Finns det en kalender som denna gjord i javascript http://www.srrs.org/ (den till höger på sidan) och isåfall var kan jag hitta en sådan.
Tack i förhand.
9 svar · 813 visningar · startad av mr.mainline
Tack i förhand.
En i javascript hittar du här: http://webfx.eae.net/dhtml/datepicker/datepicker.html
tack men gärna fler förslag.
Kan någon hjälpa mig att få igång detta javascript
Förklara på ett enkelt sätt :-))
<!-- TWO STEPS TO INSTALL THIS SCRIPT -->
<!-- STEP ONE: Place the following script into a separate JavaScript file called: calendar.js -->
<!-- This script and many more are available free online at -->
<!-- The JavaScript Source!! http://javascript.internet.com -->
<!-- Begin
// SET ARRAYS
var day_of_week = new Array('Sun','Mon','Tue','Wed','Thu','Fri','Sat');
var month_of_year = new Array('January','February','March','April','May','June','July','August','September','October','November','December');
// DECLARE AND INITIALIZE VARIABLES
var Calendar = new Date();
var year = Calendar.getYear(); // Returns year
var month = Calendar.getMonth(); // Returns month (0-11)
var today = Calendar.getDate(); // Returns day (1-31)
var weekday = Calendar.getDay(); // Returns day (1-31)
var DAYS_OF_WEEK = 7; // "constant" for number of days in a week
var DAYS_OF_MONTH = 31; // "constant" for number of days in a month
var cal; // Used for printing
Calendar.setDate(1); // Start the calendar day at '1'
Calendar.setMonth(month); // Start the calendar month at now
/* VARIABLES FOR FORMATTING
NOTE: You can format the 'BORDER', 'BGCOLOR', 'CELLPADDING', 'BORDERCOLOR'
tags to customize your caledanr's look. */
var TR_start = '<TR>';
var TR_end = '</TR>';
var highlight_start = '<TD WIDTH="30"><TABLE CELLSPACING=0 BORDER=1 BGCOLOR=DEDEFF BORDERCOLOR=CCCCCC><TR><TD WIDTH=20><B><CENTER>';
var highlight_end = '</CENTER></TD></TR></TABLE></B>';
var TD_start = '<TD WIDTH="30"><CENTER>';
var TD_end = '</CENTER></TD>';
/* BEGIN CODE FOR CALENDAR
tags to customize your calendar's look.*/
cal = '<TABLE BORDER=1 CELLSPACING=0 CELLPADDING=0 BORDERCOLOR=BBBBBB><TR><TD>';
cal += '<TABLE BORDER=0 CELLSPACING=0 CELLPADDING=2>' + TR_start;
cal += '<TD COLSPAN="' + DAYS_OF_WEEK + '" BGCOLOR="#EFEFEF"><CENTER><B>';
cal += month_of_year[month] + ' ' + year + '</B>' + TD_end + TR_end;
cal += TR_start;
// DO NOT EDIT BELOW THIS POINT //
// LOOPS FOR EACH DAY OF WEEK
for(index=0; index < DAYS_OF_WEEK; index++)
// BOLD TODAY'S DAY OF WEEK
if(weekday == index)
cal += TD_start + '<B>' + day_of_week[index] + '</B>' + TD_end;
// PRINTS DAY
cal += TD_start + day_of_week[index] + TD_end;
cal += TD_end + TR_end;
cal += TR_start;
// FILL IN BLANK GAPS UNTIL TODAY'S DAY
for(index=0; index < Calendar.getDay(); index++)
cal += TD_start + ' ' + TD_end;
// LOOPS FOR EACH DAY IN CALENDAR
for(index=0; index < DAYS_OF_MONTH; index++)
if( Calendar.getDate() > index )
// RETURNS THE NEXT DAY TO PRINT
week_day =Calendar.getDay();
// START NEW ROW FOR FIRST DAY OF WEEK
if(week_day == 0)
cal += TR_start;
if(week_day != DAYS_OF_WEEK)
// SET VARIABLE INSIDE LOOP FOR INCREMENTING PURPOSES
var day = Calendar.getDate();
// HIGHLIGHT TODAY'S DATE
if( today==Calendar.getDate() )
cal += highlight_start + day + highlight_end + TD_end;
// PRINTS DAY
cal += TD_start + day + TD_end;
// END ROW FOR LAST DAY OF WEEK
if(week_day == DAYS_OF_WEEK)
cal += TR_end;
// INCREMENTS UNTIL END OF THE MONTH
Calendar.setDate(Calendar.getDate()+1);
}// end for loop
cal += '</TD></TR></TABLE></TABLE>';
// PRINT CALENDAR
document.write(cal);
// End -->
<!-- STEP TWO: Place this into the BODY of the HTML document where you want the calendar -->
<!-- Make sure the '.js' and '.html' files are in the same directory. -->
<BODY>
<SCRIPT SRC="calendar.js"></SCRIPT>
<p><center>
<font face="arial, helvetica" size"-2">Free JavaScripts provided<br>
by <a href="http://javascriptsource.com">The JavaScript Source</a></font>
</center><p>
<!-- Script Size: 4.15 KB -->
Till att börja med får du gärna kasta in lite [kod]-taggar, så man kan läsa koden utan att bli självmordsbenägen.
mvh
(Försök att hålla ihop trådar med samma fråga. Det blir enklare att följa diskussionen då. Trådarna ihopslagna)
// This script and many more are available free online at
// The JavaScript Source!! [url]http://javascript.internet.com[/url]
// SET ARRAYS
cal += TR_start;
// PRINTS DAY
cal += TR_start;
if(week_day == 0)
cal += TR_start;
// PRINTS DAY
cal += TR_end;
}// end for loop
// PRINT CALENDAR
... bara att klistra in det som ligger i kod-blockat på din sida där du vill ha kalendern.
jag är nybörjare,vilket är kod-blockat??
ok,nu är det fixat,kan jag ändra storleken på kalendern ?
Scriptet är inte skrivet för att du enkelt skall kunna göra det med en variabel, men du hittar width=... på 3 ställen i scriptet. Öka dessa värden med X.
