Jag har en xml fil som jag vill lägga in värden i men lyckas inte på något sätt.
Programmerar i C#.
Hur gör jag om jag till exempel vill lägga in punched="true" (fetmarkerat)
<?xml version="1.0" encoding="UTF-8"?>
<?mso-infoPathSolution name="urn:schemas-microsoft-com:office:infopath:IDM-B--C11-Concrete-pouring-Inspection-1:-dataFormSolution" href="manifest.xsf" solutionVersion="1.0.0.149" initialView="View 1" productVersion="11.0.8034" PIVersion="1.0.0.0" ?>
<?mso-application progid="InfoPath.Document"?>
<dfs:myFields xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:q="http://schemas.microsoft.com/office/infopath/2003/ado/queryFields" xmlns:d="http://schemas.microsoft.com/office/infopath/2003/ado/dataFields" xmlns:dfs="http://schemas.microsoft.com/office/infopath/2003/dataFormSolution" xmlns:my="http://schemas.microsoft.com/office/infopath/2003/myXSD/2007-04-21T19:05:15" xmlns:xd="http://schemas.microsoft.com/office/infopath/2003">
<dfs:queryFields>
<q:project_commissioning_form form_code="B0_C11 " Project_ID="" responsible_person="" done="" signed="" punched="" test_date="" time_allocated="" time_spend="" equipment_code="" notes="" customer_signature="" W_name="" W_date="" W_place="" C_name="" C_date="" C_place="" C2_name="" C2_date="" C2_place="" C3_name="" C3_date="" C3_place=""></q:project_commissioning_form>
<q:commissioning_form form_code="" title="" description="" engine_related="" template_id="" classification="" form_remark=""></q:commissioning_form>
<q:skill id="" name="" form_code=""></q:skill>
<q:equipment Project_ID="" equipment_code="" customer_code="" equipment_manufacturer="" equipment_type="" equipment_serial_nr="" engine_serial_nr="" equipment_remark=""></q:equipment>
<q:test_equipment id="" name="" type="" maker="" serial_number="" calibration_expiring_date="" test_equipment_remarks="" form_code="" Project_ID=""></q:test_equipment>
</dfs:queryFields>
<dfs:dataFields>
<d:project_commissioning_form form_code="" Project_ID="" responsible_person="" done="False" signed="" [B]punched=""[/B] test_date="" time_allocated="" time_spend="" equipment_code="" notes="" customer_signature="" W_name="" W_date="" W_place="" C_name="" C_date="" C_place="" C2_name="" C2_date="" C2_place="" C3_name="" C3_date="" C3_place="">
<d:equipment Project_ID="" equipment_code="" customer_code="" equipment_manufacturer="" equipment_type="" equipment_serial_nr="" engine_serial_nr="" equipment_remark=""></d:equipment>
<d:test_equipment id="" name="" type="" maker="" serial_number="" calibration_expiring_date="" test_equipment_remarks="" form_code="" Project_ID=""></d:test_equipment>
</d:project_commissioning_form>
</dfs:dataFields>
<my:tester1></my:tester1>
<my:testdate1 xsi:nil="true"></my:testdate1>
<my:tester2></my:tester2>
<my:testdate2 xsi:nil="true"></my:testdate2>
<my:test_description>
<my:reference_dp xsi:nil="true"></my:reference_dp>
<my:reference_initials_tb></my:reference_initials_tb>
<my:reference_result_tb></my:reference_result_tb>
<my:subbase_dp xsi:nil="true"></my:subbase_dp>
<my:subbase_initials_tb></my:subbase_initials_tb>
<my:subbase_result_tb></my:subbase_result_tb>
<my:fill_dp xsi:nil="true"></my:fill_dp>
<my:fill_initials_tb></my:fill_initials_tb>
<my:fill_result_tb></my:fill_result_tb>
<my:formwork_dp xsi:nil="true"></my:formwork_dp>
<my:formwork_initials_tb></my:formwork_initials_tb>
<my:formwork_result_tb></my:formwork_result_tb>
<my:check_dp xsi:nil="true"></my:check_dp>
<my:check_initials_tb></my:check_initials_tb>
<my:check_result_tb></my:check_result_tb>
<my:formwork_supported_dp xsi:nil="true"></my:formwork_supported_dp>
<my:formwork_supported_initials_tb></my:formwork_supported_initials_tb>
<my:formwork_supported_result_tb></my:formwork_supported_result_tb>
<my:formwork_cleanliness_dp xsi:nil="true"></my:formwork_cleanliness_dp>
<my:formwork_cleanliness_initials_tb></my:formwork_cleanliness_initials_tb>
<my:formwork_cleanliness_result_tb></my:formwork_cleanliness_result_tb>
<my:reinforcement_dp xsi:nil="true"></my:reinforcement_dp>
<my:reinforcement_initials_tb></my:reinforcement_initials_tb>
<my:reinforcement_result_tb></my:reinforcement_result_tb>
<my:reinforcement_suppported_dp xsi:nil="true"></my:reinforcement_suppported_dp>
<my:reinforcement_supported_initials_tb></my:reinforcement_supported_initials_tb>
<my:reinforcement_supported_result_tb></my:reinforcement_supported_result_tb>
<my:concrete_dp xsi:nil="true"></my:concrete_dp>
<my:concrete_initials_tb></my:concrete_initials_tb>
<my:concrete_result_tb></my:concrete_result_tb>
<my:check_tolerance_dp xsi:nil="true"></my:check_tolerance_dp>
<my:check_tolerance_initials_tb></my:check_tolerance_initials_tb>
<my:check_tolerance_result_tb></my:check_tolerance_result_tb>
<my:entrance_dp xsi:nil="true"></my:entrance_dp>
<my:entrance_initials_tb></my:entrance_initials_tb>
<my:entrance_result_tb></my:entrance_result_tb>
<my:earthing_dp xsi:nil="true"></my:earthing_dp>
<my:earthing_initials_tb></my:earthing_initials_tb>
<my:earthing_result_tb></my:earthing_result_tb>
<my:construction_dp xsi:nil="true"></my:construction_dp>
<my:construction_initials_tb></my:construction_initials_tb>
<my:construction_result_tb></my:construction_result_tb>
<my:pentration_dp xsi:nil="true"></my:pentration_dp>
<my:pentration_initials_tb></my:pentration_initials_tb>
<my:pentration_result_tb></my:pentration_result_tb>
<my:concrete_pour_dp xsi:nil="true"></my:concrete_pour_dp>
<my:concrete_pour_initials_tb></my:concrete_pour_initials_tb>
<my:concrete_pour_result_tb></my:concrete_pour_result_tb>
<my:concrete_aggregates_dp xsi:nil="true"></my:concrete_aggregates_dp>
<my:concrete_aggregates_initials_tb></my:concrete_aggregates_initials_tb>
<my:concrete_aggregates_result_tb></my:concrete_aggregates_result_tb>
<my:all_equipment_dp xsi:nil="true"></my:all_equipment_dp>
<my:all_equipment_initials_tb></my:all_equipment_initials_tb>
<my:all_equipment_result_tb></my:all_equipment_result_tb>
<my:number_dp xsi:nil="true"></my:number_dp>
<my:number_initials_tb></my:number_initials_tb>
<my:number_result_tb></my:number_result_tb>
<my:planned_dp xsi:nil="true"></my:planned_dp>
<my:planned_initials_tb></my:planned_initials_tb>
<my:planned_result_tb></my:planned_result_tb>
<my:ok__to_pour_dp xsi:nil="true"></my:ok__to_pour_dp>
<my:ok__to_pour_initials_tb></my:ok__to_pour_initials_tb>
<my:ok__to_pour_result_tb>false</my:ok__to_pour_result_tb>
<my:observation_dp xsi:nil="true"></my:observation_dp>
<my:observation_initials_tb></my:observation_initials_tb>
<my:observation_result_tb></my:observation_result_tb>
</my:test_description>
<my:Add_list>
<my:Additional_test></my:Additional_test>
<my:Result></my:Result>
<my:Remark></my:Remark>
<my:Performed_by></my:Performed_by>
<my:Date xsi:nil="true"></my:Date>
</my:Add_list>
<my:Additional_notes>
<my:Additional_notes1></my:Additional_notes1>
</my:Additional_notes>
</dfs:myFields>
