Hej.
Sedan jag bytte dator så kan jag inte bygga webparts, jag kan bygga windows program och webservices.
Jag använder VS 2008.
Detta felet får jag:
Error 2 Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin\sgen.exe /assembly:C:\Projects\SPS_ComponentDevelopment\src\EOR\ORDERREPORTINGWEBPART_bak\obj\Release\OrderReportingWebPart.dll /proxytypes /reference:C:\Projects\SPS_ComponentDevelopment\shared\Flextronics.Logging.dll /reference:C:\Projects\SPS_ComponentDevelopment\shared\Microsoft.ApplicationBlocks.Data.dll /reference:C:\Projects\SPS_ComponentDevelopment\shared\Microsoft.ApplicationBlocks.ExceptionManagement.dll /reference:C:\Projects\SPS_ComponentDevelopment\shared\Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.dll /reference:C:\Projects\SPS_ComponentDevelopment\shared\Microsoft.SharePoint.dll /reference:C:\Projects\SPS_ComponentDevelopment\shared\Microsoft.Web.UI.WebControls.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Configuration.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Data.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Web.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Web.Services.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll /reference:c:\WINNT\Microsoft.NET\Framework\v2.0.50727\System.Xml.dll /compiler:/keyfile:MyKeySPS.snk
SGEN : error : Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
Done building project "OrderReportingWebPart.csproj" -- FAILED.
Hur får man ut LoaderExceptions?
Jag har testat med olika variablar för sgen utan att bli klokare.
Hur kan man lösa det?
mvh
Johan
