Intsallera Microsoft SQL Server 2005
2 svar · 420 visningar · startad av weedogt
weedogtMedlem sedan mars 200427 inlägg
**Jag har försökt installera nya Microsoft SQL Server 2005, men det funkar inte. Jag har kollat i logfilerna men fattar inte riktigt vad som går fel. Kanske någon kan ge mej ett tips?
summary.txt ser ut så här:**
Microsoft SQL Server 2005 9.00.1399.06
OS Version : Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Time : Fri Nov 25 22:42:40 2005
Och så kommer det ett antal med "successful" installationer. Och sen kommer detta:
Machine : P2
Product : SQL Server Database Services
Error : An instance with the same name is already installed on this computer. To proceed with SQL Server Setup, provide a unique instance name.
Machine : P2
Machine : P2
Product : Microsoft SQL Server 2005 Express Edition
Product Version : 9.00.1399.06
Install : Failed
Log File : C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SQL.log
Last Action : DetectInstanceClash
Error String : An instance with the same name is already installed on this computer. To proceed with SQL Server Setup, provide a unique instance name.
Error Number : 28086
Machine : P2
Product : Microsoft SQL Server 2005 Tools Express Edition
Install : Successful
Log File : C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_Tools.log
SQL Server Setup failed. For more information, review the Setup log file in %ProgramFiles%\Microsoft SQL Server\90\Setup Bootstrap\LOG\Summary.txt.
List of log files:
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_Core(Local).log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SQLSupport_1.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SQLNCLI_1.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SqlWriter_1.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_MSXML6_1.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SQLSupport_2.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SQLNCLI_2.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_MSXML6_2.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_Datastore.xml
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_.NET Framework 2.0.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_Support.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_Core.log
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Summary.txt
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_SCC.log
Så här ser min "SQLSetup0011_P2-Core.log" ut:
Microsoft SQL Server 2005 Setup beginning at Fri Nov 25 22:41:49 2005
Process ID : 3500
f:\22644329947aca3bcc8446\setup.exe Version: 2005.90.1399.0
Running: LoadResourcesAction at: 2005/10/25 22:41:49
Complete: LoadResourcesAction at: 2005/10/25 22:41:49, returned true
Sen kommer det ett antal actions som slutar med "returned true".
Running: DetectLocalBootstrapAction at: 2005/10/25 22:42:37
Complete: DetectLocalBootstrapAction at: 2005/10/25 22:42:37, returned true
Running: LaunchLocalBootstrapAction at: 2005/10/25 22:42:37
Error: Action "LaunchLocalBootstrapAction" threw an exception during execution. Error information reported during run:
"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\setup.exe" finished and returned: 28086
Aborting queue processing as nested installer has completed
Message pump returning: 28086
**Här var det något som gick fel, men vad...?
Min "SQLSetup0011_P2_Core(Local).log" ser ut såhär:**
Microsoft SQL Server 2005 Setup beginning at Fri Nov 25 22:42:40 2005
Process ID : 1424
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\setup.exe Version: 2005.90.1399.0
Running: LoadResourcesAction at: 2005/10/25 22:42:40
Complete: LoadResourcesAction at: 2005/10/25 22:42:40, returned true
Sedan är det kommer ett antal actions om slutar med diverse felmedelanden.
One or more packages failed to install. Refer to logs for error details. : 28086
Error Code: 0x80076db6 (28086)
Windows Error Text: Source File Name: sqlchaining\sqlchainingactions.cpp
Compiler Timestamp: Thu Sep 1 22:23:05 2005
Function Name: sqls::ReportChainingResults::perform
Source Line Number: 3097
---- Context -----------------------------------------------
sqls::HostSetupPackageInstallerSynch::postCommit
sqls::HighlyAvailablePackage::preInstall
led due to cancel code received from cancel source: 29539
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0011_P2_.NET Framework 2.0.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0011.cab" Error Code : 2
Delay load of action "UploadDrWatsonLogAction" returned nothing. No action will occur as a result.
**Någon som har någon bra gissning på vad som går egentligen fel?
/anders**
LaspMedlem sedan juli 200010 197 inlägg
För det första så säger den ju att namnet redan finns. Den brukar lägga upp det med maskinnamn/express.
Ta bort alla tidigare försök via ta bort lägg till.
Kör på Framework2.0 som krävs, iallafall första gången, som man försöker installera SQL2005.
Kolla via tjänster om den startas eller kanske bara finns där färdig för dig.
wallabouMedlem sedan apr. 200486 inlägg
När du kör installationen så får du välja instance name, från början så står den typ bara på Default instance name, vilket är samma om du tex har sql server 2000 eller liknande på den, så tryck på valet under och skriv in något eget typ SQL2005 så ska det funka.
Genererad på 364 ms · cache AV · v20260730165559-full.f96bc7eb
