SQL, VB.NET och C# i en röra...
.NET
0 svar · 246 visningar · startad av aleborg
Jag har en DLL gjord i VB.NET där jag har dessa 2 funktionerna:
    Public Function CreateMail(ByVal dt As DataTable) As String Implements Interfaces.IContact.ICreateMail
        Dim SQL
        Dim myDataReader As OleDbDataReader
        Dim myOleDbCommand As OleDbCommand
        Try
            SQL = "SELECT ID,OrderRubrik,Ordermail,KreditRubrik,Kreditmail,FakturaRubrik,Fakturamail,PasswordRubrik,Passwordmail FROM Mallar WHERE ID=1"
            Dim da As OleDbDataAdapter = New OleDbDataAdapter(SQL.ToString(), Me.myOleDbConnection)
            Dim cmdb As New OleDb.OleDbCommandBuilder(da)
            da.UpdateCommand = cmdb.GetUpdateCommand
            ' da.InsertCommand = cmdb.GetInsertCommand
            ' da.DeleteCommand = cmdb.GetDeleteCommand
            da.Update(dt)
            Me.myOleDbConnection.Close()
            Return "OK"
        Catch ex As Exception
            Return ex.ToString()
        End Try
    End Function
    Public Function GetMail() As DataTable Implements Interfaces.IContact.IGetMail
        Dim SQL
        Dim mdt As DataTable = New DataTable
        mdt.Clear()
        Try
            Me.myOleDbConnection.Open()
            da.Fill(mdt)
            Return mdt
            Return mdt
        End Try
    End Function
Sen har jag i ett program gjort i C# den här koden:
		private void btnSave_Click(object sender, System.EventArgs e)
			IContact cc;
			cc=(IContact)Activator.GetObject(typeof(IContact),ConfigurationSettings.AppSettings["Contact"].ToString());
			DataTable dt = new DataTable();
			dt.Columns.Add("ID", typeof(int));
			dt.Columns.Add("OrderRubrik", typeof(string));
			dt.Columns.Add("Ordermail", typeof(string));
			dt.Columns.Add("KreditRubrik", typeof(string));
			dt.Columns.Add("Kreditmail", typeof(string));
			dt.Columns.Add("FakturaRubrik", typeof(string));
			dt.Columns.Add("Fakturamail", typeof(string));
			dt.Columns.Add("PasswordRubrik", typeof(string));
			dt.Columns.Add("Passwordmail", typeof(string));
            DataRow dr = dt.NewRow();
			dr["ID"] = 1;
			dr["OrderRubrik"] = txtOrderRubrik.Text;
			dr["Ordermail"] = txtOrderText.Text;
			dr["KreditRubrik"] = txtKreditRubrik.Text;
			dr["Kreditmail"] = txtKreditText.Text;
			dr["FakturaRubrik"] = txtFakturaRubrik.Text;
			dr["Fakturamail"] = txtFakturaText.Text;
			dr["PasswordRubrik"] = txtPasswordRubrik.Text;
			dr["Passwordmail"] = txtPasswordText.Text;
			dt.Rows.Add(dr);
			txtFakturaText.Text =cc.ICreateMail(dt);
		private void Epostmallar_Load(object sender, System.EventArgs e)
			IContact cc;
			dt = cc.IGetMail();
			foreach(DataRow dr in dt.Rows)
				txtFakturaRubrik.Text = dr["FakturaRubrik"].ToString();
				txtFakturaText.Text = dr["Fakturamail"].ToString();
				txtOrderRubrik.Text = dr["OrderRubrik"].ToString();
				txtOrderText.Text = dr["Ordermail"].ToString();
				txtKreditRubrik.Text = dr["KreditRubrik"].ToString();
				txtKreditText.Text = dr["Kreditmail"].ToString();
				txtPasswordRubrik.Text = dr["PasswordRubrik"].ToString();
				txtPasswordText.Text = dr["Passwordmail"].ToString();
Det funkar fint att hämta infon men när jag sen ska uppdatera sparas en ny post i databasen istället för att uppdatera.
Kan inte förstå varför, någon som har ett tips?
267 ms totalt · 4 externa anrop · v20260731065814-full.2f471f9e
125 ms — deklarationer (db)
122 ms — ändringar (db)
