sökning, får inte upp något
.NET
10 svar · 954 visningar · startad av annasmurf
Medlem sedan mars 2006237 inlägg
hej!
kan någon förklara varför jag inte får upp något, har detta:
 <form id="form1" runat="server">
     <div>
      Event: <asp:TextBox ID="SokTextBox" runat="server"></asp:TextBox>
      <br />
      <br />
     <asp:Button ID="SokButton" runat="server" Text="Sök Event" OnClick="SokButton_Click" />
   <asp:GridView ID="EventPrisUppgGridView" runat="server" AllowPaging="True"
   AutoGenerateColumns="true"
OnRowDataBound="EventPrisUppgGridView_RowDataBound"
OnSelectedIndexChanged="EventPrisUppgGridView_SelectedIndexChanged"
OnRowEditing="EventPrisUppgGridView_RowEditing"
OnRowUpdating="EventPrisUppgGridView_RowUpdating"
OnRowCancelingEdit="EventPrisUppgGridView_RowCancelingEdit"
OnRowCommand="EventPrisUppgGridView_RowCommand"
PageSize="500"
OnSorting="EventPrisUppgGridView_OnSorting"
AllowSorting="true"
ShowFooter="true">
<Columns>
<asp:TemplateField HeaderText="id" SortExpression="id"  >
    <ItemTemplate>
    <asp:TextBox ID="idTextBox" runat="server" Width="70" Text='<%# Bind("id") %>'
    OnTextChanged="TextBox_TextChanged" BorderStyle="None" ReadOnly="true"></asp:TextBox>
    </ItemTemplate>
    <FooterTemplate>
       <asp:TextBox ID="idFootTextBox" runat="server"  Text="Ny"> </asp:TextBox>
    </FooterTemplate>
</asp:TemplateField>
<asp:TemplateField HeaderText="name" SortExpression="name"  >
    <ItemTemplate>
        <asp:TextBox ID="nameTextBox" runat="server" Width="200" Text='<%# Bind("name") %>'
        OnTextChanged="TextBox_TextChanged" BorderStyle="None" ></asp:TextBox>
    </ItemTemplate>
    <FooterTemplate>
         <asp:TextBox ID="nameFootTextBox" runat="server" OnTextChanged="TextBox_TextChanged"></asp:TextBox>
     </FooterTemplate>
</Columns>
<RowStyle ForeColor="#000066" />
<SelectedRowStyle BackColor="#669999" Font-Bold="True" ForeColor="White" />
<PagerStyle BackColor="White" ForeColor="#000066" HorizontalAlign="Left" />
<HeaderStyle BackColor="#006699" Font-Bold="True" ForeColor="White" />
</asp:GridView>
<asp:Button ID="SaveButton" runat="server" Text="Spara uppdateringen" OnClick="SaveButton_Click" Height="34px" Width="160px" />
<asp:Button ID="SaveNEwButton" runat="server" Text="Spara det nya eventet" OnClick="SaveNewButton_Click" Height="34px" Width="160px" />
public partial class admin_EventPrisUppg : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
        if (!(IsPostBack))
    protected void SokButton_Click(object sender, EventArgs e)
        string sok = SokTextBox.Text;
        EventPrisUppg eventprisuppgclass = new EventPrisUppg();
        EventPrisUppgSchema eventprisschema = eventprisuppgclass.GetData("%" + sok + "%");
        EventPrisUppgGridView.DataSource = eventprisschema;
        EventPrisUppgGridView.DataBind();
Medlem sedan jan. 2008280 inlägg
Du får debugga och notera vad variabeln "sok" innehåller samt kontrollera om variabeln eventprisschema tilldelas något värde från metoden eventprisuppgclass.GetData.
hej!
jag ser att "sok" innehåller mitt ord, å kör jag schemat där det är en sp-frågan får jag fram svar, så det känns som om något går fel sen, men hur kontrollera om variabeln eventprisschema tilldelas något värde från metoden eventprisuppgclass.GetData
Medlem sedan feb. 20013 023 inlägg
Visa oss vad metoden GetData innehåller så blir det lättare att förstå...
så här ser den ut:
public EventPrisUppgSchema GetData(string eventname)
            EventPrisUppgSchema ds2Return = new EventPrisUppgSchema();
            EventPrisUppgTableAdapter pta = new EventPrisUppgTableAdapter();
            pta.Fill(ds2Return.EventPrisUppg, eventname);
            return ds2Return;
ds2Return ska ha en property DataTable som i sin tur har propertyn Rows som har Count.
Debugga och stanna på raden
return ds2Return;
Använd immediate window och skriv:
?ds2Return.DataTables[0].Rows.Count
Så ska du få antalet rader som datatablen innehåller. Är det 0 där måste du kika på vad din kod skickar iväg för SQL...
då säger den
Web.Schemas.EventPrisUppgSchema.EventRow' does not contain a definition for 'Rows'
men skriver jag
ds2Return.Event.Count
så får jag 0
Den fråga som exekveras mot databasen verkar ju inte vara rätt. Använder du sql server så använder du sql server profiler för att se vad som faktiskt skickas mot databasen.
kommit vidare fel var som du sa 0 har den kod
GO
/****** Object:  StoredProcedure [dbo].[EventPrisUppg]    Script Date: 04/25/2012 09:27:59 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
-- Author:		<Author,,Name>
-- Create date: <Create Date,,>
-- Description:	<Description,,>
ALTER PROCEDURE [dbo].[EventPrisUppg]
	-- Add the parameters for the stored procedure here
	@name char(1024)
AS
BEGIN
	-- SET NOCOUNT ON added to prevent extra result sets from
	-- interfering with SELECT statements.
	SET NOCOUNT ON;
    -- Insert statements for procedure here
	select id, name
, show, e.createdDate, e.updatedDate, e.statusid,
statusSV, selarenaid, transportstatus, ticketId, t.ticketSupplierId,
ticketSupplier, price, ticketStatusId, t.ticketTypeId, ticketType
from event e join
dbo.tickets t on id=eventId join
dbo.eventStatus s on s.statusId = e.statusId join
dbo.ticketSupplier l on l.ticketSupplierId = t.ticketSupplierId join
dbo.ticketType b on b.ticketTypeId = t.ticketTypeId
where name like @name
END
då funkar det inte å köra!!! vad är felet? men gör jag så här så funkar det å jag får ut en lista...kan någon se vad felet är...blir tokig...
select id, name
from event e join
where name like '%arsenal%'
hittade felet char(1024)
ska vara varchar(1024) å då funkar det
123 ms — deklarationer (db)
119 ms — ändringar (db)
