rättigheter problem
.NET
2 svar · 195 visningar · startad av CatZ
Medlem sedan jan. 20022 440 inlägg
Access to the path "J:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\root\e4d37b75\a7c216b2" is denied.
vad tusan betyder det? Jag sitter och pillar lite med windows.net 2003 server, och själva .net verkar inte vilja fungera när jag ska köra asp.net sidor
Såhär ser hela felmeddelandet ut
internet explorer skrev:
Server Error in '/' Application.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.UnauthorizedAccessException: Access to the path "J:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\root\e4d37b75\a7c216b2" is denied.
ASP.NET is not authorized to access the requested resource. Consider granting access rights to the resource to the ASP.NET request identity. ASP.NET has a base process identity (typically {MACHINE}\ASPNET on IIS 5 or Network Service on IIS 6) that is used if the application is not impersonating. If the application is impersonating via <identity impersonate="true"/>, the identity will be the anonymous user (typically IUSR_MACHINENAME) or the authenticated request user.
To grant ASP.NET write access to a file, right-click the file in Explorer, choose "Properties" and select the Security tab. Click "Add" to add the appropriate user or group. Highlight the ASP.NET account, and check the boxes for the desired access.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[UnauthorizedAccessException: Access to the path "J:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\root\e4d37b75\a7c216b2" is denied.]
System.IO.__Error.WinIOError(Int32 errorCode, String str) +393
System.IO.Directory.InternalCreateDirectory(String fullPath, String path) +632
System.IO.Directory.CreateDirectory(String path) +195
System.Web.Compilation.PreservedAssemblyEntry.DoFirstTimeInit(HttpContext context) +85
System.Web.Compilation.PreservedAssemblyEntry.EnsureFirstTimeInit(HttpContext context) +97
System.Web.Compilation.PreservedAssemblyEntry.GetPreservedAssemblyEntry(HttpContext context, String virtualPath, Boolean fApplicationFile) +29
System.Web.UI.TemplateParser.GetParserCacheItemFromPreservedCompilation() +91
System.Web.UI.TemplateParser.GetParserCacheItemInternal(Boolean fCreateIfNotFound) +148
System.Web.UI.TemplateParser.GetParserCacheItemWithNewConfigPath() +125
System.Web.UI.TemplateParser.GetParserCacheItem() +88
System.Web.UI.TemplateControlParser.CompileAndGetParserCacheItem(String virtualPath, String inputFile, HttpContext context) +120
System.Web.UI.TemplateControlParser.GetCompiledInstance(String virtualPath, String inputFile, HttpContext context) +36
System.Web.UI.PageParser.GetCompiledPageInstanceInternal(String virtualPath, String inputFile, HttpContext context) +43
System.Web.UI.PageHandlerFactory.GetHandler(HttpContext context, String requestType, String url, String path) +44
System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, String path, String pathTranslated, Boolean useAppConfig) +718
System.Web.MapHandlerExecutionStep.System.Web.HttpApplication+IExecutionStep.Execute() +95
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +173
Version Information: Microsoft .NET Framework Version:1.1.4322.342; ASP.NET Version:1.1.4322.342
jaha, tydligen löste det sig genom att fippla lite med behörigheter till den givna mappen. Konstigt eftersom jag satt rätt behörighet flera gånger tidigare...
Tack för hjälpen katten ;)
251 ms totalt · 4 externa anrop · v20260731065814-full.e96017d9
120 ms — deklarationer (db)
122 ms — ändringar (db)
