funktioner...
6 svar · 419 visningar · startad av Alvar s
Alvar sMedlem sedan mars 2000398 inlägg
1: Hur gör man så att vb hämtar en viss nyckel från registret och sparar den till en fil??
2: Hur får jag alla tal att flytta till olika ställen på detta program? : http://user.tninet.se/~xkk718a/matte.zip ( med rnd funktionen.. )
3: Kan man göra så att många forms använder samma meny? Lr kan man kopiera menyn och snabbt klistra in den, och isf, hur??
[Redigerat av Alvar s den 29 jun 2000]
SweyMedlem sedan apr. 20003 971 inlägg
Registret:
<font size="1" face="Verdana, Arial, Helvetica, sans-serif">Kod:<font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#666600">Public Const HKEY_CLASSES_ROOT = &H80000000
Public Const HKEY_CURRENT_USER = &H80000001
Public Const HKEY_LOCAL_MACHINE = &H80000002
Public Const HKEY_USERS = &H80000003
Public Const HKEY_PERFORMANCE_DATA = &H80000004
Public Const ERROR_SUCCESS = 0&
Declare Function RegCloseKey Lib "advapi32.dll" (ByVal Hkey As Long) As Long
Declare Function RegCreateKey Lib "advapi32.dll" Alias "RegCreateKeyA" (ByVal Hkey As Long, ByVal lpSubKey As String, phkResult As Long) As Long
Declare Function RegDeleteKey Lib "advapi32.dll" Alias "RegDeleteKeyA" (ByVal Hkey As Long, ByVal lpSubKey As String) As Long
Declare Function RegDeleteValue Lib "advapi32.dll" Alias "RegDeleteValueA" (ByVal Hkey As Long, ByVal lpValueName As String) As Long
Declare Function RegOpenKey Lib "advapi32.dll" Alias "RegOpenKeyA" (ByVal Hkey As Long, ByVal lpSubKey As String, phkResult As Long) As Long
Declare Function RegQueryValueEx Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal Hkey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, lpData As Any, lpcbData As Long) As Long
Declare Function RegSetValueEx Lib "advapi32.dll" Alias "RegSetValueExA" (ByVal Hkey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, lpData As Any, ByVal cbData As Long) As Long
Public Const REG_SZ = 1
Public Const REG_DWORD = 4
Public Sub savekey(Hkey As Long, strPath As String)
Dim keyhand&, r
r = RegCreateKey(Hkey, strPath, keyhand&)
r = RegCloseKey(keyhand&)
End Sub
Public Function getstring(Hkey As Long, strPath As String, strValue As String)
Dim keyhand As Long
Dim datatype As Long
Dim lResult As Long
Dim strBuf As String
Dim lDataBufSize As Long
Dim intZeroPos As Integer
Dim r, lValueType
r = RegOpenKey(Hkey, strPath, keyhand)
lResult = RegQueryValueEx(keyhand, strValue, 0&, lValueType, ByVal 0&, lDataBufSize)
If lValueType = REG_SZ Then
strBuf = String(lDataBufSize, " ")
lResult = RegQueryValueEx(keyhand, strValue, 0&, 0&, ByVal strBuf, lDataBufSize)
If lResult = ERROR_SUCCESS Then
intZeroPos = InStr(strBuf, Chr$(0))
If intZeroPos > 0 Then
getstring = Left$(strBuf, intZeroPos - 1)
Else
getstring = strBuf
End Function
Public Sub savestring(Hkey As Long, strPath As String, strValue As String, strdata As String)
Dim keyhand As Long
Dim r As Long
r = RegCreateKey(Hkey, strPath, keyhand)
r = RegSetValueEx(keyhand, strValue, 0, REG_SZ, ByVal strdata, Len(strdata))
r = RegCloseKey(keyhand)
End Sub
Function getdword(ByVal Hkey As Long, ByVal strPath As String, ByVal strValueName As String) As Long
Dim lResult As Long
Dim lValueType As Long
Dim lBuf As Long
Dim r As Long
Dim keyhand As Long
lDataBufSize = 4
lResult = RegQueryValueEx(keyhand, strValueName, 0&, lValueType, lBuf, lDataBufSize)
If lValueType = REG_DWORD Then
getdword = lBuf
End Function
Function SaveDword(ByVal Hkey As Long, ByVal strPath As String, ByVal strValueName As String, ByVal lData As Long)
Dim lResult As Long
Dim keyhand As Long
Dim r As Long
lResult = RegSetValueEx(keyhand, strValueName, 0&, REG_DWORD, lData, 4)
End Function
Public Function DeleteKey(ByVal Hkey As Long, ByVal strKey As String)
Dim r As Long
r = RegDeleteKey(Hkey, strKey)
End Function
Public Function DeleteValue(ByVal Hkey As Long, ByVal strPath As String, ByVal strValue As String)
Dim keyhand As Long, r
r = RegDeleteValue(keyhand, strValue)
End Function
/mvh Swey
Programmera PHP
[Redigerat av Swey den 29 jun 2000]
2. Med Show och Hide antar jag.
3. Med PopupMenu kan du visa en meny från ett annat formulär. Men inte som meny längs titelraden.
/mvh Swey
Programmera PHP
1: Var ska jag lägga in den koden? Måste jag ha nåt speciellt för att koden ska funka?
2: Om jag har 3 tal och 3 positioner vill jag att 1 av dom 3 talen slumpvis ska hamna på en av dom 3 positionerna... osv...
[Redigerat av Alvar s den 04 jul 2000]
Jag har inte Visual Basic installerat för tillfället.
Kan du förtydliga dina frågor?
/mvh Swey
Programmera PHP
1. Lägg koden i en modul och kör funktionerna.
Förstår inte vad du menar med skriva ut en nyckel dock.
2. Vad för sorts positioner?
/mvh Swey
Programmera PHP
exempel
5 + 5 = 10
7 + 7 = 14
1 + 7 = 8
istället kunde det bli tex:
1 + 7 = 8
7 + 7 = 14
5 + 5 = 10
1 + 7 = är en label och svaret är en text där man skriver in svaret, alltså måste båda flyttas till samma ställe på nåt sätt...
178 ms totalt · 3 externa anrop · v20260731065814-full.86db40fa
175 ms — hämta tråd, inlägg och bilagor (db)
