeddelande:
A potentially dangerous Request.Form value was detected from the client (fltText1="<i>i</i>").
Description: Request Validation has detected a potentially dangerous client input value, and processing of the request has been aborted. This value may indicate an attempt to compromise the security of your application, such as a cross-site scripting attack. You can disable request validation by setting validateRequest=false in the Page directive or in the configuration section. However, it is strongly recommended that your application explicitly check all inputs in this case.Exception Details: System.Web.HttpRequestValidationException: A potentially dangerous Request.Form value was detected from the client (fltText1="<i>i</i>").
Jag får det bara på webbhotellet och inte lokalt. Kan det ha nåt med vilken version av .NET man har?
