funkar inte(LÄNK)
17 svar · 249 visningar · startad av mr.mainline
mr.mainlineMedlem sedan feb. 2003777 inlägg
Vad är fel:
<script language="JavaScript1.2">
Pausing updown message scroller-
© Dynamic Drive (https://www.dynamicdrive.com)
For full source code, installation instructions,
Terms Of Use, visit http://www.dynamicdrive.com
//configure the below five variables to change the style of the scroller
var scrollerwidth=165
var scrollerheight=150
var scrollerbgcolor='333333'
//set below to '' if you don't wish to use a background image
var scrollerbackground='scrollerback.gif'
//configure the below variable to change the contents of the scroller
var messages=new Array()
messages[0]="<font face='Arial''>Sidan är uppdaterad 03-03-05</a></font>"
messages[1]="<font face='Arial'>Sportfiske mässa den 29-30 mars i Strömsnäsbruk</a></font>"
messages[2]="<font face='Arial'>Jag och broder Richard åker till Frankrike Etang de la horre den 18 April</a></font>"
messages[3]="<font face='Arial'>Swedish carp challenge i Vittsjön den 25-28 september</a></font>"
messages[4]="<font face='Arial'><a href='http://www.mikaeljohansson.com/sportfishingpages/sporting'target=">Sporting har en ny sida på Sportfishingpages</a></font>"
///////Do not edit pass this line///////////////////////
var ie=document.all&&navigator.userAgent.indexOf("Opera")==-1
var dom=document.getElementById&&navigator.userAgent.indexOf("Opera")==-1
if (messages.length>2)
i=2
i=0
function move1(whichlayer){
tlayer=eval(whichlayer)
if (tlayer.top>0&&tlayer.top<=5){
tlayer.top=0
setTimeout("move1(tlayer)",3000)
setTimeout("move2(document.main.document.second)",3000)
return
if (tlayer.top>=tlayer.document.height*-1){
tlayer.top-=5
setTimeout("move1(tlayer)",50)
else{
tlayer.top=scrollerheight
tlayer.document.write(messages*)
tlayer.document.close()
if (i==messages.length-1)
i=0
i++
function move2(whichlayer){
tlayer2=eval(whichlayer)
if (tlayer2.top>0&&tlayer2.top<=5){
tlayer2.top=0
setTimeout("move2(tlayer2)",3000)
setTimeout("move1(document.main.document.first)",3000)
return
if (tlayer2.top>=tlayer2.document.height*-1){
tlayer2.top-=5
setTimeout("move2(tlayer2)",50)
else{
tlayer2.top=scrollerheight
tlayer2.document.write(messages*)
tlayer2.document.close()
i=0
i++
function move3(whichdiv){
tdiv=eval(whichdiv)
if (parseInt(tdiv.style.top)>0&&parseInt(tdiv.style.top)<=5){
tdiv.style.top=0
setTimeout("move3(tdiv)",3000)
setTimeout("move4(second2_obj)",3000)
return
if (parseInt(tdiv.style.top)>=tdiv.offsetHeight*-1){
tdiv.style.top=parseInt(tdiv.style.top)-5
setTimeout("move3(tdiv)",50)
else{
tdiv.style.top=scrollerheight
tdiv.innerHTML=messages
*if (i==messages.length-1)
i=0
i++
function move4(whichdiv){
tdiv2=eval(whichdiv)
if (parseInt(tdiv2.style.top)>0&&parseInt(tdiv2.style.top)<=5){
tdiv2.style.top=0
setTimeout("move4(tdiv2)",3000)
setTimeout("move3(first2_obj)",3000)
return
if (parseInt(tdiv2.style.top)>=tdiv2.offsetHeight*-1){
tdiv2.style.top=parseInt(tdiv2.style.top)-5
setTimeout("move4(second2_obj)",50)
else{
tdiv2.style.top=scrollerheight
tdiv2.innerHTML=messages
i=0
i++
function startscroll(){
if (ie||dom){
first2_obj=ie? first2 : document.getElementById("first2")
second2_obj=ie? second2 : document.getElementById("second2")
move3(first2_obj)
second2_obj.style.top=scrollerheight
second2_obj.style.visibility='visible'
else if (document.layers){
document.main.visibility='show'
document.main.document.second.top=scrollerheight+5
document.main.document.second.visibility='show'
window.onload=startscroll
<ilayer id="main" width=&{scrollerwidth}; height=&{scrollerheight}; bgColor=&{scrollerbgcolor}; background=&{scrollerbackground}; visibility=hide>
<layer id="first" left=0 top=1 width=&{scrollerwidth};>
document.write(messages[0])
</layer>
<layer id="second" left=0 top=0 width=&{scrollerwidth}; visibility=hide>
document.write(messages[dyndetermine=(messages.length==1)? 0 : 1])
</layer>
</ilayer>
if (ie||dom){
document.writeln('<div id="main2" style="position:relative;width:'+scrollerwidth+';height:'+scrollerheight+';overflow:hidden;background-color:'+scrollerbgcolor+' ;background-image:url('+scrollerbackground+')">')
document.writeln('<div style="position:absolute;width:'+scrollerwidth+';height:'+scrollerheight+';clip:rect(0 '+scrollerwidth+' '+scrollerheight+' 0);left:0;top:0">')
document.writeln('<div id="first2" style="position:absolute;width:'+scrollerwidth+';left:0;top:1;">')
document.writeln('</div>')
document.writeln('<div id="second2" style="position:absolute;width:'+scrollerwidth+';left:0;top:0;visibility:hidden">')
Det är länken till sporting som inte funkar,den ska öppnas i nytt fönster,hur ska koden se ut då??****
SugarDaddyMedlem sedan apr. 20021 155 inlägg
<a href='http://www.mikaeljohansson.com/sportfishingpages/sporting' target='blank'">
obs mellanslaget mlln g' o target
får inte det att funka ändå det står felmeddelande: rad 36 tecken 126,
kan inte någon bara lägga in länken så kan jag kopiera den här ifrån??
Efter "target" nedan skall det vara apostrofer, ej en "snuff".
nix funkar inte.....sorry men gör så att gör ändringen i koden och klistra in hela koden här.
och tack för att ni hjälper mig :-))
Vafalls, har jag fel? :e
Såhär:
"<font face='Arial'><a href='http://www.mikaeljohansson.com/sportfishingpages/sporting' target='_blank'>Sporting har en ny sida på Sportfishingpages</a></font>"
ps. Använd css istället f hemska font-taggar.. :p
sorry mange med det funkar inte...
Det finns några till fel:
Det skall vara en "brädgård" före "333333":
Du har dubbla apostrofer efter "Arial" nedan:
Fullständig kod;
© Dynamic Drive ([url]www.dynamicdrive.com[/url])
Terms Of Use, visit [url]http://www.dynamicdrive.com[/url]
var scrollerbgcolor='#333333'
messages[0]="<font face='Arial'>Sidan är uppdaterad 03-03-05</a></font>"
messages[4]="<font face='Arial'><a href='http://www.mikaeljohansson.com/sportfishingpages/sporting'>Sporting har en ny sida på Sportfishingpages</a></font>"
i=2
i=0
tlayer.top=0
return
tlayer.top-=5
else{
tlayer.document.write(messages[i])
i=0
i++
tlayer2.top=0
return
tlayer2.top-=5
else{
tlayer2.document.write(messages[i])
i=0
i++
tdiv=eval(whichdiv)
tdiv.style.top=0
return
else{
tdiv.innerHTML=messages[i]
i=0
i++
tdiv2.style.top=0
return
else{
tdiv2.innerHTML=messages[i]
i=0
i++
if (ie||dom){
move3(first2_obj)
</layer>
</layer>
</ilayer>
if (ie||dom){
document.writeln('<div id="main2" style=" position:relative;width:'+scrollerwidth+';height:'+scrollerheight+';overflow:hidden;background-color:'+scrollerbgcolor+' ;background-image:url('+scrollerbackground+')">')
document.writeln('<div style=" position:absolute;width:'+scrollerwidth+';height:'+scrollerheight+';clip:rect(0 '+scrollerwidth+' '+scrollerheight+' 0);left:0;top:0">')
document.writeln('<div id="second2" style=" position:absolute;width:'+scrollerwidth+';left:0;top:0;visibility:hidden">')
Notera att det inte skall vara några radbrytningar i de närmast ovanstående raderna.
Vfan.. ;)
Det är inte raden
messages[0]="<font face='Arial''>Sidan är uppdaterad 03-03-05</a></font>" som spökar då?
Byt till
(snart börjar jag känna mig dum..) :r
*muttrar lite* - men Peter har rätt det är de dubbla apostroferna som fuckar upp det med stor sannolikhet :h
jag är verkligen ledsen men det funkar inte kollar ni koden innan?
Läs min sista rad väldigt noga ;)
är det denna du menar }</script> att den ska se ut såhär eller vad menar du??
och inte så här
Jag skickar med en fil istället.
om du kollar på http://trax.to/carp så nere i höger hörna finns scriptet om du klickar på den länken vi har klöddat med så kommer den i ramen och inte i ett nytt fönster..
Ojdå, jag måste ha tagit bort target="_blank".
Skickar med en reviderad fil.
YES!!!!!!!!!!!!!!!!!!! Nu funkar det tusen tack Peter...
No problem.
:bire
145 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
