Långsammare?
3 svar · 164 visningar · startad av hajdo
hajdoMedlem sedan nov. 2003169 inlägg
Hej, jag ska använda ett script som gör att det regnar ner snö från sidan och jag undrar hur man kan göra så att snön går långsammare, jag kollade men hittade inte vart...
<script language="JavaScript1.2">
Snow Effect Script
Created and submitted by Altan d.o.o. (snow@altan.hr, http://www.altan.hr/snow/index.html)
Permission granted to Dynamicdrive.com to feature script in archive
For full source code and installation instructions to this script, visit http://dynamicdrive.com
Comes from http://kallabananer.cjb.net
//Configure below to change URL path to the snow image
var snowsrc="snow.gif"
// Configure below to change number of snow to render
var no = 5;
var ns4up = (document.layers) ? 1 : 0; // browser sniffer
var ie4up = (document.all) ? 1 : 0;
var dx, xp, yp; // coordinate and position variables
var am, stx, sty; // amplitude and step variables
var i, doc_width = 800, doc_height = 600;
if (ns4up) {
doc_width = self.innerWidth;
doc_height = self.innerHeight;
} else if (ie4up) {
doc_width = document.body.clientWidth;
doc_height = document.body.clientHeight;
dx = new Array();
xp = new Array();
yp = new Array();
am = new Array();
stx = new Array();
sty = new Array();
for (i = 0; i < no; ++ i) {
dx *= 0; // set coordinate variables
xp *= Math.random()*(doc_width-50); // set position variables
yp *= Math.random()*doc_height;
am *= Math.random()*20; // set amplitude variables
stx *= 0.02 + Math.random()/10; // set step variables
sty *= 0.7 + Math.random(); // set step variables
if (ns4up) { // set layers
if (i == 0) {
document.write("<layer name=\"dot"+ i +"\" left=\"15\" top=\"15\" visibility=\"show\"><a href=\"http://dynamicdrive.com/\\"><img src='"+snowsrc+"' border=\"0\"></a></layer>");
} else {
document.write("<layer name=\"dot"+ i +"\" left=\"15\" top=\"15\" visibility=\"show\"><img src='"+snowsrc+"' border=\"0\"></layer>");
} else if (ie4up) {
if (i == 0) {
document.write("<div id=\"dot"+ i +"\" style=\"POSITION: absolute; Z-INDEX: "+ i +"; VISIBILITY: visible; TOP: 15px; LEFT: 15px;\"><a href=\"http://dynamicdrive.com\"><img src='"+snowsrc+"' border=\"0\"></a></div>");
} else {
document.write("<div id=\"dot"+ i +"\" style=\"POSITION: absolute; Z-INDEX: "+ i +"; VISIBILITY: visible; TOP: 15px; LEFT: 15px;\"><img src='"+snowsrc+"' border=\"0\"></div>");
function snowNS() { // Netscape main animation function
for (i = 0; i < no; ++ i) { // iterate for every dot
yp += sty;
if (yp *> doc_height-50) {
xp = Math.random()*(doc_width-am-30);
yp *= 0;
stx = 0.02 + Math.random()/10;
sty = 0.7 + Math.random();
dx += stx;
document.layers["dot"+i].top = yp
document.layers["dot"+i].left = xp + am*Math.sin(dx
setTimeout("snowNS()", 10);
function snowIE() { // IE main animation function
yp += sty;
yp *= 0;
dx += stx;
document.all["dot"+i].style.pixelTop = yp
document.all["dot"+i].style.pixelLeft = xp + am*Math.sin(dx
setTimeout("snowIE()", 10);
if (ns4up) {
snowNS();
} else if (ie4up) {
snowIE();
</script>**********************************
Kan nån skriva om den så den går långsammare? skulle va schyyst...
På följande två rader:
och
kan du ändra 10 till ett större tal för att det ska snöa långsammare.
Fett bra, tack. Men det är också så att snön försvinner halvägs ner på skärmen, hur kan man fixa det?
Utan att ha tittat speciellt noggrant på koden skulle jag säga till dig att ändra i denna rad:
Förmodligen är det doc_width och doc_height som bestämmer var snöflingorna ska kunna placeras.
