Dubbla rader i DB
.NET
1 svar · 494 visningar · startad av TomKarl
Medlem sedan okt. 200720 inlägg
Jag har en bilduppladdnings funktion som inte gör som jag vill. Det blir dubbla rader i databasen samt att filnamnet på thumben inte följer med, har inte lyckats klura ut hur jag plockar fram det.
Vad är galet?
/Tomas
    Protected Sub PictureUploadButton_Click(ByVal sender As Object, ByVal e As EventArgs) Handles PictureUploadButton.Click
        If PictureUpload.HasFile Then
            Dim image As System.Drawing.Image = System.Drawing.Image.FromStream(PictureUpload.PostedFile.InputStream)
            ' save orginal image
            Dim fileName As String = Path.Combine(Server.MapPath("~/Uploads"), PictureUpload.FileName)
            If File.Exists(fileName) Then
                File.Delete(fileName)
            image.Save(fileName)
            Dim uplImg As String
            uplImg = PictureUpload.FileName
            ' create thumbnail
            Dim w As Single = image.PhysicalDimension.Width
            Dim h As Single = image.PhysicalDimension.Height
            Dim s As Single = Math.Max(h, w) ' pick the larger side
            Dim r As Single = IIf(s <= 64, 1.0, 64 / s) ' max width or height is 64 pixels
            ' scale the dimensions
            w *= r
            h *= r
            Dim thumb As System.Drawing.Image = image.GetThumbnailImage(w, h, AddressOf DoNothing, 0)
            ' save the thumbnail
            fileName = Path.Combine( _
                Server.MapPath("~/Uploads"), _
                String.Format("{0}_thm{1}", _
                    Path.GetFileNameWithoutExtension(PictureUpload.FileName), _
                    Path.GetExtension(PictureUpload.FileName) _
                ) _
            thumb.Save(fileName)
            Dim uplImgThmb As String
            uplImgThmb = PictureUpload.FileName
            ' Spara till DB
            Dim strConnectionString As String
            Dim strQuery As String
            Dim MyConnection As OdbcConnection
            Dim myCommand As OdbcCommand
            strConnectionString = "DRIVER={MySQL ODBC 3.51 Driver}; SERVER=****; DATABASE=*****; UID=*****; PASSWORD=*****; OPTION=3"
            MyConnection = New OdbcConnection(strConnectionString)
            MyConnection.Open()
            strQuery = "INSERT INTO tbl_uplImg(imgName, imgThumb) VALUES (?, ?)"
            myCommand = New OdbcCommand(strQuery, MyConnection)
            myCommand.Parameters.AddWithValue("?", uplImg)
            myCommand.Parameters.AddWithValue("?", uplImgThmb)
            myCommand.ExecuteNonQuery()
            MyConnection.Close()
        Else
            lblUpload.Text = ("Ingen bild uppladdad!")
    End Sub
Sätt namn på parametrarna
myCommand.Parameters.AddWithValue("blabla", uplImg)
myCommand.Parameters.AddWithValue("blublu", uplImgThmb)
Det spelar ingen roll för SQL-frågan, men för själva parameter-kollektionen.
Eller byt till MySqlClient (i stället för ODBC) och använd riktiga namngivna parametrar.
119 ms — deklarationer (db)
123 ms — ändringar (db)
