har ett problem på min egna webserver, den kan inte köra .aspx filer.
så här står det i iexplore när jag öppnar första sidan.
**Server Application Unavailable
The web application you are attempting to access on this web server is currently unavailable. Please hit the "Refresh" button in your web browser to retry your request.
Administrator Note: An error message detailing the cause of this specific request failure can be found in the application event log of the web server. Please review this log entry to discover what caused this error to occur.**
och när jag läser Application Log står det så här:
aspnet_wp.exe could not be started. The error code for the failure is 80004005. This error can be caused when the worker process account has insufficient rights to read the .NET Framework files. Please ensure that the .NET Framework is correctly installed and that the ACLs on the installation directory allow access to the configured account.
jag är inloggad som Administrator
nån som vet vad det är för fel, kanske borde jag installera om framework?
