konvertera asp/vbscript --> VbScript
14 svar · 635 visningar · startad av devotion
:e
Jag har följande kod som är en aspfil:
Dim sSQL, objConn, objRS1, objRS2,  iStatus, sNote, sCategory, sName, sArtNr, sUnit, iPrice, iNextId, sArticleNumber, sArticleName, sList, iSupplierId
'Ange status; 0 = "synkroniserad med SPCS", 1 = "Inte synkroniserad mot SPCS"
iStatus = 0
'Notering
sNote = ""
'Pris
iPrice = 0
' Öppna databasen
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.ConnectionString = Application("sConn")
objConn.Open
sSQL = 		"SELECT tblArticle.articlenumber, tblArticle.articleName, tblArticle.articleUnit " &_
			"FROM tblArticle " &_
			"ORDER BY tblArticle.articlenumber"
Set objRS1 = Server.CreateObject("ADODB.Recordset")
objRS1.Open sSQL, objConn, 3, 1
If not objRS1.EOF then
	do while not objRS1.EOF
		sArticleNumber = objRS1("articleNumber")
		sArticleName = objRS1("articleName")
		sUnit = lCase(objRS1("articleUnit"))
		'Ta ut de två första tecknena i E-numret
		sList = left(sArticleNumber, 2)
		'Hämta kategorinamn mha sList
		Set objRS2 = objConn.Execute ("SELECT listName FROM tblList WHERE listNr = '" & sList & "'")
		If not objRS2.EOF then
			sCategory = objRS2("listName")
		objRS2.Close
		Set objRS2 = Nothing
		Set objRS2 = objConn.Execute ("SELECT nextId FROM UppdragNu.dbo.tblNextId WHERE [table] = 'tblArticle'")
			iNextId = cLng(objRS2("NextId"))
		objRS2.Close
		sSQL = 	"INSERT INTO UppdragNu.dbo.tblArticle ([Id], [Status], [Modified], [Nr], [Name], [Category], [Unit], [Price], [Note]) " &_
				"VALUES(" & iNextId & ", " & iStatus & ", getdate(), '" & sArticleNumber & "', '" & sArticleName & "', " &_
				"'" & sCategory & "', '" & sUnit & "', " & iPrice & ", '" & sNote & "')"
				Response.write sSQL
		'response.end
		objConn.execute sSQL,,128
		sSQL = "UPDATE UppdragNu.dbo.tblNextId SET nextId = nextId + 1 WHERE [Table] = 'tblArticle'"
		objConn.Execute sSQL,, 128
		objRS1.Movenext
	Loop
Else
	Response.write "Fel!"
End if
objRS1.Close
Set objRS1 = Nothing
Response.write "Datat har lagrats!"
Nu skulle jag vilja göra om den till en vbscriptfil som är körbar i windows. Detta är helt nytt för mig, så jag skulle vara glad om någon kunde sparka mig i rätt riktning.... ;)
Var hittar jag vbScript-referenser?
Finns det någon bra bok?
Henrik
VBScript referenser finns en del. Jag brukar använda: http://www.devguru.com/technologies/vbscript/home.asp
Enda skillnaden mellan att använda ASP+VBScript och bara VBScript är att man inte använder context-switchar och kan inte använda ASP-objekten.
Så i ditt fall så skulle du först ta bort <%%>, använda CreateObject istället för Server.CreateObject, hårdkoda connectionsträngen eller hämta ut den på något annat sätt (istället för Application) och använda t.ex. MsgBox eller WScript.Echo istället för Response.Write.
Okidoki.... :)
Tackar Erik!
Jag provar mig fram lite, så får vi se var jag hamnar....
Henrik
hmm, finns det någon käck editor, som du rekommenderar? Tänkte på färgkodning och sådant..
Henrik
Aha... Dreamweaver funkar tydligen med *.vbs-filer oxå... då kör jag med den...
Jo det verkar ju funka fint med:
iStatus = 0
'Notering
sNote = ""
'Pris
iPrice = 0
' Öppna databasen
Set objConn = CreateObject("ADODB.Connection")
objConn.ConnectionString = "Provider=SQLOLEDB.1;Password=XXXXX;Persist Security Info=True;User ID=sa;Initial Catalog=IntranetSydostel;Data Source=.\sqlexpress"
objConn.Open
Set objRS1 = CreateObject("ADODB.Recordset")
		objRS2.Close
		objRS2.Close
		objRS1.Movenext
	Loop
Else
	MsgBox "Fel!"
End if
objRS1.Close
MsgBox "Datat har lagrats!"
Men det känns som man gör saker i blindo.. Kan man inte få till lite räkneverk och felhantering och sådant... Så man ser vad som händer så att säga..
Henrik
Du kan skapa dig en hta om du vill.
Säg vad exakt det är du vill ha för felhantering etc. så kastar jag ihop den åt dig. :)
Men, weeeee.. du var en snäll prick! :D
Den felhanteringen jag tänkte på var om det av någon anledning inte går att skriva en post till databasen så ska inte scriptet avbrytas, utan bara få ett meddelande om att det inte gick att skriva just den posten.
Sen vet jag inte om det går att göra någon typ av dialog som visas när scriptet körs. där tex tid och antal poster visas...
..och vad betyder hta?
Henrik
HTml Application. Kort sagt är det en HTML-kodad fil som med andra säkerhetsinställningar än en html fil. Du kan designa den hur du vill egentligen med html och css samt vbscript och JScript, men utan de varningar du får i IE.
http://msdn.microsoft.com/workshop/author/hta/overview/htaoverview.asp
Aha.. okej!
lägger man vbscriptet där i då? Hmm... du får gärna visa mer...
Henrik
Här har vi en början på en hta-fil, med lite felhantering (rapporterar än så länge endast fel, inga positiva händelser). Självklart kan detta göras djupare och mer specifikt, samt kasta in en räknare etc.
Du kan ju PM:a mig lite mer information, eller kanske egen-ritade bilder på hur det ska se ut. :) Så kan vi komma fram till en lösning och sedan posta resultatet här så att folk får se det?
<html>
'*  File:         	  wF.hta
'*  Creator:	             Olle Lundberg
<title>HTA för devotion (bättre titel kommer ;) )</title>
<HTA:APPLICATION
     ID="objwF"
     APPLICATIONNAME="devotion"
     SCROLL="no"
     SINGLEINSTANCE="yes"
     WINDOWSTATE="normal"
	 MAXIMIZEBUTTON="no"
	 CAPTION="YES"
<style>
BODY
   background-color: buttonface;
   font-family: Arial;
   font-size: 8pt;
   margin-top: 10px;
   margin-left: 10px;
   margin-right: 10px;
   margin-bottom: 10px;
.button
   font-family: Helvetica;
   font-size: 8pt;
</style>
<script language="vbscript">
doLog=true
const LOG_FILE="ErrorLog.txt"
sub main()
iStatus = 0
'Notering
sNote = ""
'Pris
iPrice = 0
' Öppna databasen
On Error Resume Next
objConn.ConnectionString = "Provider=SQLOLEDB.1;Password=H74x32L;Persist Security Info=True;User ID=sa;Initial Catalog=IntranetSydostel;Data Source=.\sqlexpress"
objConn.Open
' Felhantering
if Err.Number <> 0 then
			Report(Err.Description)
			Err.Clear
			Exit Sub
' Slut felhantering
' Felhantering
			Err.Clear
' Slut felhantering
		' Felhantering
					Err.Clear
		' Slut felhantering
		' Felhantering
					Err.Clear
		' Slut felhantering
		objRS2.Close
		' Felhantering
					Err.Clear
		' Slut felhantering
		objRS2.Close
		' Felhantering
					Err.Clear
		' Slut felhantering
		' Felhantering
						Err.Clear
		' Slut felhantering
		objRS1.Movenext
	Loop
Else
	Report("Kunde inte hitta ett korrekt recordset!")
End if
objRS1.Close
On Error Goto 0
end sub
Sub Report(strMessage)
		dim FSO
		set FSO=CreateObject("Scripting.FileSystemObject")
		document.GetElementById("information").innerHTML=strMessage
		if (doLog) then
		set File=FSO.OpenTextFile(LOG_FILE, 8, -2, TRUE)
		File.Write Now()&vbCrLf&strMessage&vbcrlf&vbcrlf&_
				   "-----------------"&vbcrlf&vbcrlf
		File.close
end Sub
Sub Window_Onload
self.Focus
self.resizeTo 615,100
main
end sub
<body>
	Information:&nbsp;<span id="information"></span>
	</span>
</html>
Kopiera, klistra in i en käck textfil, och spara som *.hta
Hej igen! :)
Tack för hjälpen! :D
Jag får dock det inte att fungera ordentligt... :(
Koden ser ut så här nu:
' VB Script Document
<html>
'*  File:         	  wF.hta
<title>HTA för devotion (bättre titel kommer  )</title>
<HTA:APPLICATION
     ID="objwF"
     SCROLL="no"
	 MAXIMIZEBUTTON="no"
	 CAPTION="YES"
<style>
BODY
   font-family: Arial;
   font-size: 8pt;
   margin-top: 10px;
   margin-left: 10px;
   margin-right: 10px;
.button
   font-size: 8pt;
</style>
doLog=true
sub main()
iStatus = 0
'Notering
sNote = ""
'Pris
iPrice = 0
' Öppna databasen
objConn.Open
' Felhantering
			Err.Clear
			Exit Sub
' Slut felhantering
'Hämta nästa Id
Set objRS = objConn.Execute ("SELECT nextId FROM UppdragNu.dbo.tblNextId WHERE [table] = 'tblArticle'")
' Felhantering
			Err.Clear
' Slut felhantering
If not objRS.EOF then
	iNextId = cLng(objRS("NextId"))
objRS.Close
Set objRS = Nothing
sSQL = 		"SELECT a.articlenumber, a.articleName, a.articleUnit, l.listName " &_
			"FROM tblArticle a " &_
			"LEFT JOIN tblList l ON LEFT(a.articleNumber,2)=l.listNr " &_
			"ORDER BY a.articlenumber"
Set objRS = Server.CreateObject("ADODB.Recordset")
objRS.Open sSQL, objConn, 3, 1
' Felhantering
			Err.Clear
' Slut felhantering
	do while not objRS.EOF
		sCategory = objRS("listName")
		' Felhantering
					Err.Clear
		' Slut felhantering
		' Felhantering
					Err.Clear
		' Slut felhantering
		iNextId = iNextId + 1
		objRS.Movenext
	Loop
'Uppdatera tblNextId
sSQL = "UPDATE UppdragNu.dbo.tblNextId SET nextId = " & iNextId & " WHERE [Table] = 'tblArticle'"
Else
End if
objRS.Close
Set objRS = Nothing
[b]on Error Goto 0[/b]
end sub
		dim FSO
		if (doLog) then
		File.close
end Sub
Sub Window_Onload
self.Focus
main
end sub
<body>
	</span>
</html>
Jag har optimerat SQL-delen lite.... Det kanseke är jag som rört till det...
Men jag får Fel på Rad 155 "If förväntas"
Jag har markerat rad 155 med fetstil!
Henrik
Rad 99 och rad 109 kollar samma sak, det verkar som om du har med samma koll två gånger och missar att avsluta den ena if-satsen.
<html>
'*  File:         	  wF.hta
<HTA:APPLICATION
     ID="objwF"
     SCROLL="no"
	 MAXIMIZEBUTTON="no"
	 CAPTION="YES"
<style>
BODY
   font-family: Arial;
   font-size: 8pt;
   margin-top: 10px;
   margin-left: 10px;
   margin-right: 10px;
.button
   font-size: 8pt;
</style>
doLog=true
sub main()
iStatus = 0
'Notering
sNote = ""
'Pris
iPrice = 0
' Öppna databasen
objConn.Open
' Felhantering
			Err.Clear
			Exit Sub
' Slut felhantering
'Hämta nästa Id
' Felhantering
			Err.Clear
' Slut felhantering
objRS.Close
Set objRS = Nothing
[b][u][I]If not objRS.EOF then
[/I][/u][/b]
' Felhantering
			Err.Clear
' Slut felhantering
[/I][/u][/b]
		' Felhantering
					Err.Clear
		' Slut felhantering
		' Felhantering
					Err.Clear
		' Slut felhantering
		objRS.Movenext
	Loop
Else
End if
objRS.Close
Set objRS = Nothing
On Error Goto 0
end sub
		dim FSO
		if (doLog) then
		File.close
end Sub
Sub Window_Onload
self.Focus
main
end sub
<body>
	</span>
</html>
Jag skulle ha tagit bort den understa.
men gahhh....
Sorry... :(
copy/paste-fel....
Testar igen!
HUr fungerar felhanteringen? Lägger man sådana block efter tex sql-frågor, eller hur gör man?
Henrik
Vad du gör är att säga till att applikationen ska fortsätta köra när den stöter på ett fel (on error resume next)
Sedan kastar du in ett block som kollar om objektet Err:s egenskap, Number (när man får ett fel i vb-script får man alltid en lång harang med siffror som är förrknippat med det felmeddelandet) inte är lika med noll. (if Err.Number <> 0 then)
om den inte är det så kan man sedan göra i princip vad man vill i det if-blocket, här kastade jag in en av mina gamla log-funktioner som loggar felet.
Om du vill kan du välja att bryta den aktuella suben med Exit Sub.
Sedan i detta if-block brukar man ha för vana att nollställa err.number genom en err.clear.
Detta eftersom err-objektet fungerar som en hink, ett fel betyder att hinken är full, och då spelar det ingen roll hur mycket nytt vatten (läs fel) du försöker hälla på, det får inte plats mer förrän du har tömt hinken.
Det triggar tyvärr inte på specifika sql-fel, men det triggar på vb-script fel som har med sql-en att göra. Exempelvis så frå jag följande fel på första connect försöket mot databasen: [DBNETLIB][ConnectionOpen (Connect()).]Antingen finns inte SQL Server eller så nekas åtkomst.
Sker här:
objConn.Open
Förresten så vill du nog ta bort: Exit Sub på rad 69 då jag använde detta för att slippa köra igenom en hel radda med felaktig kod (gäller min maskin).
268 ms totalt · 3 externa anrop · v20260731065814-full.3ab8d573
131 ms — hämta forumlista (db)
124 ms — hämta statistik (db)
142 ms — hämta tråd, inlägg och bilagor (db)
