När jag skapar en usercontrol (*.ascx) i VS.NET så skapar VS denna kod:
[red]
namespace office.left_ascx
using System;
using System.Data;
using System.Drawing;
using System.Web;
using System.Web.UI.WebControls;
using System.Web.UI.HtmlControls;
[b]using Icaaq.Office;[/b]
/// <summary>
/// Summary description for userinfo.
/// </summary>
public abstract class userinfo : System.Web.UI.UserControl
private void Page_Load(object sender, System.EventArgs e)
// Put user code to initialize the page here
#region Web Form Designer generated code
override protected void OnInit(EventArgs e)
// CODEGEN: This call is required by the ASP.NET Web Form Designer.
InitializeComponent();
base.OnInit(e);
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
private void InitializeComponent()
this.Load += new System.EventHandler(this.Page_Load);
#endregion
[/red]
Men hur ska jag skriva för att komma åt funktionerna i Icaaq.Office??
Om jag skriver som jag gjort nu så får jag:
The type or namespace name 'Office' does not exist in the class or namespace 'office.Icaaq' (are you missing an assembly reference?)
Mvh icaaq
