hover länk
3 svar · 183 visningar · startad av MizzK
MizzKMedlem sedan juni 2003410 inlägg
jag undrar nu hur jag skall göra för att få en bild att komma fram när jag drar musen över den samt att bilden skall synsas när länken är aktiv.. fått ett svar i html forumet, men fungerar inte med denna menyn, vill veta hur jag gör i javascript..
var active=null,_oE=null;
var subMenus=[
	["sub1","cat","prog"],
	["sub2","cat","for"],
	["sub3","cat","vip"],
	["sub4","cat","noll"],
	["sub5","cat","lank"],
	["sub6","cat","kont"]
function getElm(e){
	switch(true){
	case typeof(document.all)=="object":
		return document.all[e];
	case typeof(document.getElementById)=="function":
		return document.getElementById(e);
	default:
		return null;
function showHide(s){
	var e=getElm(s);
	if(!e){
		return true;
	if(active&&active!=e.id){
		var oE=getElm(active);
		if(document.all){
			oE.nextSibling.style.display=(window.opera)?"table-row":"block";
		} else {
			oE.nextSibling.nextSibling.style.display="table-row";
		oE.style.display="none";
	else if(!active&&find()){
		var i=subMenus.length;
		while(i-->0){
			if(e==getElm(subMenus[i][0])){
				if(document.all){
					_oE.nextSibling.style.display=(window.opera)?"table-row":"block";
				} else {
					_oE.nextSibling.nextSibling.style.display="table-row";
				continue;
			} else {
				getElm(subMenus[i][0]).style.display="none";
	if(e.style.display==""||e.style.display=="none"){
		if(document.all){
			e.style.display=(window.opera)?"table-row":"block";
			e.nextSibling.style.display="none";
		} else {
			e.style.display="table-row";
			e.nextSibling.nextSibling.style.display="none";
	} else {
		if(document.all){
			e.nextSibling.style.display=(window.opera)?"table-row":"block";
		} else {
			e.nextSibling.nextSibling.style.display="table-row";
		e.style.display="none";
	active=e.id;
	return false;
function find(){
	if(subMenus.length<1 || location.search.indexOf("cat=")<1 || location.search.indexOf("cat=pics")>0){
		return 0;
	var
		o=subMenus,
		i=o.length,
		l=location.search;
	while(i-->0){
		if(l.indexOf(o[i][1])>0){
			if(l.split(o[i][1])[1].indexOf(o[i][2])>0){
				_oE=getElm(o[i][0]);
				if(document.all){
					_oE.style.display=(window.opera)?"table-row":"block";
					_oE.nextSibling.style.display="none";
				} else {
					_oE.style.display="table-row";
					_oE.nextSibling.nextSibling.style.display="none";
				continue;
		getElm(o[i][0]).style.display="none";
	return 1;
window.onload=function(){
	find();
var a=document.getElementsByTagName("a");
for (var i=0;i<a.length;i++){
if(a[i].href.substring(a[i].href.lastIndexOf("/")+1)==location.href.substring(location.href.lastIndexOf("/")+1)){
a[i].style.textDecoration="underline";
ps. just nu är det underline på länken, men detta är ej nödvändigt..
värt att tillägga är kanske att jag har försökt med css men det fungerar tydligen inte med mitt script..
ChoronzonMedlem sedan aug. 20011 346 inlägg
tack men det fungerade inte för mig...
