class till xsd?
.NET
2 svar · 279 visningar · startad av Walker
Medlem sedan okt. 2002188 inlägg
Hej
Har hittat en del verktyg som konverterar xsd filer till c# klasser, men jag undrar om det finns någon som hittat ett verktyg som går andra vägen. dvs skapar xsd filer utifrån klasser.
/w
Medlem sedan sep. 20011 914 inlägg
XML Schema Definition Tool (Xsd.exe) borde klara det.
Xsd.exe performs the following operations:
XDR to XSD
Generates an XML schema from an XML-Data-Reduced schema file. XDR is an early XML-based schema format.
XML to XSD
Generates an XML schema from an XML file.
XSD to DataSet
Generates common language runtime DataSet classes from an XSD schema file. The generated classes provide a rich object model for regular XML data.
XSD to Classes
Generates runtime classes from an XSD schema file. The generated classes can be used in conjunction with System.XML.Serialization.XMLSerializer to read and write XML code that follows the schema.
Classes to XSD
Generates an XML schema from a type or types in a runtime assembly file. The generated schema defines the XML format used by System.XML.Serialization.XMLSerializer.
Xsd.exe only allows you to manipulate XML schemas that follow the XML Schema Definition (XSD) language proposed by the World Wide Web Consortium (W3C). For more information on the XML Schema Definition proposal or the XML standard, see http://w3.org.
Stämmer bra det.. Tackar
258 ms totalt · 4 externa anrop · v20260731065814-full.868a69e5
124 ms — deklarationer (db)
120 ms — ändringar (db)
