Fotot STAB.jpg visas som det ska på datorn, men syns inte när jag lagt ut på Internet.
Någon som kan förklara varför?
Det löste sig! Hade fått med gemener på ett ställe och versaler på ett annat...
Första delen av scriptet ser ut såhär:
<!-- Beginning of JavaScript -
// CREDITS:
// PeopleMarker by Urs Dudli and Peter Gehrig
// Copyright (c) 2000 Peter Gehrig and Urs Dudli. All rights reserved.
// Permission given to use the script provided that this notice remains as is.
// Additional scripts can be found at http://www.24fun.com.
// info@24fun.ch
// 7/14/2000
// the url of your image (in this sample the people-picture)
var imgurl="ame/images/personal/stab.jpg"
// the url of your marker-image (in this sample it's a transparent circle)
var markerurl="images/circlemarker.gif"
// set the horizontal position of the image (distance to the left margin of the window, pixels)
var x_imgposition=130
// set the vertical position of the image (distance to the top margin of the window, pixels)
var y_imgposition=140
// do not edit the variables below
var preloadimgurl=new Image()
preloadimgurl.src=imgurl
var preloadmarkerurl=new Image()
preloadmarkerurl.src=markerurl
var isloaded=false
function initiate() {
if(document.all) {
yourimage.innerHTML="<img src="+imgurl+">"
document.all.yourimage.style.posLeft=x_imgposition
document.all.yourimage.style.posTop=y_imgposition
markerimage.innerHTML="\<img src="+markerurl+"\>"
document.all.markerimage.style.posLeft=x_imgposition
document.all.markerimage.style.posTop=y_imgposition
isloaded=true
if(document.layers) {
document.yourimage.document.write("\<img src="+imgurl+"\>")
document.yourimage.document.close()
document.yourimage.left=x_imgposition
document.yourimage.top=y_imgposition
document.markerimage.document.write("\<img src="+markerurl+"\>")
document.markerimage.document.close()
document.markerimage.left=x_imgposition
document.markerimage.top=y_imgposition
isloaded=true
function setmarkerto(x_pos,y_pos) {
if(document.all && isloaded) {
var x_marker=eval(x_pos)+eval(x_imgposition)
var y_marker=eval(y_pos)+eval(y_imgposition)
document.all.markerimage.style.posLeft=x_marker
document.all.markerimage.style.posTop=y_marker
if(document.layers && isloaded) {
document.markerimage.left=x_marker
document.markerimage.top=y_marker
// - End of JavaScript - -->
