Jag får följande fel när jag försöker logga in på min sida. Det fungerar när jag kör den lokalt och det fungerar i firefox men inte i Internet explorer. Det har fungerat men slutade att fungera i helgen, jag har inte gjort några ändringar i koden.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Security.Cryptography.CryptographicException: Padding is invalid and cannot be removed.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[CryptographicException: Padding is invalid and cannot be removed.]
System.Security.Cryptography.RijndaelManagedTransform.DecryptData(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount, Byte[]& outputBuffer, Int32 outputOffset, PaddingMode paddingMode, Boolean fLast) +7594654
System.Security.Cryptography.RijndaelManagedTransform.TransformFinalBlock(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount) +208
System.Security.Cryptography.CryptoStream.FlushFinalBlock() +33
System.Web.Configuration.MachineKeySection.EncryptOrDecryptData(Boolean fEncrypt, Byte[] buf, Byte[] modifier, Int32 start, Int32 length, IVType ivType, Boolean useValidationSymAlgo) +225
System.Web.Security.FormsAuthentication.Decrypt(String encryptedTicket) +246
ASP.global_asax.Application_AuthenticateRequest(Object sender, EventArgs e) +860
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Någon som vet vad som kan vara fel? Kan det vara något på webhotellet som ändrats?
Version Information: Microsoft .NET Framework Version:2.0.50727.3053; ASP.NET Version:2.0.50727.3053
