Nätverksklass (går ej att starta 2 gånger)
.NET
10 svar · 323 visningar · startad av xcalibrate
Medlem sedan aug. 2002136 inlägg
Hej, jag bifogar min nätverksclass skriven i VB.NET nedan. Problemet är att jag inte kan starta 2 gånger, alltså om jag startar servern första gången så kan en användare ansluta. Stänger jag då anslutningen och försöker starta servern igen, startas den inte.
Imports System.Net
Imports System.Net.Sockets
Imports System.IO
Imports System.Text
Public Class NetworkingClass
Public Event Begin_Connect(ByVal RemoteEp As IPEndPoint)
Public Event Connect_Complete(ByVal RemoteEp As IPEndPoint)
Public Event Data_Recieved(ByVal Data As Byte(), ByVal Size As Integer)
Public Event Begin_Send(ByVal Data As Byte(), ByVal Size As Integer)
Public Event Send_Complete(ByVal Sent As Integer)
Public Event Started(ByVal Ep As IPEndPoint, ByVal Port As Integer)
Public Event Connection_Accepted(ByVal RemoteEp As IPEndPoint)
Public Event Exception(ByVal Ex As Exception)
Public Event Begin_Receive()
Public Event Closed()
Public S As New Socket(2, 1, 6)
Dim Ls As New Socket(2, 1, 6)
Private Sent As Long
Private Recv As Long
Private Est As Date
Public Sub New()
    S = New Socket(2, 1, 6)
End Sub
Private Class StateObject
    Public Worksocket As Socket = Nothing
    Public BufferSize As Integer = 1025
    Public Buffer(1025) As Byte
    Public Sb As New StringBuilder
End Class
Public ReadOnly Property DataSent() As Long
    Get
        Return Sent
    End Get
End Property
Public ReadOnly Property ConnectionEstablished() As Date
    Get
        Return Est
    End Get
End Property
Public ReadOnly Property DataRecieved() As Long
    Get
        Return Recv
    End Get
End Property
Public Sub Connect(ByVal Ip As String, ByVal Port As Integer)
    Try
        If S.Connected Then S.Close()
        S.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, 1)
        Dim Ep As New IPEndPoint(IPAddress.Parse(Ip), Port)
        S = New Socket(Ep.Address.AddressFamily, SocketType.Stream, ProtocolType.Tcp)
        Dim IpHostInfo As IPHostEntry = Dns.Resolve(Dns.GetHostName)
        Dim LocalEP As New IPEndPoint(IpHostInfo.AddressList(0), 2266)
        S.Bind(LocalEP)
        S.BeginConnect(Ep, AddressOf ConnectCallback, S)
        RaiseEvent Begin_Connect(Ep)
    Catch ex As Exception
        RaiseEvent Exception(ex)
        Debug.WriteLine(ex.ToString)
    End Try
End Sub
Public Sub ConnectCallback(ByVal Ar As IAsyncResult)
    Try
        S = CType(ar.AsyncState, Socket)
        S.EndConnect(Ar)
        BeginReceive(S)
        Dim Ep As IPEndPoint = S.RemoteEndPoint
        Est = DateAndTime.Now
        RaiseEvent Connect_Complete(Ep)
    End Try
End Sub
Public Sub BeginReceive(ByVal Socket As Socket)
    Try
        Dim State As New StateObject
        state.Worksocket = Socket
        Socket.BeginReceive(State.Buffer, 0, State.BufferSize, 0, New AsyncCallback(AddressOf ReceieveCallback), State)
        RaiseEvent Begin_Receive()
    End Try
End Sub
Public Sub ReceieveCallback(ByVal Ar As IAsyncResult)
    Try
        Dim State As StateObject = CType(Ar.AsyncState, StateObject)
        Dim Handler As Socket = State.Worksocket
        Dim Read As Integer = Handler.EndReceive(Ar)
        If Read = 0 Then
            S.Close()
            RaiseEvent Closed()
            Exit Sub
        BeginReceive(S)
        RaiseEvent Data_Recieved(State.Buffer, Read)
    End Try
End Sub
Public Sub Start(ByVal Port As Integer)
    Try
        MsgBox("start")
        Dim LocalEP As New IPEndPoint(IpHostInfo.AddressList(0), Port)
        Ls.Bind(LocalEP)
        Ls.Listen(1000)
        Ls.BeginAccept(AddressOf AcceptCallback, Ls)
        RaiseEvent Started(LocalEP, Port)
    End Try
End Sub
Public Sub AcceptCallback(ByVal Ar As IAsyncResult)
    Try
        Dim Ls As Socket = CType(Ar.AsyncState, Socket)
        S = Ls.EndAccept(Ar)
        BeginReceive(S)
    Catch sexp As SocketException
        Debug.WriteLine(sexp.ToString & vbCrLf)
    End Try
End Sub
Public Sub Send(ByVal Data As String)
    Try
        Dim Buffer(1024) As Byte
        Buffer = System.Text.ASCIIEncoding.ASCII.GetBytes(Data)
        S.BeginSend(Buffer, 0, Data.Length, 0, AddressOf SendCallback, S)
        RaiseEvent Begin_Send(Buffer, Buffer.Length)
    End Try
End Sub
Public Sub Send(ByVal Data() As Byte)
    Try
        S.BeginSend(Data, 0, Data.Length, 0, AddressOf SendCallback, S)
        RaiseEvent Begin_Send(Data, Data.Length)
    End Try
End Sub
Public Sub SendCallback(ByVal Ar As IAsyncResult)
    Try
        Dim Socket As Socket = CType(Ar.AsyncState, Socket)
        Dim BytesSent As Integer
        BytesSent = Socket.EndSend(Ar)
        RaiseEvent Send_Complete(BytesSent)
    End Try
End Sub
Public Sub Close()
    Try
        S.Shutdown(SocketShutdown.Both)
        S.Close()
        RaiseEvent Closed()
    End Try
    S = Nothing
End Sub
End Class
Försök hitta flera fel om ni kan och notera att den funkar helt bra annars, tänkte om ni hade lite tips som gör den bättre och snabbare vid sidan av mitt problem jag besrkev överst.
Använd kodtaggar, snälla. :x
Du kan inte ha två program igång som samtidigt lyssnar på samma port.
Men jag har inte två program, utan jag stänger anslutningne och försöker lyssnar igen med samma program. Det är där problemet ligger. Den lyssnar inte igen vid andra försöket efter jag stängt anslutningen första gången jag lyssnade.
Med taggar:
Imports System.Net
Imports System.IO
Imports System.Text
    Private Est As Date
    Public Sub New()
    End Sub
    End Class
        Get
            Return Sent
        End Get
    End Property
        Get
            Return Est
        End Get
    End Property
        Get
            Return Recv
        End Get
    End Property
        Try
            S.Bind(LocalEP)
        End Try
    End Sub
        Try
            S.EndConnect(Ar)
            BeginReceive(S)
        End Try
    End Sub
        Try
        End Try
    End Sub
        Try
            If Read = 0 Then
                S.Close()
                RaiseEvent Closed()
                Exit Sub
            BeginReceive(S)
        End Try
    End Sub
        Try
            MsgBox("start")
            Ls.Bind(LocalEP)
            Ls.Listen(1000)
        End Try
    End Sub
        Try
            BeginReceive(S)
        End Try
    End Sub
        Try
        End Try
    End Sub
        Try
        End Try
    End Sub
        Try
        End Try
    End Sub
    Public Sub Close()
        Try
            S.Close()
            RaiseEvent Closed()
        End Try
        S = Nothing
    End Sub
End Class
Medlem sedan maj 20021 466 inlägg
Anropa Ls.Close och Ls.Dispose för att stänga och frigöra socketens resurser. Gör du inte det kommer den att fortsätta ta emot anslutningar på den bundna porten.
Finns inget som heter Dispose under Ls eller S. Bara close
Det jag har upptäckt när jag använt mig av TCP/IP är att själva porten fortfarande är öppen ett litet tag efter det att jag har stängt min koppling.
Om jag däremot stänger ner programmet så stängs porten direkt, men stänger jag bara socketsen så är porten fortfarande öppen/låst ett litet tag till.
Varför har jag ingen anning om och jag hittade inget bra svar när jag sökte på nätet om hur man skulle göra, allt jag hittade var att det var så det fungerade med TCP/IP. Jag hittade dock ett program som alltid stängde ner sin port när socketsen stängdes, och fast jag tog den koden och körde i mitt eget program så stängdes inte porten, men likförbannat så stängdes porten i det andra programmet, märkligt...
Så jag tror inte du kan komma runt detta problem, men om du skulle hitta en lösning (min var att använd UDP :)) så får du gärna skriva svaret här, för jag är mycket intresserad av den informationen...
- M
Markus E hade rätt, eller ganska rätt, allt fungerar somd et ska nu efter jag la till Ls.Close också och Ls = Nothing, istället för att bara stänga S
Dispose ska finnas. Att sätta till Nothing gör ingenting. Dispose gör däremot att resurserna frigörs direkt istället för senare. Det är inte nödvändigt men kan vara bra att göra.
Bra att Close fungerade dock. Om du anropar Dispose kommer nog Close också att anropas.
Okej, det som är synd är ju att det inte finns nån Dispose :D
268 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
125 ms — deklarationer (db)
122 ms — ändringar (db)
