VB 6.0
1 svar · 179 visningar · startad av kaktusen
kaktusenMedlem sedan juni 2002139 inlägg
Försöker installera VB 6.0 men då installationen är klar och jag ska öppna programmet får jag fram följande felmeddelande:
Can´t find file ´DAO350.DLL´
Vad är det för fel?
Engine^Medlem sedan dec. 20003 887 inlägg
Jag vet inte om det här hjälper dig, men det kan vara värt ett försök...
MSDN Developer Community skrev:
Q: We consistently get -Out of Memory- errors on Windows 2000 platforms, running an A97 db, We've checked code and all rs and db variables are being closed and set to nothing, any other ideas?
A: This is a complex problem, and usually due to mismatched dynamic-link library (.dll) files for the versions of Microsoft Office and Microsoft Access installed on your computer. As such, there are many different possibilities for replies.:
Ensure that no version (Microsoft Office 97 or 2000/2002) Small Business Tools have been installed on the same computer. If the Small Business Tools have been installed, you'll want to remove them. For more information, see Q235279.
Ensure that you're using Microsoft Office 97 SR2. You can obtain Microsoft Office 97 SR2 from Q151261. Ensure you have the latest Jet on all computers. For Microsoft Access 97, you need Jet 3.5 SP3, available at Q172733.
Delete all .tmp files; Ensure that TMP and TEMP both point to valid, existing directories; Ensure that the operating system is managing virtual memory; Run setup /y (Access 97) to recreate all registry entries.
You probably want to re-register dao3032.dll and/or dao350.dll as per Q141294 (for Access 97); reregister DAO360.dll. If you are unable to register dao350.dll, you may need to review the other methods of obtaining a good copy of dao350.dll as per Q17726
Rename hatten.ttf on your system (if found) and reinstall, as per Q141373.
Other resources include: Q161329; Q163493; Q217353; Q241141. As a last resort, you may need to remove Microsoft Office 97 and reinstall. Another last-resort type option is to install the operating system to a new folder and then in
För att komma till svaret på t.ex. Q141294 anger du url:en http://support.microsoft.com/default.aspx?scid=KB;en-us;141294
Hoppas det hjälper :)
