Filhantera i datagrid - laddar inte om!?
.NET
4 svar · 343 visningar · startad av Griphem
Medlem sedan apr. 200422 inlägg
Jag har hittat ett fint script som bygger en datagrid från filer i en mapp - det fungerar utmärkt men...
... när man har tryckt på delete så måste man ladda om sidan manuellt för att se resultatet. Vad är det jag glömt?
<%@ Import Namespace="System.IO" %>
<script language="VB" runat="server">
  Sub Page_Load(sender as Object, e as EventArgs)
    If Not Page.IsPostBack then
      Dim dirInfo as New DirectoryInfo(Server.MapPath(""))
      articleList.DataSource = dirInfo.GetFiles("*.pdf")
      articleList.DataBind()
  End Sub
  Sub articleList_ItemDataBound(sender as Object, e as DataGridItemEventArgs)
    ' First, make sure we're NOT dealing with a Header or Footer row
    If e.Item.ItemType <> ListItemType.Header AND _
         e.Item.ItemType <> ListItemType.Footer then
      'Now, reference the Button control that the Delete ButtonColumn
      'has been rendered to
      Dim deleteButton as Button = e.Item.Cells(0).Controls(0)
      'We can now add the onclick event handler
      deleteButton.Attributes("onclick") = "javascript:return " & _
                 "confirm('Are you sure you want to delete the file " & _
                 DataBinder.Eval(e.Item.DataItem, "Name") & "?')"
  End Sub
  Sub articleList_DeleteFile(sender as Object, e as DataGridCommandEventArgs)
    'First, get the filename to delete
    Dim fileName as String = articleList.DataKeys(e.Item.ItemIndex)
	File.Delete(fileName)
    'lblMessage.Text = "You opted to delete the file " & _
        'fileName & ".<br />" & _
        '"This file could be deleted by calling: " & _
        '"<code>File.Delete(fileName)</code><p>"
    'You would want to rebind the Directory's files to the DataGrid after
    'deleting the file...
  End Sub
:D Nicklas
Medlem sedan apr. 2004778 inlägg
Där det står
"'You would want to rebind the Directory's files to the DataGrid after
'deleting the file..."
måste du lägga in funktionaliteten för att binda din DataGrid igen.
ja...
...och hur kan man förklara det för en räka som mig?
(Jag har jobbat med ASP tidigare och detta med ASP.NET är lite vanskligt för mig.)
I din Page_Load databinder du med
Använd samma tre rader sist i din delete funktion.
Man kan även lägga de tre raderna i en egen funktion, t.ex. BindGrid() och ropa på den funktionen både i Page_Load och Delete.
Japp - det löste det hela - då har jag lärt mig något nytt idag!
Tack! Djupbugande Jag! :L
130 ms — deklarationer (db)
119 ms — ändringar (db)
