Dim SQL As String
Dim qs As String = Request.QueryString("sort")
SQL = "SELECT " & _
"tblforum.fID, tblforum.ForumName, tblPosts.pID, tblPosts.postTopic, tblposts.postText, tblPosts.postDatePosted, tblUser.uID, tblUser.userName " & _
"FROM tblUser " & _
"INNER JOIN (tblforum INNER JOIN tblPosts ON tblforum.fID = tblPosts.postForum) ON tblUser.uID = tblPosts.postUser"
If qs = "ner" Then
SQL &= " ORDER BY tblPosts.postDatePosted DESC"
ElseIf Request.QueryString("sort") = "upp" Then
SQL &= " ORDER BY tblPosts.postDatePosted"
SQL &= ";"
listforum.DataSource = sqltest(SQL, "tblUser").Tables("tblUser")
Me.DataBind
gör jag nu... men det är inte direkt smart va? med Datalist kan man ju sortera realtivt lätt(vad jag vet)...
