har ett supeskumt problem:
har skalat bort allt onödigt men denna valideringen i netscape funkar inte, den väljer att skicka upp alertrutan hela tiden... vad missar jag?
<script language="javascript">
function validateForm()
return false;
function initPage()
self.document.assignNumberForm.REG_NUMBER.focus();
function ChangeOrg()
var result = prompt("Enter search criteria (e.g. \"ETX/I\" or \"ERA\")", "");
if (result != null)
document.assignNumberForm.ORG_SEARCH.value = result;
document.assignNumberForm.entry.value = 'start';
document.assignNumberForm.submit();
function DoAssignRegNumber()
document.assignNumberForm.DOC_NUMBER_TYPE.value = 'REG';
function DoAssignRefNumber()
if ((document.assignNumberForm.ORG.value !=null) && (document.assignNumberForm.ORG.value !=''))
document.assignNumberForm.DOC_NUMBER_TYPE.value = 'REF';
alert("Organisation missing!!");
osv med head body blabla...
<FORM NAME="assignNumberForm" ACTION="#" METHOD="POST" onSubmit="return validateForm();">
<SELECT NAME="ORG" WIDTH=1>
<OPTION VALUE="FR/SV">FR/SV</option>
</SELECT>
jag ser det inte men det borde vara någon struntsak jag missar =)
tack på förhand
Hoppis
