Jag körde aspnet_regsql.exe och valde att spara användarinformation för min hemsida i en databas, vid namn "VWD", som jag redan tidigare skapat och lagt till tabeller i via Visual Web Developer.
Detta fungerade väl, men då jag testar AspNetSqlProvider via "Web Site Administration Tool" händer följande:
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SqlException (0x80131904): Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.]
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +684707
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +207
System.Data.SqlClient.TdsParser.Connect(Boolean& useFailoverPartner, Boolean& failoverDemandDone, String host, String failoverPartner, String protocol, SqlInternalConnectionTds connHandler, Int64 timerExpire, Boolean encrypt, Boolean integratedSecurity, SqlConnection owningObject, Boolean aliasLookup) +890
System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance) +601
System.Data.SqlClient.SqlInternalConnectionTds..ctor(SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance) +159
System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection) +108
System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup) +27
System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +47
System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +105
System.Data.SqlClient.SqlConnection.Open() +111
System.Web.Management.SqlServices.GetSqlConnection(String server, String user, String password, Boolean trusted, String connectionString) +67
[HttpException (0x80004005): Unable to connect to SQL Server database.]
System.Web.Management.SqlServices.GetSqlConnection(String server, String user, String password, Boolean trusted, String connectionString) +123
System.Web.Management.SqlServices.SetupApplicationServices(String server, String user, String password, Boolean trusted, String connectionString, String database, String dbFileName, SqlFeatures features, Boolean install) +90
System.Web.DataAccess.SqlConnectionHelper.EnsureValidMdfFile(String fullFileName, String dataDir, String connectionString) +345
Web.config ser ut så här om det kan ha någon betydelse:
<?xml version="1.0" encoding="utf-8"?>
<configuration xmlns="http://schemas.microsoft.com/.NetConfiguration/v2.0">
</configuration>
Mappen "App_Data" är tom, vilket den inte ska vara, vad jag förstår.
:q
edit. Primary file path för databasen är, enligt Visual Web Developer: C:\Program\Microsoft SQL Server\MSSQL\Data\VWD.mdf. Jag antar att default är att den ska ligga i mappen "App_Data" -hur konfigurerar jag så att "den" förstår att databasen har den tidigare nämnda sökvägen i stället? :)
