Efter lite letande på nätet har jag fått till nedanstående kod:
dim Rs, Conn, sSQL, Stream
dim Fs, File
'Öppna databasen
Set Conn=CreateObject("ADODB.Connection")
Conn.Open "Provider=sqloledb;Data Source=KARLSKRONA\SQLExpress;Initial Catalog=UN;User id=sa;Password=xxx;"
Set Rs=CreateObject("ADODB.Recordset")
Set Stream=CreateObject("ADODB.Stream")
sSQL = "SELECT [Id], BinDocType, BinData FROM tblDocument Where ID IN (10002)"
Rs.Open sSQL, Conn
Do While Not Rs.EOF
Stream.open
Stream.type = 1
Stream.Write Rs.Fields("BinData").Value
Stream.SaveToFile "C:\" & CStr(Rs("Id")) & "." & Rs("BinDocType"), 1
Stream.Close
Rs.MoveNext
Loop
Set Stream=Nothing
Rs.Close
Set Rs = Nothing
Set Conn = Nothing
Den fungerar och min fil skrivs till disk.
Men, är det rätt? Kan man optimera något, är det något jag glömt?
unction GetDocument(lDocId)
dim Rs, Conn, Stream
dim sSQL
dim sOutputPath, sFileName
sOutputPath=application.setting("CommonPath") & "PdfOutput\"
If not isnumeric(lDocId) then exit function
'Öppna databasen
Conn.Open Application.sDbConnectionString
sSQL = "SELECT d.[BinDocType] AS DocType, d.[BinData] AS DocData, d.[Name] AS DocName" _
& " FROM tblDocument d" _
& " WHERE d.[Id] = " & lDocId & "" _
& " AND d.BinDocType <> ''"
Rs.Open sSQL, Conn
if Rs.EOF then
GetDocument=""
sFileName=CStr(lDocId) & "_" & Rs("DocName") & "." & Rs("DocType")
Stream.open
Stream.type = 1
Stream.Write Rs("DocData")
Stream.SaveToFile sOutputPath & sFileName, 1
Stream.Close
GetDocument=sOutputPath & sFileName
end If
Set Stream=Nothing
Rs.Close
Set Rs = Nothing
Set Conn = Nothing
End function
Är det ok, eller ser ni något galet?
Henrik
259 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
