Skapa Virtual Directory i ASP.NET
.NET
1 svar · 258 visningar · startad av Hyzac
Medlem sedan mars 200475 inlägg
Går det att skapa ett virtual directory från en sida i asp.net?
har hittat denna kod men det funkar inte riktigt får felmeddelande att directoryEntry inte är definerad
Private Sub CreateVirtualDir(ByVal WebSite As String, ByVal AppName As String, ByVal Path As String)
        Dim IISSchema As New System.DirectoryServices.DirectoryEntry("IIS://" & WebSite & "/Schema/AppIsolated")
        Dim CanCreate As Boolean = Not IISSchema.Properties("Syntax").Value.ToString.ToUpper() = "BOOLEAN"
        IISSchema.Dispose()
        If CanCreate Then
            Dim PathCreated As Boolean
            Try
                Dim IISAdmin As New System.DirectoryServices.DirectoryEntry("IIS://" & WebSite & "/W3SVC/1/Root")
                'make sure folder exists
                If Not System.IO.Directory.Exists(Path) Then
                    System.IO.Directory.CreateDirectory(Path)
                    PathCreated = True
                'If the virtual directory already exists then delete it
                For Each VD As System.DirectoryServices.DirectoryEntry In IISAdmin.Children
                    If VD.Name = AppName Then
                        IISAdmin.Invoke("Delete", New String() {VD.SchemaClassName, AppName})
                        IISAdmin.CommitChanges()
                        Exit For
                Next VD
                'Create and setup new virtual directory
                Dim VDir As System.DirectoryServices.DirectoryEntry = IISAdmin.Children.Add(AppName, "IIsWebVirtualDir")
                VDir.Properties("Path").Item(0) = Path
                VDir.Properties("AppFriendlyName").Item(0) = AppName
                VDir.Properties("EnableDirBrowsing").Item(0) = False
                VDir.Properties("AccessRead").Item(0) = True
                VDir.Properties("AccessExecute").Item(0) = True
                VDir.Properties("AccessWrite").Item(0) = False
                VDir.Properties("AccessScript").Item(0) = True
                VDir.Properties("AuthNTLM").Item(0) = True
                VDir.Properties("EnableDefaultDoc").Item(0) = True
                VDir.Properties("DefaultDoc").Item(0) = "default.htm,default.aspx,default.asp"
                VDir.Properties("AspEnableParentPaths").Item(0) = True
                VDir.CommitChanges()
                'the following are acceptable params
                'INPROC = 0
                'OUTPROC = 1
                'POOLED = 2
                VDir.Invoke("AppCreate", 1)
            Catch Ex As Exception
                If PathCreated Then
                    System.IO.Directory.Delete(Path)
                Throw Ex
            End Try
    End Sub
Medlem sedan juli 20022 537 inlägg
Ta en titt här:
http://tant102.mine.nu/Code/Projects.aspx
275 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
134 ms — deklarationer (db)
134 ms — ändringar (db)
