Veckodag från veckonummer
.NET
1 svar · 338 visningar · startad av ironhead
Medlem sedan mars 20011 346 inlägg
Kan man på något enkelt sätt få ut Måndagens & Fredagens datum utifrån ett veckonummer?
Jag använder denna kod för att få ut veckonumret
        Dim gc As GregorianCalendar = New GregorianCalendar
        Dim Week As Integer = gc.GetWeekOfYear(Datum, CalendarWeekRule.FirstFourDayWeek, DayOfWeek.Monday)
Har hittat denna funktion, men får den inte att fungera:
    Function GetFirstDayOfWeek(ByVal year As Integer, ByVal week As Integer) As Date
        Dim dateTimeFormat As DateTimeFormatInfo = Culture.CurrentCulture
        Dim cal As Calendar = dateTimeFormat.Calendar
        Dim dt As Date
        Try
            If week >= 1 AndAlso week <= 53 Then
                dt = New Date(year, 1, 1)
                dt = dt.AddDays(-7) ' Ensure that we start before the first week
                Dim weekOfYear As Integer = cal.GetWeekOfYear(dt, dateTimeFormat.CalendarWeekRule, dateTimeFormat.FirstDayOfWeek)
                While weekOfYear <> 1
                    dt = dt.AddDays(1)
                    weekOfYear = cal.GetWeekOfYear(dt, dateTimeFormat.CalendarWeekRule, dateTimeFormat.FirstDayOfWeek)
                    ' The following is a workaround for the bug described in Q200299,
                    ' which is still present in .NET
                    If weekOfYear = 53 AndAlso cal.GetWeekOfYear(dt.AddDays(7), dateTimeFormat.CalendarWeekRule, dateTimeFormat.FirstDayOfWeek) = 2 Then
                        weekOfYear = 1
                End While
                dt = dt.AddDays((week - 1) * 7)
                    weekOfYear = 1
                If weekOfYear = week Then
                    Return dt
        Catch e As Exception
        End Try
        Return Date.MinValue
    End Function
Får följande fel:
Dim dateTimeFormat As DateTimeFormatInfo = Culture.CurrentCulture <-- Property Culture is write only
Dim cal As Calendar = dateTimeFormat.Calendar <-- System.Globalization.Calendar cannot be converted to Projekt1.Calendar
cal.GetWeekOfYear <-- is not a member of Projekt1.Calendar
Nån som kan hjälpa mig?
133 ms — deklarationer (db)
124 ms — ändringar (db)
