Vad är fel:
<script language="JavaScript1.2">
Pausing updown message scroller-
© Dynamic Drive (https://www.dynamicdrive.com)
For full source code, installation instructions,
Terms Of Use, visit http://www.dynamicdrive.com
//configure the below five variables to change the style of the scroller
var scrollerwidth=165
var scrollerheight=150
var scrollerbgcolor='333333'
//set below to '' if you don't wish to use a background image
var scrollerbackground='scrollerback.gif'
//configure the below variable to change the contents of the scroller
var messages=new Array()
messages[0]="<font face='Arial''>Sidan är uppdaterad 03-03-05</a></font>"
messages[1]="<font face='Arial'>Sportfiske mässa den 29-30 mars i Strömsnäsbruk</a></font>"
messages[2]="<font face='Arial'>Jag och broder Richard åker till Frankrike Etang de la horre den 18 April</a></font>"
messages[3]="<font face='Arial'>Swedish carp challenge i Vittsjön den 25-28 september</a></font>"
messages[4]="<font face='Arial'><a href='http://www.mikaeljohansson.com/sportfishingpages/sporting'target=">Sporting har en ny sida på Sportfishingpages</a></font>"
///////Do not edit pass this line///////////////////////
var ie=document.all&&navigator.userAgent.indexOf("Opera")==-1
var dom=document.getElementById&&navigator.userAgent.indexOf("Opera")==-1
if (messages.length>2)
i=2
i=0
function move1(whichlayer){
tlayer=eval(whichlayer)
if (tlayer.top>0&&tlayer.top<=5){
tlayer.top=0
setTimeout("move1(tlayer)",3000)
setTimeout("move2(document.main.document.second)",3000)
return
if (tlayer.top>=tlayer.document.height*-1){
tlayer.top-=5
setTimeout("move1(tlayer)",50)
else{
tlayer.top=scrollerheight
tlayer.document.write(messages*)
tlayer.document.close()
if (i==messages.length-1)
i=0
i++
function move2(whichlayer){
tlayer2=eval(whichlayer)
if (tlayer2.top>0&&tlayer2.top<=5){
tlayer2.top=0
setTimeout("move2(tlayer2)",3000)
setTimeout("move1(document.main.document.first)",3000)
return
if (tlayer2.top>=tlayer2.document.height*-1){
tlayer2.top-=5
setTimeout("move2(tlayer2)",50)
else{
tlayer2.top=scrollerheight
tlayer2.document.write(messages*)
tlayer2.document.close()
i=0
i++
function move3(whichdiv){
tdiv=eval(whichdiv)
if (parseInt(tdiv.style.top)>0&&parseInt(tdiv.style.top)<=5){
tdiv.style.top=0
setTimeout("move3(tdiv)",3000)
setTimeout("move4(second2_obj)",3000)
return
if (parseInt(tdiv.style.top)>=tdiv.offsetHeight*-1){
tdiv.style.top=parseInt(tdiv.style.top)-5
setTimeout("move3(tdiv)",50)
else{
tdiv.style.top=scrollerheight
tdiv.innerHTML=messages
*if (i==messages.length-1)
i=0
i++
function move4(whichdiv){
tdiv2=eval(whichdiv)
if (parseInt(tdiv2.style.top)>0&&parseInt(tdiv2.style.top)<=5){
tdiv2.style.top=0
setTimeout("move4(tdiv2)",3000)
setTimeout("move3(first2_obj)",3000)
return
if (parseInt(tdiv2.style.top)>=tdiv2.offsetHeight*-1){
tdiv2.style.top=parseInt(tdiv2.style.top)-5
setTimeout("move4(second2_obj)",50)
else{
tdiv2.style.top=scrollerheight
tdiv2.innerHTML=messages
i=0
i++
function startscroll(){
if (ie||dom){
first2_obj=ie? first2 : document.getElementById("first2")
second2_obj=ie? second2 : document.getElementById("second2")
move3(first2_obj)
second2_obj.style.top=scrollerheight
second2_obj.style.visibility='visible'
else if (document.layers){
document.main.visibility='show'
document.main.document.second.top=scrollerheight+5
document.main.document.second.visibility='show'
window.onload=startscroll
<ilayer id="main" width=&{scrollerwidth}; height=&{scrollerheight}; bgColor=&{scrollerbgcolor}; background=&{scrollerbackground}; visibility=hide>
<layer id="first" left=0 top=1 width=&{scrollerwidth};>
document.write(messages[0])
</layer>
<layer id="second" left=0 top=0 width=&{scrollerwidth}; visibility=hide>
document.write(messages[dyndetermine=(messages.length==1)? 0 : 1])
</layer>
</ilayer>
if (ie||dom){
document.writeln('<div id="main2" style="position:relative;width:'+scrollerwidth+';height:'+scrollerheight+';overflow:hidden;background-color:'+scrollerbgcolor+' ;background-image:url('+scrollerbackground+')">')
document.writeln('<div style="position:absolute;width:'+scrollerwidth+';height:'+scrollerheight+';clip:rect(0 '+scrollerwidth+' '+scrollerheight+' 0);left:0;top:0">')
document.writeln('<div id="first2" style="position:absolute;width:'+scrollerwidth+';left:0;top:1;">')
document.writeln('</div>')
document.writeln('<div id="second2" style="position:absolute;width:'+scrollerwidth+';left:0;top:0;visibility:hidden">')
Det är länken till sporting som inte funkar,den ska öppnas i nytt fönster,hur ska koden se ut då??****
