Av någon anledning så körs min ena stored procedure (insertIMDBmovie) två gånger, medans den andra (insertUserMovie) endast körs en gång (vilket är rätt) någon som kan se problemet?
Sub MySQLDataGrid_RowCommand(ByVal sender As Object, ByVal e As GridViewCommandEventArgs)
Dim intMovieID As Integer
' If multiple ButtonField column fields are used, use the
' CommandName property to determine which button was clicked.
If e.CommandName = "Select" Then
' Convert the row index stored in the CommandArgument
' property to an Integer.
Dim index As Integer = Convert.ToInt32(e.CommandArgument)
' Get the last name of the selected author from the appropriate
' cell in the GridView control.
Dim selectedRow As GridViewRow = MySQLDataGrid.Rows(index)
Dim titleCell As TableCell = selectedRow.Cells(1)
Dim strTitle As String = titleCell.Text
Dim yearCell As TableCell = selectedRow.Cells(2)
Dim intYear As String = yearCell.Text
Dim imdbCell As TableCell = selectedRow.Cells(3)
Dim strImdbID As String = imdbCell.Text
' Define data objects
Dim conn As SqlConnection
Dim comm As SqlCommand
' Read the connection string from Web.config
Dim connectionString As String = ConfigurationManager.ConnectionStrings("moviedatabase").ConnectionString
' Initialize connection
conn = New SqlConnection(connectionString)
' Create command
comm = New SqlCommand("insertIMDBMovie", conn)
' Specify we're calling a stored procedure
comm.CommandType = System.Data.CommandType.StoredProcedure
' Add command parameters
comm.Parameters.Add("@title", System.Data.SqlDbType.NVarChar, 150)
comm.Parameters("@title").Value = strTitle
comm.Parameters.Add("@year", System.Data.SqlDbType.Int)
comm.Parameters("@year").Value = intYear
comm.Parameters.Add("@imdbid", System.Data.SqlDbType.NVarChar, 50)
comm.Parameters("@imdbid").Value = strImdbID
Try
' Open the connection
conn.Open()
' Execute the command
comm.ExecuteNonQuery()
intMovieID = comm.ExecuteScalar
Catch
' Display error message
dbErrorMessage.Text = "Error submitting the IMDBmovie request! Please Try again later, and/or change the entered data!"
Finally
conn.Close()
Label1.Text = "You Added " & Title & "."
End Try
Dim conn2 As SqlConnection
Dim comm2 As SqlCommand
' Close the connection
conn2 = New SqlConnection(connectionString)
' Create command
comm2 = New SqlCommand("insertUserMovie", conn2)
comm2.CommandType = System.Data.CommandType.StoredProcedure
comm2.Parameters.Add("@userID", System.Data.SqlDbType.Int)
comm2.Parameters("@userID").Value = Session("userID")
comm2.Parameters.Add("@MovieID", System.Data.SqlDbType.Int)
comm2.Parameters("@MovieID").Value = intMovieID
comm2.Parameters.Add("@format", System.Data.SqlDbType.Int)
comm2.Parameters("@format").Value = movie_formats.SelectedItem.Value.ToString()
Try
conn2.Open()
comm2.ExecuteNonQuery()
Catch
dbErrorMessage.Text = "Error submitting the usermovie request! Please Try again later, and/or change the entered data!"
Finally
conn2.Close()
End Try
End Sub
