AJAX
.NET
1 svar · 528 visningar · startad av devotion
Jag har följande script på en html-sida:
<SCRIPT language='vbscript'>
	' KOPIERAD FRÅN UN_GLOBAL.VBS:
	' Return a value from an SQL SELECT query to Uppdrag NU db
	function GetUNValue(sSQL)
		dim Conn, Rs
		Set Conn=CreateObject("ADODB.Connection")
		Conn.Open "<% =Application.sDbConnectionString %>"
		Set Rs=CreateObject("ADODB.Recordset")
		Rs.Open sSQL, Conn
		if Rs.EOF then
			GetUNValue=""
			GetUNValue=Rs.Fields(0)
		end If
		Rs.Close
		Set Rs=Nothing
		Set Conn=Nothing
	end function
	sub OnValidateArtNr(nIndex)
		dim sArtNr, sArtName
		sArtNr=document.all.item("article" & nIndex).value
		if sArtNr="" then
			document.all.item("artname" & nIndex).innerHtml="(ingen artikel vald)"
			exit sub
		sArtName=GetUNValue("SELECT [Name] FROM [tblArticle] WHERE [Nr]='" & sArtNr & "'")
		sUnit=GetUNValue("SELECT [Unit] FROM [tblArticle] WHERE [Nr]='" & sArtNr & "'")
		if sArtName="" then
			' MsgBox "Artikeln '" & sArtNr & "' finns inte."
			document.all.item("artname" & nIndex).innerHtml="<font color='#ff0000'>(felaktigt artikelnr)</font>"
			document.all.item("artname" & nIndex).innerHtml=sArtName
			document.all.item("unit" & nIndex).value=sUnit
	end sub
	sub OnSave()
		dim i
		dim sArtNr, fAmount, sUnit, sPLNr, fPrice
		dim s
		sPLNr=document.all.item("supplier").value
		s=""
		for i=1 to 10
			sArtNr=document.all.item("article" & i).value
			fAmount=document.all.item("amount" & i).value
			sUnit=document.all.item("unit" & i).value
			if sArtNr<>"" then
				fPrice=GetUNValue("SELECT TOP 1 [Price] FROM [tblPrice] WHERE [Type]=4 AND [PriceListNr]='" & sPLNr & "' AND [ArtNr]='" & sArtNr & "' AND [FromAmount]<=" & fAmount & "ORDER BY [FromAmount] DESC")
				if not IsNumeric(fPrice) then fPrice=0
				s = s & "Lägg till " & fAmount & " " & sUnit & " av artikelnr " & sArtNr & ", pris " & fPrice & " kr" & Chr(13) & Chr(10)
		next
		MsgBox s
	end sub
</SCRIPT>
Den övriga koden på sidan ser ut så här:
<body bgcolor='#<COLOR_3DFACE>'>
<h1>Registrera materialrader för uppdrag: <% =GetUNValue("SELECT [TaskNr] FROM [tblTask] WHERE [Id]=<TaskId>") %></h1>
<form name='myform' action="javascript:OnSave()" method="post">
<label>Välj leverantör:
Dim objConn, objRS, sSQL
Set objConn = CreateObject( "ADODB.Connection" )
objConn.Open Application.sDbConnectionString
Set objRs = CreateObject( "ADODB.Recordset" )
sSQL = "SELECT * FROM tblPricelist ORDER BY [Name]"
Set objRS = objConn.Execute (sSQL)
Response.write "<select name=""supplier"">"
while not ObjRS.EOF
    sName = objRS("Name")
    sPriceListNr = objRS("Nr")
    Response.write "<option value=" & sPriceListNr & ">" & sName & "</option>"
objRS.Movenext
wend
Response.write "</select>"
objRS.Close
Set objRS = Nothing
Response.write "</label>"
Response.write "<p>"
for i = 1 to 10
    Response.write "<label>Artikelnummer: <input name=""article" & i & """ onblur='OnValidateArtNr(" & i & ")'></label>"
    Response.write "<label>Antal: "
    Response.Write "<select name=""amount" & i & """ id=""amount" & i & """>"
        for i2 = 1 to 100
            Response.Write "<option value=""" & i2 & """ "
            Response.Write ">" & i2 & "</option>" & vbCrLf
        next
    Response.write "<label>Enhet: "
    Response.write "<select name=""unit" & i & """>"
        Response.write "<option value=""st"">styck</option>"
        Response.write "<option value=""m"">meter</option>"
	Response.Write "&nbsp;&nbsp;<label id='artname" & i & "'>(ingen artikel vald)</label>"
Next
<input name="addArticles" type="submit" value="Lägg till">
objConn.Close
Set objConn = Nothing
Det fungerar som så att när man lämnar textfältet så slås artikeln upp i databasen. Se bifogad bild. Kan man göra så att sökningen börjar direkt när man börjar skriva?
Så när inget text skrivits står det "Ingen artikel vald"
När man skrivit ett felaktigt nummer visas "Felaktigt artikelnummer"
När man till slut kommer till ett nummer som finns i databasen visas benämningen. Det kan väl liknas AJAX...
Henrik
Använde:
onKeyUp
istället för:
onBlur
Och det verkar ju funka...
139 ms — deklarationer (db)
122 ms — ändringar (db)
