Ta en titt på ghostscript!
pdf till jpg
5 svar · 554 visningar · startad av lucgo446
Det verkar inte finnas mkt på kombinationen GS och .net... suck...
MEN
Jag har hittat en kodsnutt som funkar på winform. behöver BARA hitta vad motsvarigheten till Clipboard är i asp.net... nån som vet?
OBS du måste ha Interop.Acrobat.dll i bin mappen
ladda ner lösningen här:
http://www.codeproject.com/dotnet/pdfthumbnail.asp
using System;
using System.IO;
using System.Drawing;
using System.Configuration;
using System.Runtime.InteropServices;
using System.Runtime.InteropServices.ComTypes;
public partial class Default2 : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
// Acrobat objects
Acrobat.CAcroPDDoc pdfDoc;
Acrobat.CAcroPDPage pdfPage;
Acrobat.CAcroRect pdfRect;
Acrobat.CAcroPoint pdfPoint;
AppSettingsReader appSettings = new AppSettingsReader();
string pdfInputPath = appSettings.GetValue("pdfInputPath", typeof(string)).ToString();
string pngOutputPath = appSettings.GetValue("pngOutputPath", typeof(string)).ToString();
string templatePortraitFile = pdfInputPath + @"\pdftemplate_portrait.gif";
string templateLandscapeFile = pdfInputPath + @"\pdftemplate_portrait.gif"; ;
try
// Get list of files to process from the input path
// Could change to read list from database instead
string[] files = Directory.GetFiles(pdfInputPath, "*.pdf");
for (int n = 0; n < files.Length; n++)
string inputFile = files[n].ToString();
string outputFile = pngOutputPath + files[n].Substring(files[n].LastIndexOf(@"\") + 1).Replace(".pdf", ".png");
/* Could skip if thumbnail already exists in output path
FileInfo fi = new FileInfo(inputFile);
if (!fi.Exists) {} */
// Create the document (Can only create the AcroExch.PDDoc object using late-binding)
// Note using VisualBasic helper functions, have to add reference to DLL in
// C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Microsoft.VisualBasic.dll
// Will always be available as .NET framework ships with all"
pdfDoc = (Acrobat.CAcroPDDoc)Microsoft.VisualBasic.Interaction.CreateObject("AcroExch.PDDoc", "");
int ret = pdfDoc.Open(inputFile);
if (ret == 0)
throw new FileNotFoundException();
// Get the number of pages (to be used later if you wanted to store that information)
int pageCount = pdfDoc.GetNumPages();
// Get the first page
pdfPage = (Acrobat.CAcroPDPage)pdfDoc.AcquirePage(0);
pdfPoint = (Acrobat.CAcroPoint)pdfPage.GetSize();
pdfRect = (Acrobat.CAcroRect)Microsoft.VisualBasic.Interaction.CreateObject("AcroExch.Rect", "");
pdfRect.Left = 0;
pdfRect.right = pdfPoint.x;
pdfRect.Top = 0;
pdfRect.bottom = pdfPoint.y;
// Render to clipboard, scaled by 100 percent (ie. original size)
// Even though we want a smaller image, better for us to scale in .NET
// than Acrobat as it would greek out small text
// see http://www.adobe.com/support/techdocs/1dd72.htm
[B]pdfPage.CopyToClipboard(pdfRect, 0, 0, 100);
IDataObject clipboardData = Clipboard.GetDataObject();[/B]
if (clipboardData.GetDataPresent(DataFormats.Bitmap))
Bitmap pdfBitmap = (Bitmap)clipboardData.GetData(DataFormats.Bitmap);
// Size of generated thumbnail in pixels
int thumbnailWidth = 45;
int thumbnailHeight = 59;
string templateFile;
// Switch between portrait and landscape
if (pdfPoint.x < pdfPoint.y)
templateFile = templatePortraitFile;
templateFile = templateLandscapeFile;
// Swap width and height (little trick not using third temp variable)
thumbnailWidth = thumbnailWidth ^ thumbnailHeight;
thumbnailHeight = thumbnailWidth ^ thumbnailHeight;
// Load the template graphic
Bitmap templateBitmap = new Bitmap(templateFile);
// Render to small image using the bitmap class
Image pdfImage = pdfBitmap.GetThumbnailImage(thumbnailWidth, thumbnailHeight,
null, IntPtr.Zero);
// Create new blank bitmap (+ 7 for template border)
Bitmap thumbnailBitmap = new Bitmap(thumbnailWidth + 7, thumbnailHeight + 7,
System.Drawing.Imaging.PixelFormat.Format32bppArgb);
// To overlayout the template with the image, we need to set the transparency
// http://www.sellsbrothers.com/writing/default.aspx?content=dotnetimagerecoloring.htm
templateBitmap.MakeTransparent();
using (Graphics thumbnailGraphics = Graphics.FromImage(thumbnailBitmap))
// Draw rendered pdf image to new blank bitmap
thumbnailGraphics.DrawImage(pdfImage, 2, 2, thumbnailWidth, thumbnailHeight);
// Draw template outline over the bitmap (pdf with show through the transparent area)
thumbnailGraphics.DrawImage(templateBitmap, 0, 0);
// Save as .png file
thumbnailBitmap.Save(outputFile, System.Drawing.Imaging.ImageFormat.Png);
Console.WriteLine("Generated thumbnail... {0}", outputFile);
pdfDoc.Close();
// Not sure how why it is to do this, but Acrobat is not the best behaved COM object
// see http://blogs.msdn.com/yvesdolc/archive/2004/04/17/115379.aspx
Marshal.ReleaseComObject(pdfPage);
Marshal.ReleaseComObject(pdfRect);
Marshal.ReleaseComObject(pdfDoc);
catch (System.Exception ex)
Console.Write(ex.ToString());
Nej det som finnes är ett rätt bra program som du med olika parametrar kan göra olika saker. T ex skapa pdf av bilder eller tvärtom. Detta program kan du med lätthet anropa från .NET
Hej Mc F
Det braiga programmet är GS menar du? då ska jag kolla upp syntax och hur man anropar det....
Det är lite pyssel med det, nån annan lösning? nån?
Det finns många .NET-komponenter för ändamålet. En som är gratis och ruggigt bra är
http://www.tallcomponents.com/Default.aspx?id=pdfthumbnail
Om du vill generera med "mer kontroll" så får du välja en annan komponent eller köra med ImageMagick + GhostScript, startat mha System.Diagnostics.Process
http://www.webforum.nu/showthread.php?t=134351
http://www.cs.wisc.edu/~ghost/
http://www.c-sharpcorner.com/Code/2002/July/ShellCommandsInCS.asp
