Översätta VB6 till C#
.NET
9 svar · 744 visningar · startad av Zaiman
Hallå har suttit ett bra tag med detta nu och snurrat till det rejält. Får det inte att stämma.
Oginalet som ska översättas ser ut så här:
Make_Subset_C()
  '*** Start C has value of 105
	Total% = 105
	'*** Add Start Character to output
	BarCodeData.Text = Chr$(137)
	'*** Make sure there are an even number of digits
	If Len(UserText.Text) Mod 2 <> 0 Then UserText.Text = "0" + UserText.Text
	'*** Initialize k to keep track of position value
	k% = 1
	'*** Loop through the data & read each pair of characters
	For I% = 1 To Len(UserText.Text)
		'*** Need to remap this character if it appears
		If Asc(Mid$(UserText.Text, I%, 1)) = 127 Then
			BarCodeData.Text = BarCodeData.Text + Chr$(139)
 		If Asc(Mid$(UserText.Text, I%, 1)) = 32 Then
                    BarCodeData.Text = BarCodeData.Text + Chr$(192)
            Else
			BarCodeData.Text = BarCodeData.Text + Chr$(Val(Mid$(UserText.Text,_ 			I%, 2)) + 32)
            '*** Multiply position * value and add to existing total
		Total% = Total% + (Val(Mid$(UserText.Text, I%, 2)) * k%)
            k% = k% + 1
            I% = I% + 1
        Next I%
      '*** get the MOD 103 check digit value
	Total% = Total% Mod 103
	'*** remap character if it appears
	If Total% = 0 Then Total% = 113
	'*** Add check digit to output
	BarCodeData.Text = BarCodeData.Text + Chr$(Total% + 32)
	'*** Add stop character to output
	BarCodeData.Text = BarCodeData.Text + Chr$(138)
      '*** Loop through code and remap space characters
	Temp$ = ""
	For I% = 1 To Len(BarCodeData.Text)
		If Asc(Mid$(BarCodeData.Text, I%, 1)) = 32 Then
			Temp$ = Temp$ + Chr$(192)
		Else
			Temp$ = Temp$ + Mid$(BarCodeData.Text, I%, 1)
	Next I%
	BarCodeData.Text = Temp$
end sub
Efter många försök har jag inte fått till det :(
Min snurriga, virriga kod just nu (jag vet att den inte är snygg :r )
namespace Lab
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            string s = code128C(txtIn.Text);
            txtUt.Text = s.ToString();
        private string code128C(string txt)
            string txtRetur = "";
            string start = new string((char)0137, 1);
            // Fixa till längden på inkommande sträng
            if (txt.Length % 2 != 0)
                txt = "0" + txt;
            string tmpText = txt;
            //Längen på strängen parvis
            int k = txt.Length ;
            for (int i = 0; i < k; i++)
                    string s = Mid(txt, i,1);
                    int myChar = Convert.ToInt32(s);
                    MessageBox.Show(myChar.ToString(), "s", MessageBoxButtons.OK);
                    if (myChar == 127)
                        string str = new string((char)0139, 1);
                        txtRetur += str;
                    if (myChar == 32)
                        string str = new string((char)0192, 1);
                        txtRetur += str;
                        string b = Mid(txt, 0, 2);
                        int myChar1 = Convert.ToInt32(b);
                        myChar1 = myChar1 + 32;
                        string str = new string((char)myChar1, 1);
                        txtRetur = txtRetur + str;
                   //txt = txt.Remove(0, 2);
            txtRetur = start + txtRetur;
            int sum = Code128CChecksum(txt);
            if (sum == 0)
                sum = 113;
                sum = sum + 32;
            string strCheck = new string((char)sum, 1);
            txtRetur = txtRetur + strCheck;
            return txtRetur;
        private int Code128CChecksum(string chk)
            int i = 1;
            int sum = 105; //Summan 105 är startkoden för 128C
            int k = chk.Length;
            for (int a = 1; a <= k; a++)
                string s = chk.Substring(0, 2);
                sum = sum + (myChar * i);
                i++;
            sum = (sum % 103);
            return sum;
        private string MakeCode128C(string txt)
            int start = 105;
            // string startChar = new string((char)0137, 1);
            string returnText = new string((char)0137, 1); ;
            //Kontrollera att strängen är jämt delbar annars lägg till 0 i början av strängen
                txt  = "0" + txt;
            //Antal par siffror
            int par = txt.Length / 2;
            int k = 1;
            int i = 1;
            foreach(char c in txt)
                int iAsciiValue = Convert.ToInt16(c);
                // int iAsciiValue = Convert.ToInt32(((int)c).ToString());
                if(iAsciiValue  == 127)
                    string s = new string((char)0139, 1);
                    returnText = returnText + s;
                if (iAsciiValue == 32)
                    string s = new string((char)0192, 1);
                    int myChar = Convert.ToInt16(Mid(txt, i, 2))+32;
                    string str = new string((char)myChar, 1);
                    returnText = returnText + str;
                start = start + (Convert.ToInt32(Mid(txt, i, 2)) * k);
                k++;
                i++;
            //Kontroll tecken
            start = start % 103;
            if (start == 0)
                start = 113;
            // Lägg till Kontrolltecken i strängen
            int controlChar = start + 32;
            string kontrolltkn = new string((char)controlChar, 1);
            returnText = returnText + kontrolltkn;
            // Konvertera space tecken
            string strRetur = "";
            i = 1;
            foreach (char c in returnText)
                int iAsciiValue = Convert.ToInt32(c);
                    strRetur = strRetur + s;
                    strRetur = strRetur + Mid(returnText, i, 1);
                i++;
            returnText = strRetur;
            return returnText;
        private int ChecksumC(string chk)
            int i = 1;
            int sum = 105; //Summan 104 är startkoden för 128B
            foreach (char c in chk)
                int tal = (int)c - 32;
                sum = sum + (tal * i);
                i++;
            sum = sum % 103;
            return sum;
        private string Mid(string param, int startIndex, int length)
            //start at the specified index in the string ang get N number of
            //characters depending on the lenght and assign it to a variable
            string result = param.Substring(startIndex, length);
            //return the result of the operation
            return result;
Någon som kanske redan gjort detta eller kan hjälpa mig på traven. Trött i knoppen och blir avbruten hela tiden. Det hela handlar alltså om teckenkonvertering och checksumma för streckkoder.
Tacksam för all hjälp.
Varför översätta?
Sätt upp kraven på vad som skall utföras och utgå ifrån dom tycker jag.
Kraven är dem samma som i VB koden. Lösningen ska generera samma sträng som VB koden. Så i princip blir det en översättning av koden.
Sen om lösningen är exakt översatt från VBkoden eller helt annorlunda ska resultatet bli detsamma. :)
Kommit en bir på äg nu iaf. Men får inte till undantagen, det fungerar bra så länge inkommande sträng är jämnt antal tecken.
        public Form1()
            // string str = new string((char)0192, 1);
            string start = "‰";
            string strStop = "Š";
                txt = "0" + txt;
            int k = (txt.Length /2) ;
            for (int i = 1; i <= k; i++)
                    string s = Mid(txt, 0,2);
                    int myChar = Convert.ToInt32(s) + 32;
                    if (myChar == 32)
                    else if (myChar == 127)
            int sum = Code128CChecksum(tmpText);
            if (sum == 0)
                sum = 113;
                sum = sum + 32;
            txtRetur = txtRetur + strCheck + strStop;
            return txtRetur;
            int i = 1;
            int k = chk.Length / 2;
            string tmp = chk;
                string s = tmp.Substring(0, 2);
                i++;
                tmp = tmp.Remove(0, 2);
            sum = (sum % 103);
            return sum;
            return result;
Säkert går det att lösa på andra bättre sätt.. Men jag lär mig lite i taget.
Någon som har någon idé ?
Ingen som har någon idé om hur man får till undantagen?
Har nog kommit igenom allt men är lite osäker på om allt är rätt. Hittils fungerar det ok.
Äh hittade mer fel så det funkar inte *suck*
Då kan det ju alltid vara en idé att posta felen här för att få lite hjälp om man känner att man behöver det. ;)
Här kommer kod :)
Först den som är direkt översatt, den får jag såklart fel i eftersom den väljer mitt i en loop 2 tecken helt plötsligt medans den loopar igenom för varje tecken. Såklart att substring out of range inträffar. Inget konstigt med det. Den är mest för att få till det översättningsmässigt. Så kanske det bara är något enkel att korrigera som inte jag har grepp om :r
    public static string code128Cny(string txt)
        int total = 105;
        //Start tecken för 128C
        string strReturn = "‰";
        // Kontrollera längen på strängen om ojämn lägg till en nolla i början
            txt = "0" + txt;
        // initera k för att hålla koll på positionen
        int k = 1;
        // Räkna igenom alla tecken och parvis
        for (int i = 1; i < txt.Length; i++)
            string s = txt.Substring(i, 1);
            if (Convert.ToInt32(s) == 127)
                strReturn = strReturn + "‹";
            if (Convert.ToInt32(s) == 32)
                strReturn = strReturn + "À";
                string s1 = txt.Substring(i,2);
                int s2 = Int32.Parse(s1) + 32;
                string str = new string((char)s2, 1);
                strReturn = strReturn + str;
            total = total + (Int32.Parse(txt.Substring(i, 2)) * k);
            k++;
        // Utvinn checksiffra
        total = (total % 103);
        // Checksiffra får ej vara 0 mappa om till 113
        if (total == 0)
            total = 113;
        // Mappa till ascii
        total = total + 32;
        // Lägg på checksiffra i strängen
        string strC = new string((char)total, 1);
        strReturn = strReturn + strC;
        // Lägg på stoptecken
        strReturn = strReturn + "Š";
        // Loopa igen kontroll efter blanksteg och byt ut dessa
        string temp = "";
        foreach (char c in strReturn)
            if (Convert.ToInt32(c) == 32)
                temp = temp + "À";
                temp = temp + c;
        strReturn = temp;
        return strReturn;
Och så den "fula" som jag knåpat ihop och som fungerar 8 av tio fall ungefär :r
   public static string code128C(string txt)
            string start = "‰";
                txt = "0" + txt;
            int k = (txt.Length / 2);
                string s = Mid(txt, 0, 2);
                if (myChar == 32)
                else if (myChar > 127)
                    string sTemp = "1" + s;
                    int tmpChar = Convert.ToInt32(sTemp);
                    string str = new string((char)tmpChar, 1);
            if (sum == 0)
                sum = 113;
            else if (sum > 94)
                sum = sum + 100;
                sum = sum + 32;
            //Kolla storlek på kontrolltecken innan.
            return txtRetur;
    private static int Code128CChecksum(string chk)
        int i = 1;
        string tmp = chk;
            i++;
        sum = (sum % 103);
        return sum;
    private static string Mid(string param, int startIndex, int length)
        return result;
Den har jag knåpat bäst jag kunnat..
*puff* ?
267 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
120 ms — deklarationer (db)
129 ms — ändringar (db)
