HeHe
Här kommer koden FÖR ATT STÄLLA IN MENYN.
Det finns en till fil, men den är NOG inte nödvändig här, efter som alla inställningar sker här:
var NoOffFirstLineMenus=5; // Number of main menu items
// Colorvariables:
// Color variables take HTML predefined color names or "#rrggbb" strings
//For transparency make colors and border color ""
var LowBgColor="#4F85F3"; // Background color when mouse is not over
var HighBgColor="#3F6FDD"; // Background color when mouse is over
var FontLowColor="#FFFFFF"; // Font color when mouse is not over
var FontHighColor="#DAD8D8"; // Font color when mouse is over
var BorderColor="#4F85F3"; // Border color
var BorderWidthMain=0; // Border width main items
var BorderWidthSub=0; // Border width sub items
var BorderBtwnMain=0; // Border between elements main items 1 or 0
var BorderBtwnSub=0; // Border between elements sub items 1 or 0
var FontFamily="comic sans ms,technical,arial"; // Font family menu items
var FontSize=10; // Font size menu items
var FontBold=0; // Bold menu items 1 or 0
var FontItalic=0; // Italic menu items 1 or 0
var MenuTextCentered="center"; // Item text position left, center or right
var MenuCentered="center"; // Menu horizontal position can be: left, center, right, justify,
// leftjustify, centerjustify or rightjustify. PartOfWindow determines part of window to use
var MenuVerticalCentered="static"; // Menu vertical position top, middle,bottom or static
var ChildOverlap=.2; // horizontal overlap child/ parent
var ChildVerticalOverlap=.2; // vertical overlap child/ parent
var StartTop=0; // Menu offset x coordinate. If StartTop is between 0 and 1 StartTop is calculated as part of windowheight
var StartLeft=0; // Menu offset y coordinate. If StartLeft is between 0 and 1 StartLeft is calculated as part of windowheight
var VerCorrect=0; // Multiple frames y correction
var HorCorrect=0; // Multiple frames x correction
var LeftPaddng=3; // Left padding
var TopPaddng=2; // Top padding
var FirstLineHorizontal=1; // First level items layout horizontal 1 or 0
var MenuFramesVertical=0; // Frames in cols or rows 1 or 0
var DissapearDelay=100; // delay before menu folds in
var UnfoldDelay=100; // delay before sub unfolds
var TakeOverBgColor=1; // Menu frame takes over background color subitem frame
var FirstLineFrame="MyFrameOne"; // Frame where first level appears
var SecLineFrame="MyFrameTwo"; // Frame where sub levels appear
var DocTargetFrame="MyFrameTwo"; // Frame where target documents appear
var TargetLoc=""; // span id for relative positioning
var MenuWrap=1; // enables/ disables menu wrap 1 or 0
var RightToLeft=0; // enables/ disables right to left unfold 1 or 0
var BottomUp=0; // enables/ disables Bottom up unfold 1 or 0
var UnfoldsOnClick=0; // Level 1 unfolds onclick/ onmouseover
var BaseHref=""; // BaseHref lets you specify the root directory for relative links.
// The script precedes your relative links with BaseHref
// For instance:
// when your BaseHref= "http://www.MyDomain/" and a link in the menu is "subdir/MyFile.htm",
// the script renders to: "http://www.MyDomain/subdir/MyFile.htm"
// Can also be used when you use images in the textfields of the menu
// "MenuX=new Array("<img src=\""+BaseHref+"MyImage\">"
// For testing on your harddisk use syntax like: BaseHref="file:///C|/MyFiles/Homepage/"
var Arrws=[BaseHref+"tri.gif",5,10,BaseHref+"tridown.gif",10,5,BaseHref+"trileft.gif",5,10,BaseHref+"triup.gif",10,5];
// Arrow source, width and height.
// If arrow images are not needed keep source ""
var MenuUsesFrames=1; // MenuUsesFrames is only 0 when Main menu, submenus,
// document targets and script are in the same frame.
// In all other cases it must be 1
var RememberStatus=0; // RememberStatus: When set to 1, menu unfolds to the presetted menu item.
// When set to 2 only the relevant main item stays highligthed
// The preset is done by setting a variable in the head section of the target document.
// <head>
// <script type="text/javascript">var SetMenu="2_2_1";</script>
// </head>
// 2_2_1 represents the menu item Menu2_2_1=new Array(.......
var PartOfWindow=.8; // PartOfWindow: When MenuCentered is justify, sets part of window width to stretch to
// Below some pretty useless effects, since only IE6+ supports them
// I provided 3 effects: MenuSlide, MenuShadow and MenuOpacity
// If you don't need MenuSlide just leave in the line var MenuSlide="";
// delete the other MenuSlide statements
// In general leave the MenuSlide you need in and delete the others.
// Above is also valid for MenuShadow and MenuOpacity
// You can also use other effects by specifying another filter for MenuShadow and MenuOpacity.
// You can add more filters by concanating the strings
var BuildOnDemand=0; // 1/0 When set to 1 the sub menus are build when the parent is moused over
var MenuSlide="";
var MenuSlide="progid:DXImageTransform.Microsoft.RevealTrans(duration=.5, transition=19)";
var MenuSlide="progid:DXImageTransform.Microsoft.GradientWipe(duration=.5, wipeStyle=1)";
var MenuShadow="";
var MenuOpacity="";
var MenuOpacity="progid:DXImageTransform.Microsoft.Alpha(opacity=75)";
function BeforeStart(){return}
function AfterBuild(){return}
function BeforeFirstOpen(){return}
function AfterCloseAll(){return}
// Menu tree:
// MenuX=new Array("ItemText","Link","background image",number of sub elements,height,width,"bgcolor","bghighcolor",
// "fontcolor","fonthighcolor","bordercolor","fontfamily",fontsize,fontbold,fontitalic,"textalign","statustext");
// Color and font variables defined in the menu tree take precedence over the global variables
// Fontsize, fontbold and fontitalic are ignored when set to -1.
// For rollover images ItemText format is: "rollover?"+BaseHref+"Image1.jpg?"+BaseHref+"Image2.jpg"
Menu1=new Array("Hem","file.htm","",0,20,100,"","","","","","",-1,-1,-1,"","Gå Till Första Sidan.");
Menu2=new Array("Installation","","",5,20,100,"","","","","","",-1,-1,-1,"","Installation");
Menu2_1=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under1");
Menu2_2=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under2");
Menu2_3=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under3");
Menu2_4=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under4");
Menu2_5=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under5");
Menu3=new Array("Datateknik","","",5,20,100,"","","","","","",-1,-1,-1,"","Datateknik");
Menu3_1=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under1");
Menu3_2=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under2");
Menu3_3=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under3");
Menu3_4=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under4");
Menu3_5=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under5");
Menu4=new Array("Elektronik","","",5,20,100,"","","","","","",-1,-1,-1,"","Elektronikn");
Menu4_1=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under1");
Menu4_2=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under2");
Menu4_3=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under3");
Menu4_4=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under4");
Menu4_5=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under5");
Menu5=new Array("Automation","","",5,20,100,"","","","","","",-1,-1,-1,"","Automation");
Menu5_1=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under1");
Menu5_2=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under2");
Menu5_3=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under3");
Menu5_4=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under4");
Menu5_5=new Array("Under1","","",0,20,100,"","","","","","",-1,-1,-1,"","Under5");
Lycka Till ; ))
