specified cast.. dataset + mysql
3 svar · 232 visningar · startad av P
PMedlem sedan jan. 20012 204 inlägg
Har haft lite annat att göra ett tag så har inte kodat så mycket, så när jag satte mig idag så var det ett problem jag fastnad vid...
Felmeddelandet är: Specified cast is not valid.
Kod utdrag från databas klasserna:
Public Class DataAccess
        'Write the database type in web.config: myssql / mysql / access
        Private strCnnDBType As String = ConfigurationSettings.AppSettings("CnnDBType")
        Private strCnnString As String = ConfigurationSettings.AppSettings("CnnString")
        Private strCnnMail as String = ConfigurationSettings.AppSettings("CnnMail") ' True = mail send
        ' Connection properties etc
        Private cmdSqlCommand As IDbCommand
        Private objDataAdapter As IDbDataAdapter
        Private objCnn As IdbConnection
        ' Function for select right DB
        Function setDBType()
            Select Case strCnnDBType
                Case "Mssql"
                    objCnn = New SqlConnection(strCnnString)
                    objDataAdapter = New SqlDataAdapter()
                    cmdSqlCommand = New SqlCommand()
                Case "Mysql"
                    objCnn = New OdbcConnection(strCnnString)
                    objDataAdapter = New OdbcDataAdapter()
                    cmdSqlCommand = New OdbcCommand()
                Case "Access"
                    objCnn = New OledbConnection(strCnnString)
                    objDataAdapter = New OledbDataAdapter()
                    cmdSqlCommand = New OledbCommand()
                Case Else
                    _ThrowError("FEL: Databastypen är felaktig, kontrollera web.config")
            End Select
        End Function
        Function CreateCommand(SqlStatement as String)
            SqlStatement = SqlStatement.Replace("'","")
            Dim SqlCommand as New OdbcCommand(SqlStatement,objCnn)
            Return SqlCommand
        End Function
        '  Return data by a DataSet()
        Function GetDataSet(SqlStatement As String)
            SetDbType()
            Try
                Dim objDataSet as New DataSet()
                objCnn.Open()
                objDataAdapter.SelectCommand = CreateCommand(SqlStatement)
                objDataAdapter.Fill(objDataSet)
                Return objDataSet
            Catch Exp as SqlException
                Throw exp
            Finally
                objCnn.Close()
            End Try
        End Function
och sen i klassen som anropar...
    Public Class bdBook 'CMS BusinessData
        Inherits DataAccess
        Public Function aa()
            Dim strSql as String = "Select * from tbl_admin"
            Return GetDataSet(strSql)
        End Function
    End Class
    Public NotInheritable Class dbBook ' Business Layer
        Public Shared Function Test()
            Dim objData as New bdBook
            Return (objData.aa())
        End Function
    End Class
och sen i aspx filen
Sub Page_Load(obj as Object, e as EventArgs)
        Dim ds As DataSet()
        [b]ds = dbBook.Test[b]
End Sub
Har suttit med detta hela dagen... *river håret*
red/ jag vet att CreateCommand() inte är 100%-ig då databasen inte väljs "dynamsikt " där...
SkarreMedlem sedan apr. 20012 427 inlägg
Re: specified cast.. dataset + mysql
Är det verkligen hela felmeddelandet? Om du vet vilken rad det gäller så skulle du kunna markera denna i fetstil. Kan det vara så att du försöker göra en "implicit" cast där det krävs en "explicit cast"?
RED: stavfel.
det är markerat. Allt ligger ju i en klass/dll så jag får inget "finare" felmeddelande.
implicit/explicit har jag inte en aning om vad du pratar om :\
Dim ds As New DataSet()
ds = dbBook.Test
eller
Dim ds As DataSet
128 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
